G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
#202
If anyone tries to solder two 0.12 ohms in the meantime let me know... I'm curious as RO if that will work! I believe the factory bulbs pull 21W from the front corners.. I'm not sure what the rears pull I'd just be guessing that they would be 21W as well...
My current LEDs I posted above have 2.5W at rear corners and not sure what the V-LED switchbacks pull... I did order some high power 7W corner lights from V-LEDs to replace my switchabacks... So to make short story long, I'll eventually have 7W in front two corners and 2.5W on rear corners.
Roger, I'm not sure what formula you used... But are those numbers helpful at all? Sorry I couldn't research the exact power pull of the factory lights as I am out of town still...
Kirk
Kirk
#203
Kirk
Kirk
#204
Sorry, I left out an important word.... I meant 2 resistors in series to increase resistance to 0.24 not decrease it to 0.06 ohms ... No clue if it would work but Roger had suggested it, was curious if anyone had tried that yet...
#205
Kirk
Kirk
#206
Balling in the...
The eBay Listing I purchased my Switchbacks from say they are 12w:
http://cgi.ebay.com/ebaymotors/ws/eB...d=244646953273
The rears don't have any Info about wattage:
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_4337wt_848
#207
I just spoke with V-LEDs the switchbacks I posted the link to earlier(48 smt) pull roughly 1.44W and obviously much less than that when it flashes... They were unable to give a specific wattage for when they are flashing...
#208
King of NYC
Just want to make some reminders out there after my hours and hours of experience working with wiring and LEDs back in the day.
1) Make sure the polarity is correct when putting in those LEDs in the sockets. They are almost always polarity specific.
2) To test if you have hyperflash with an LED bulb remember to actually turn on your ignition and test your actual turn singal. Hyper-flsh will NOT be seen with the hazards. Hazards will blink at normal rate even with LED bulbs in and no resistors and it will fool you.
That will save you a lot of run around time and headache. I can't remember how many times I rechecked my work over and over because of those 2 reasons! I actually even replaced the front bumper and everything thinking I was OK, come to find out I had to redo everything! For those who have been doing this kind of work on their car for awhile, you already know this but hopefully it will help a newbie.
Now we know this works all 4 corners I am going to tackle it! I need t source those resistors now!
#210
Balling in the...
A Quick Suggestion i have... Do not take ur Whole bumper off, Just take out the screws from the fenders out and you should be able to access the corner lights from there. Just pull back on the fender plastics. I figured this out after taking my bumper out around 4-5 times to change lights
#211
^^^ yeah there is absolutely not reason to remove the bumper for a simple bulb replacement. Turn your wheels to access the front wheel well pop out the two push pins and you can easily reach your hand right in by pulling the plastic out of the way. If you want just a tad more room you can even remove the one philips screw and pop out that top corner of the bumper. Plenty of room to do all the work you need to. I feel bad for the people that spent all that time taking the entire bumper off ;-D
#212
Wallet raped by my
The two rear red LED's work just fine I tried them prior to messing with the turn signal relay. Also, I just noticed that even though the front LED's flash correctly they do not go on when I put the parking lights on. Yeah this is odd that the standard bulb works, but the LED doesn't. You would think since the circuit out back at the bulb holder is getting 12v it should light up.
So after all this I re-examined my resistor install and it's perfect as far as I can tell. I then removed one of the resistors and that didn't make a difference. So as it stands the rear turn signals only work with a standard halogen bulb, the front LED's work and flash correctly, but will not go on with parking lights.
As for the specs on my LED's see one of my posts above I put a link in for the exact ones I ordered.
I'm at work now so can't mess with it anymore, but I'm definitely looking for some ideas.
Thanks,
James
Thanks,
James
#213
I had the same issue with my parking lights not coming on once I switched to led bulbs. I am using vleds AMBER 54 SMT TURN SIGNAL BULBS on all 4 corners. What I found was that the turn signal wire rests at ground when not in use. What its doing is actually shorting out the bulb and is the reason why the parking lights won't turn on. The way I fixed this issue was put a diode inline on the turn signal wire. That way there wasn't a ground feedback coming from the turn signal wire when the turn signal wasn't in use. Kind of sad that vleds are so expensive but they couldn't take the time to make sure that there bulbs wouldn't short out if this happens.
James
#214
Wallet raped by my
Well then that explains why one of the metal leads on the base of my front LED's melted. Thanks for the info. I wonder if just using a load equalizer would solve that problem since I don't plan on doing the resistor method in the turn signal relay.
#215
Unfortunately load equalizers won't solve this issue either. I went that route and ordered them from vleds when I ordered my bulbs and still ran into the issue with the parking lights not working. Only way I could get them to work properly was to use the diode inline on the parking light wire up front. I had some IN5400 3A diodes laying around from my days as an installer for Circuit City and Tweeter. Looking at RadioShacks website you can pick them up for less then $2.00ea. I haven't had any issue with them yet since installing them. They also sell a 4pack of 6A diodes for less then $3.00 if your afraid 3A isn't powerful enough. Hope this helps ya out.
Yeah but how is it some of these guys are using front LED's without diodes? This is starting to sound more and more complicated to the point where it's just not worth it anymore.
Thanks for the info though.
#216
Wallet raped by my
tbh idk why others haven't had this issue or maybe others haven't noticed that there parking lights aren't working properly. I'd like to know the answer to that myself. Unless we some how got a batch of shitty bulbs from vleds. Honestly for the money I spent on vleds i'm not impressed by them at all. I bought them because of how many people on here spoke highly of them. There overall quality was not worth the money imo.
#218
Well dang I didnt know VLED products were so horrible. Wish I would have known that before I bought them but this is the first time I have heard people complaining about VLED's. The thing is the bulbs work 100% as advertised and I tested the fronts on both leads outside of the car using a 12 volt source and it worked as it should. I just assumed it was the car that wasnt cooperating with the LED's and not the LED's themselves.
Well with all that said I am selling my new LED's that I just dont feel like dealing with. If they made these LED's to be 100% plug and play that would be amazing, but im not going to be installing all these load equalizers and resistors in the turn relay.
Here is the link to everything for sale if anyone wants to give them a shot. Price is OBO and includes a pair of load equalizers and some .12ohm resistors already soldered in parallel.
https://acurazine.com/forums/car-parts-sale-361/new-vleds-front-rear-54-smt-park-turn-rear-turn-bulbs-1157-7443-a-825019/
Thanks,
James
Thanks,
James
#220
Balling in the...
This is why I purchased from eBay. I didn't want to spend 50 bucks on a pair of LEDs to then find out they dont work right LMAO. I have purchased my Interior LED lights from VLEDs tho and have no Complaints at all. I purchased 4 pair from them
JTS97Z28 Im Guessing you received the Load Resistors I sent you
N.E. Ways The other night i was driving and my lights started to Hyperflash again .... So After I got home and stood their for a good few hours i left to then notice they stopped. This is come Crazy ish I wonder why they started to hyperflash just for a few and stop. It hasn't happend again and that happened on saturday
#222
Balling in the...
Aight Remember that Problem I had on Saturday?? Heres a video.
Situation: I am stopped at a red light and the Turns start to Hyperflash... As Soon as I take off and Accelerate they stop!!! WTF Anyone have any ideas? Should I add another resistor or something. Its strange but heres the Video:
http://www.youtube.com/watch?v=3-p6Ljfmr9E
#223
King of NYC
I tried this with 2 resistors in parallel...DIDN'T work!!! I checked and rechecked my work. Circuit board looks just the way Mayfoso's does. Can't figure out why? I am pretty annoyed because I went to great lengths to remove the load resistors from all 4 corners and I am close to regretting it because everything was working fine for 4 years with the old fashioned resistors.
How did this end up working for some of us and not for others? It can't be different relays, they look identical for all of us. I don't want to be stuck with hyperflash! meh! If all else fails I am going to spend a whole day putting the load resistors back??? I hope not, there has to be a solution here.
#224
I screwed up something in my car trying this. I thought I had done everything right, but apparently, I did something very wrong.
04 TL 5AT with Navigation
I have LED blinkers in the front, the original OEM bulbs in the back, and I wired both sets of sidemarkers to blink.
Before installing the modified relay, I cut the old resistors out. When I went to test the new relay, the blinkers did not work and there was some odd popping/hissing noise coming from inside the cabin near the relay/fusebox. I immediately turned them off but didn't smell anything odd.
I reinstalled the shunt resistor in the relay and the old LED load resistors. I tried testing the blinkers again, but they still wouldn't work. The left (driver's) side hyperflash and the right (passenger's) side don't work at all. The hazards and the alarm blink still work.
I went to a local Acura dealership and purchased a new relay and it did the same thing.
I tried asking this in the Problems forum, but got no responses. Anyone here have any ideas?
#226
The Acura dealer suggest I unplug the battery and hopefully that would reset it, but no luck. He thought I may have to replace the MICU...that is one piece with the interior fuse box. I dread this possibility.
#227
#229
#230
Sorry to hear your having issues with this. Before we even start diagnosing your problem I see a red flag where you mention "I cut the old resistors out" I hope you didn't really cut it out and actually desoldered it. Please post some pictures or your relay if you could.
a
#231
#233
King of NYC
^^Yup I soldered my resistors same way. Not working. I left mine in and I've been running the car just fine as is. After reading this thread I feel like putting the shunt back in to avoid trouble. Oh boy this is going to take hrs. to put all 4 gold load resistors back in!
Unless someone can calculate a better resistor that will work with 4 LEDs. This has to work, seems to be working fine for Roger and others with 2 LEDs.
BTW anyone that is having weird electrical problems; I noticed that the lead for the resistor has to bend dangerously close to one of the pins of the relay. MAKE SURE they are NOT making contact! It may be a reason for the electrical system going haywire.
#235
I haven't checked the fuses yet.
#236
If anyone needs some of these resistors, I just bought 10 of them from the same website Roger555 got them from and will have extras. PM me if you want me to send you some!
#239
Desert Life Sucks!!
Damn cuz I just ordered some switchbacks from vleds and was about to hit up local radio shack and do the shunt removal to stop hyperflash.
Someone should gather intel on who has all 4 led blinkers compared to just the fronts led back oem.
Then what resistors used and if shunt method or inline??
Do you have to run 2 in parrallel or can you just use 1 resistor enough to work?
And I know most of you know but those resistors only work going in one way and can not be reversed because there is alot of smarter people here than I.
#240
Balling in the...
<~~ I have Switchbacks in the Front and LED turns in the Rear. Mines seem to work fine with two .12 resistors soldered just like the picture above. I have only one problem which is the Video i posted above. Sometimes if im not on the gas it starts to hyperflash and stops when i take off. Weird but only happens maybe 3 times a week. I think Imma see if I buy another Relay and try it again with the new one. I think I may have scratched some of the relays bored when i was removing the shunt and im wondering if thats the reason its doing this.
