Go Back  AcuraZine - Acura Enthusiast Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008)
Reload this Page >
G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
Notices
Old 01-03-2017, 04:59 PM
  #1201
Registered Member
Any RadioShack in Canada will have it.
Engwam is offline
Old 01-27-2017, 05:24 PM
  #1202
Registered Member
zune hd's Avatar
Anybody still have any .24 ohm resistors they wanna get rid of?..Getting some switchbacks in the mail next week
zune hd is offline
Old 01-27-2017, 06:47 PM
  #1203
Registered Member
l have both 0.24 and 0.12 ohm resistors. You can have them all (since I no longer have my TL), just pay it forward to whoever else may need them as well. A little payback to all the help I have gotten here. Thanks!
uneedkhoality is offline
Old 07-16-2017, 09:15 PM
  #1204
Registered Member
peter6's Avatar
Just finished it on my base 2008 TL.
I also tested those scenarios, and with LEDs only on rear, or with LEDs both front and rear relay works as it should.
Thank you so much.
And because photos are down, there's couple from me :
rest in spoiler :
Spoiler
peter6 is offline
Old 07-20-2017, 01:13 PM
  #1205
Registered Member
wusty23jd's Avatar
Isn't it crazy how this little modification can resolve such an annoying problem?! This method is 100Xs better than installing load resistors in my opinion.
wusty23jd is offline
Old 08-13-2017, 11:19 AM
  #1206
ATN
Registered Member
ATN's Avatar
Anyone still have 0.24 ohm resistors for sale?
ATN is offline
Old 08-13-2017, 12:17 PM
  #1207
Received 5,934 Likes on 4,758 Posts
Digikey.com.
I may have some lying around
thoiboi is offline
Old 08-13-2017, 12:39 PM
  #1208
ATN
Registered Member
ATN's Avatar
Originally Posted by thoiboi View Post
Digikey.com.
Thanks, Let me know if you still have some for sale. I looked on Digikey earlier, would this be the right resistor:
https://www.digikey.com/product-deta...CCT-ND/2059057
ATN is offline
Old 08-13-2017, 03:08 PM
  #1209
Registered Member
zune hd's Avatar
I still have some.. somebody on the thread had paid them forward to me so I can send you some
zune hd is offline
Old 08-13-2017, 03:10 PM
  #1210
Registered Member
zune hd's Avatar
Pm me your address if your interested
zune hd is offline
Old 08-13-2017, 03:12 PM
  #1211
Registered Member
zune hd's Avatar
zune hd is offline
Old 08-13-2017, 03:23 PM
  #1212
ATN
Registered Member
ATN's Avatar
PM Sent!
ATN is offline
Old 02-04-2018, 12:49 PM
  #1213
Registered Member
3GTLCHICK's Avatar
Nice. So .24 and front and rear work as they should? Anyone know what's the best led bulbs at the moment for this?
3GTLCHICK is offline
Old 02-18-2018, 02:08 AM
  #1214
Registered Member
3GTLCHICK's Avatar
I've got bulbs, does anyone know if this kills the burnt bulb indicator, too?
Old 02-22-2018, 09:46 PM
  #1215
Registered Member
skd2k1's Avatar
I've been using Morimoto bulbs because they cost less, but I think the Vled Tritons are pretty much the best out there right now...they're expensive though.
skd2k1 is offline
Old 02-23-2018, 09:04 AM
  #1216
Registered Member
peter6's Avatar
If you're planning buying Triton V6, read my thread first. No idea if they fixed them, but they have quite a big problem.
Otherwise go with morimoto, or just with something from Amazon. I've been running those cheap switchbacks ($20 for both) for like a year now, and they still work great.
peter6 is offline
Old 02-23-2018, 09:50 AM
  #1217
Registered Member
skd2k1's Avatar
^link? I didn't know about the issue with the v6!
skd2k1 is offline
Old 02-23-2018, 05:39 PM
  #1218
Registered Member
peter6's Avatar
peter6 is offline
skd2k1 (02-23-2018)
Old 03-08-2019, 08:51 AM
  #1219
Registered Member
EvilVirus's Avatar
Received 1,074 Likes on 855 Posts
Does anyone know if this works only for Acuras/Hondas or can this work for other vehicles too i.e. Toyota/Lexus/Nissan/Infiniti...etc
EvilVirus is offline
Old 03-08-2019, 10:00 AM
  #1220
It depends on how the turn signal relay is wired. Pop it open and compare with the ones here
thoiboi is offline
Old 05-29-2019, 02:11 PM
  #1221
Registered Member
iTzVlad's Avatar
iTzVlad is offline
Old 05-29-2019, 02:25 PM
  #1222
Registered Member
wusty23jd's Avatar
It appears that it should. However, this relay is $60.00 as opposed to $0.02 you could pay to do this yourself if you have 15 min and a soldering iron.
Old 05-31-2019, 12:28 PM
  #1223
Registered Member
iTzVlad's Avatar
Yah you are right. I picked up a bunch of resistors from Amazon for $6. I'm gonna try the OP method first. Any idea what soldering iron I should get? I've never soldered before so this feels like a good training piece.
iTzVlad is offline
Old 05-31-2019, 01:35 PM
  #1224
Registered Member
iTzVlad's Avatar
Forgot to mention, if I have switchbacks LEDs in my front headlights, will they be affected by the mod as well? In other words will the regular 0.12 Ohms 1 watt resistor work for both LED turn signals (front and rear)? My front LEDs never had hyperflash before and they have an independent fuse. I just swapped my rear turn signal bulb for LEDs. That's when the hyperflash began.
iTzVlad is offline
Old 05-31-2019, 02:22 PM
  #1225
Registered Member
It explains how to solder for LEDs for front and rear. Right now with one resistor, I believe itís for either front or back,not both.
I took my module out and brought it to a computer repair guy and had him solderit to the board. Gave him three bucks. Took him all of 10 seconds.
tlmailman is offline
Old 05-31-2019, 02:40 PM
  #1226
Registered Member
Originally Posted by iTzVlad View Post
Going to buy this and give it a go.
I broke the PCB on my factory relay trying to get it out. Went and bought a direct OEM replacement for $72 with tax and soldered a .24 resistor in and now my turn signals do not work at all. Pretty irritated tbh.
EmwunGarand is offline
Old 05-31-2019, 02:45 PM
  #1227
Registered Member
Should note, my OEM incandescent bulbs do not work anymore. I have not swapped in the switchbacks to test. The OEM should still work perfectly if I did this right and they don't.
Old 05-31-2019, 03:37 PM
  #1228
Registered Member
iTzVlad's Avatar
Ahh sounds good. I skimmed through the thread and that noticed someone with 4 turn signal LEDs went with 2 0.12 Ohm resistors in parallel.
I'm gonna take your advice as well, go to a computer repair guy and have him solder it up.
iTzVlad is offline
tlmailman (06-01-2019)
hashbrown
Fourth Generation TL (2009-2014)
34
12-31-2015 12:44 PM
thegipper
09-28-2015 01:01 PM
mshipon
2G CL Problems & Fixes
09-28-2015 12:14 PM
ripit
09-26-2015 06:19 PM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
