G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
Old 05-04-2011, 01:59 PM
  #81
B A N N E D
friesm2000's Avatar
Originally Posted by ajs800
.06 ohm is exactly what I was thinking...didn't use the formula above, but figured if .12 worked for two, doubling the resistance would be .06. I found some .06 ohm through hole resistors but are rated at 2W...I'm thinking it would work, but not totally sure. However, doubling up two of the .12 that Roger linked is not a bad idea and just as easy.
resistor specs:
Watts: 2
Ohms: 0.06
Tolerance: 3
Lead/Terminal Type: Axial
Number Leads/Terminals: 2
Material: Wirewound
it means that it is able to dissipate 2 watts of power/heat, compared to only 1 watt of power that is required (just means it might be a little larger sized then the one's shown in the photos)
Old 05-05-2011, 12:16 AM
  #82
BSpecialist's Avatar
Originally Posted by luder917
what im try to say is if you have two of the 0.12 ohm resistors, put them in parallel if you want to run LEDs in all four corner. ...
What would be the easiest way to solder them in parallel? Just have them both bridge the holes and solder them? Or would it be a more involved process?
Old 05-05-2011, 02:02 PM
  #83
Chapter Leader (San Antonio)
TheChamp531's Avatar
Hey Roger. Did you ever send mine out?
Clear your inbox!
Old 05-12-2011, 10:16 PM
  #84
panditobinbin
ervin1128's Avatar
roger, can i buy 2 resistors?
Old 05-13-2011, 03:11 AM
  #85
SSM FTW
luder917's Avatar
Exactly. Check out one of the picture here http://www.ridgelineownersclub.com/f...ad.php?t=37691
This guy solder his in parallel cause he couldn't find a 0.12 ohm resistor locally so he work with what he could find.
Old 05-13-2011, 02:58 PM
  #86
wtf8269's Avatar
FYI a .1ohm 2w resistor works fine. That was all I could find locally. So .12+/-.02ohm seems to be acceptable.
Old 06-06-2011, 02:56 PM
  #87
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
Added to the 3G Garage/Service Dept. G-109
Roger555 (06-07-2011)
Old 06-06-2011, 10:44 PM
  #88
Anyone with front and rear LED bulbs try two .12ohm resistors in parallel with success?
Old 06-07-2011, 03:08 AM
  #89
con5tant's Avatar
is there someone that could do this for me? i don't have a solder gun
Steve 21 (06-13-2011)
Old 06-07-2011, 12:59 PM
  #90
panditobinbin
ervin1128's Avatar
theyre like 10 bucks at radioshack. Its not hard to do. Im a complete noob with a soldering iron but i got it done. it was a pretty easy mod with some help from youtube on soldering
Old 06-07-2011, 04:41 PM
  #91
OCD
Roger555's Avatar
Thank you! Now everyone thank me lol
The following 8 users liked this post by Roger555:
614erich (06-22-2012), dwb993 (10-16-2011), gogators22 (11-07-2011), paperboy42190 (04-04-2013), Slpr04UA6 (05-30-2021), thoiboi (09-06-2013), TL Luver (02-15-2014), TripAcez (06-07-2011) and 3 others liked this post. (Show less...)
Old 06-07-2011, 04:57 PM
  #92
TripAcez's Avatar
Man this mod was fairly easy, alot cleaner as stated as opposed to the load resistors. Ever since i put my type1 switchbacks on, its been a head turner! i live around the new brunswick,nj area and i can only imagine how many people around there have probably been searching frantically for them(thats how they do there, they "copy") thanks ALOT roger for sure this mod made me realize i wasted money on the load resistors.
Old 06-07-2011, 08:32 PM
  #93
con5tant's Avatar
i can't seem to find the resistor, i'll buy one off you Roger.
Old 06-07-2011, 08:49 PM
  #94
OCD
Roger555's Avatar
im out man lol there are lots of places to buy them. I got 10 from digikey for like 3 dollars. See my link
Old 06-08-2011, 01:15 AM
  #95
Balling in the...
Mafyoso's Avatar
Need to know which Resistors to buy for Front LED Switchbacks and Rear LED Turns I just installed all my lights and this Hyper lighting is driving me NUTS
Old 06-08-2011, 02:45 AM
  #96
panditobinbin
ervin1128's Avatar
i have some if you want. just pm me if interested
con5tant (06-08-2011)
Old 06-08-2011, 01:33 PM
  #97
Balling in the...
Mafyoso's Avatar
Do you have two .06 Resistors? If you do ill take em off ur hands LMK. Ive been trying to figure this out and it looks like radio shack doesn't carry them where i live.
Old 06-08-2011, 01:36 PM
  #98
panditobinbin
ervin1128's Avatar
no, i just have .12 resistors. sorry, mafyoso
Old 06-08-2011, 03:41 PM
  #99
OCD
Roger555's Avatar
if you wire (2) .12 ohm resistors in parallel it equals .06
http://www.sengpielaudio.com/ParallelWiderstaende.gif
Old 06-08-2011, 05:31 PM
  #100
Balling in the...
Mafyoso's Avatar
Does someone know where I can buy .12 ohmz or even .06 ohmz resistors? Link? Store? Ill appreciate it Thanks
Old 06-08-2011, 07:34 PM
  #101
OCD
Roger555's Avatar
Lol you guys are helpless I posted a link already to where I bought them but here it is again
http://parts.digikey.com/1/parts/169...r-52-0r12.html
You can buy them from any of the other major electronics distributors but digikey has $2 dollar shipping on small orders
www.Mouser.com
www.Newark.com
wusty23jd (09-16-2015)
Old 06-08-2011, 08:06 PM
  #102
panditobinbin
ervin1128's Avatar
www.Mouser.com
www.Newark.com
Im out now too. i got mine from digikey tho. Thanks again, Roger.
Mafyoso (06-09-2011)
Old 06-09-2011, 01:15 AM
  #103
Balling in the...
Mafyoso's Avatar
Yeah Im a Little Helpless Sorry, I Find resistors but not the ones I need. Thats why i asked for a direct link to them But ill find them thanks anyways
Old 06-09-2011, 04:49 AM
  #104
OCD
Roger555's Avatar
Here .05 ohm they don't have .06 (68 cents)
http://search.digikey.com/scripts/Dk...me=989-1085-ND
Old 06-09-2011, 10:45 AM
  #105
Balling in the...
Mafyoso's Avatar
Must Say Roger555 You are D Man!!! Thanks again and sorry for being such a Pain in the ASS...
Old 06-10-2011, 04:18 PM
  #106
tehloxely's Avatar
Has anyone successfully used two .12 resisters, in parallel with front and read LEDs?
Old 06-10-2011, 05:27 PM
  #107
As soon as I get my switchbacks and rear signals I will be attempting it. I will be sure to post with pictures if it is successful.
Old 06-12-2011, 06:26 PM
  #108
TranceAddict's Avatar
Good read ...I just bought the switchbacks ! Thanks
Old 06-12-2011, 10:38 PM
  #109
Just installed my switchbacks tonight and it worked great. I installed 2 of the .12ohm resistors in because I am planning on adding rear LED signals as well. With that said, it still functions great with both resistors in there. The hardest part was getting the module out from under the dash, I'm not sure why but it was a PITA.
Thank you Roger for figuring this out, and thank you ervin for the resistors!
Old 06-13-2011, 12:09 AM
  #110
Balling in the...
Mafyoso's Avatar
OK But has anyone attempted this with both Switchbacks and LEDs in the rear? BSpecialist said he just added both resistors with switchbacks only. I have some resistors on their way so hopefully this does work cause this hyper flash is a PITA when both switchbacks and rear LEDS
Old 06-13-2011, 07:34 AM
  #111
King of NYC
rockyfeller's Avatar
Nobody has done it with LEDs in all 4 corners yet?
Old 06-13-2011, 08:21 AM
  #112
dr_shoxer's Avatar
Thanks a lot for the great write-up Roger! I'm definately going to be doing this instead of the resistors!
Old 06-13-2011, 10:21 AM
  #113
Balling in the...
Mafyoso's Avatar
Not Yet
If I get my resistors soon ill try it out and let everyone know on here.
Old 06-13-2011, 12:35 PM
  #114
My rear LED bulbs are coming from Hong Kong and won't be here until later this month. That's when I will be able to confirm that 2 of the .12ohm resistors work...that is unless Mafyoso beats me to it. So hurry up Mafyoso!
Old 06-14-2011, 09:29 PM
  #115
Balling in the...
Mafyoso's Avatar
Got my Resistors today So im about to do this right Now... ill post my findings in a few
Old 06-14-2011, 09:45 PM
  #116
OCD
Roger555's Avatar
good luck!
Old 06-14-2011, 09:54 PM
  #117
EDIT: ignore this
Old 06-14-2011, 09:55 PM
  #118
Do eeet
Old 06-14-2011, 10:41 PM
  #119
Balling in the...
Mafyoso's Avatar
I want to first thank luder917 for mailing me the resistors
So YES the Two .12 Ohmz Resistors Worked with Switchback LEDs In the Headlights and Red Turn LEDs in the Tail lights
Hell Yea no more Hyper Flashing. Here is a picture and a Video to show PROOF that it works
http://www.flickr.com/photos/63529687@N04/5834495631/
P.S. It took my longer to UPLOAD the damn video from my Cell phone to Youtube (over WiFi) Then it did to do this MOD. Took maybe 15 minutes. The hardest part was trying to get the Relay out of its slot near the Fuse panel. Other than that I used a cheap ass Soldering Kit from Radio Shack and the Resistors Luder917 sent me. GL
The following 4 users liked this post by Mafyoso:
CubanLynx84 (07-11-2011), daluvdr (06-15-2011), Horditruck (08-29-2011), tehloxely (06-17-2011)
Old 06-14-2011, 10:47 PM
  #120
Awesome work.
Thank you Roger, luder, ervin (for the resistors), and Mafyoso for confirming the 2 resistor theory. Can't wait to get my rear LEDs in!
Quick Reply: G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
