Go Back  AcuraZine - Acura Enthusiast Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008)
Reload this Page >
G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
Notices
Old 11-07-2011, 01:18 PM
  #401
Registered Member
Cali_Joker's Avatar
That vid just made my day, looks way better with leds, thank u. Should be getting mine by end of week
Cali_Joker is offline
Old 11-07-2011, 05:07 PM
  #402
Registered Member
Dsrtne1's Avatar
Originally Posted by gogators22 View Post
interdating. where did you buy the resistor from?
I got it from a very small electronics store.
Dsrtne1 is offline
Old 11-08-2011, 11:05 PM
  #403
Registered Member
Cali_Joker's Avatar
Exclamation
well i got my rear LEDs today , put them in and i got the hyperflash again this is how i soldered my two resistors (attachment). i did cut the extra parts out from sides. guess i gotta look n see what i did wrong. any ideas guys?
Attached Thumbnails G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS-imag0718.jpg
Old 11-08-2011, 11:57 PM
  #404
Registered Member
vietxquangstah's Avatar
what ohm are those resistors?
if they are 0.12ohm each than that should be correct... the only thing i can assume is you did a poor job soldering it.
use this picture as reference
vietxquangstah is offline
Old 11-09-2011, 12:07 AM
  #405
Registered Member
This is not correct, 2 0.12ohm resistors should be put in series. If you put them in parallel, you will create 0.06ohm resistance instead of the desired 0.24ohm.
if you want to put them in parallel, you will need to get 2 0.48ohm resistors.
Thojmoto is offline
Old 11-09-2011, 12:17 AM
  #406
Registered Member
Cali_Joker's Avatar
[QUOTE=vietxquangstah;13352093]what ohm are those resistors?
i got them from digikey , the ones that someone posted the link to.
Old 11-09-2011, 12:21 AM
  #407
Registered Member
Cali_Joker's Avatar
ill take a look at the relay tomorrow after work and take some better pics
Old 11-09-2011, 11:18 AM
  #408
Registered Member
What Thojmoto said, they need to be soldered in series, not in parallel...you guys should really read this thread thoroughly.
From Post #305, thank you xavier25
BSpecialist is offline
Old 11-09-2011, 11:23 AM
  #409
potmilkz's Avatar
Received 1,010 Likes on 784 Posts
does this work for 4g?
potmilkz is offline
Old 11-09-2011, 05:39 PM
  #410
Registered Member
so this is what needs to be done to prevent hyperflashing in both front and rear turn signals? Or will one .12 ohm resistor work?
gogators22 is offline
Old 11-09-2011, 05:42 PM
  #411
Registered Member
Yes, you will need two 0.12 ohm resistors (soldered in series; end of one to the end of the other) OR one 0.24 ohm resistor. Both will solve 99.9% of all hyper-flashing issues.
gogators22 (11-09-2011)
Old 11-09-2011, 05:46 PM
  #412
Registered Member
so OP was wrong with just one?
(I just ordered 10 so I'm good, just making sure I get it right before I solder for the first time in my life)
Old 11-09-2011, 06:07 PM
  #413
2007 6SMT Type-S
SurfingScotty's Avatar
GREAT SUCCESS!!! [/borat] I dug into the relay again and switched my 2 0.12ohm resistors from a parallel circuit setup, to a series. That is, solder them end to end and then solder them into the board (mine created a triangle). NO MORE HYPERFLASHING! I have LED switchbacks up front, and red LED signals in the rear and they are working 100%. So for those of you who want LEDs at all 4 corners, this seems like a very viable option. You can even just spring for 1 0.24ohm resistor and you should be good to go.
Video comparing my rear LED signals to the stock will be up shortly...
Type-S' are 1157, correct?
SurfingScotty is offline
  #414
Registered Member
guitarplayer16's Avatar
Received 2,245 Likes on 1,662 Posts
No, Roger555 was right with one .12ohm resistor because he only used it to prevent hyperflashing on only the front turn signals.
He doesn't have rear LED tun signals
What you're trying to do is prevent hyperflashing on all four corners.
IMO, put in a .24ohm resistor and call it a day.
Even if you only get front leds and keep the rears halogen, or vice versa, it will not hyperflash.
Yes.
guitarplayer16 is offline
Old 11-09-2011, 06:13 PM
  #415
2007 6SMT Type-S
Originally Posted by Roger555 View Post
Nice work! We should have a moderator add this to the first post lol for any noobs stumbling onto this.
No shit! I'm on post 180 something and I have a headache from reading! Still have about 4 more pages to go to make sure something is over looked.
Old 11-09-2011, 06:38 PM
  #416
2007 6SMT Type-S
WTB .24 OHM, would The Home Depot have these? Where should I look locally?
Old 11-09-2011, 07:21 PM
  #417
Registered Member
Dunno if Home Depot will have it. I went to Fry's and they didnt have it either, but Fry's did have some 0.47ohm. I bought 2 of those and put them in parallel, works fine for me.
Thojmoto is offline
Old 11-09-2011, 07:25 PM
  #418
Registered Member
well, since I just ordered 10 .24ohms, I will just keep them.
Old 11-09-2011, 07:30 PM
  #419
Registered Member
Round 3's Avatar
sweet. thanks man I'll definitely try this
Round 3 is offline
Old 11-09-2011, 07:40 PM
  #420
Registered Member
Or sell the leftovers to members on here lol
That's how I bought mine =)
Old 11-09-2011, 08:03 PM
  #421
Registered Member
ugh, the sucky thing is that I accidentally bought (5) 0.05ohm resistors for $5something and then ordered (10) .24ohm ones today. what a waste of $.
and to top it off I got the screwy used ignitor for $50 today so I am skeptical hippo about getting my lows, new HID fogs, and corner LEDs working properly this weekend
Old 11-09-2011, 08:19 PM
  #422
rockstar143's Avatar
Received 15,066 Likes on 11,216 Posts
Wow Roger, you've come a long way! I can't believe I'm just now finding this out...
I need to do this to my fiance's car...I don't have LED's but if I do, I would do this over individual resistors for sure.
rockstar143 is online now
Old 11-10-2011, 09:58 AM
  #423
2007 6SMT Type-S
Sell me one of your .24's. That will help offset your loss. I'm sure others will want some, too! I need one ASAP! PM me!
Old 11-10-2011, 02:16 PM
  #424
Registered Member
re-distribute the remaining 9 0.24 ohm resistors you have for $1 each.
that's how most of us here got our resistors.... 1 person bought a bulk of 10 or more and sold the remaining ones for a few bucks to members
Old 11-10-2011, 02:55 PM
  #425
I might even preemptively jump in on one of those...you know, just in case!
Old 11-10-2011, 03:50 PM
  #426
2007 6SMT Type-S
Installed my .24 resistor. It's a 1/2 watt, read that shouldn't make a difference. Haven't installed LED's yet but the halogens still work. Only now I occasionally hear an electrical "scratch" sound upon engaging the turn signal. Kinda weird.
Old 11-10-2011, 06:37 PM
  #427
KBPftmfw
95oRANGEcRUSH's Avatar
Not a waste of money. I'll gladly buy one of your .24ohm resistors. Shoot me a PM.
95oRANGEcRUSH is offline
Old 11-11-2011, 05:08 PM
  #428
Registered Member
Cali_Joker's Avatar
so i finally was able to work on this mod again lol took care of it now yay
Attached Thumbnails G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS-imag1401.jpg   G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS-imag1402.jpg   G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS-imag1404.jpg   G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS-imag1406.jpg
Old 11-11-2011, 06:31 PM
  #429
Bo$$ Member
Mr. I.T's Avatar
I just installed my .24 and my signals stopped working...it just makes one "click" and nothing. Is there a certain orientation to install these? Right now my colour order is gold, silver, yellow, red. Is it possible its on backwards?
Mr. I.T is offline
Old 11-11-2011, 06:49 PM
  #430
Registered Member
I believe they are not polarity specific.
Check the soldering?
Old 11-14-2011, 10:36 AM
  #431
2007 6SMT Type-S
I have the same color code on mine; mine work only every 5-6 times I flip the blinker arm I hear an audiable "scratch" sound along with the blinker "click". Other than that, my work normal. As stated, check your connections or get a new resistor (my )
Old 11-16-2011, 08:08 PM
  #432
2007 6SMT Type-S
HELP!!!
Have LED's in the rears as of last week and work great. Put my new VLEDs Switchbacks in the fronts and everything seemed to work great only when I turn on, say...the left blinker, it flashes orange AND the right flashes white! What the hell???
Old 11-16-2011, 08:23 PM
  #433
Registered Member
I really don't understand how you guys are having all these weird ass issues. My clicker noise sounds the same, my switchbacks from cheapo ebay work great, the lights blink on the correct side when they're supposed to, and this is after re-soldering everything twice. All i can say is double check your soldering points and make sure you didn't solder/desolder anything else.
Old 11-16-2011, 08:43 PM
  #434
Registered Member
Originally Posted by bspecialist View Post
i really don't understand how you guys are having all these weird ass issues. My clicker noise sounds the same, my switchbacks from cheapo ebay work great, the lights blink on the correct side when they're supposed to, and this is after re-soldering everything twice. All i can say is double check your soldering points and make sure you didn't solder/desolder anything else.
+1
Old 11-16-2011, 08:50 PM
  #435
2007 6SMT Type-S
My solder points are perfect. The fronts were working normal with halogens.
Didn't have an issue until I put in the switchbacks. The only thing I can think of is maybe I broke something with the relay when I was pulling it out (cracked the housing with vice grips).
Old 11-16-2011, 09:01 PM
  #436
Registered Member
About the clicker noise it was all in my head so no it's not an issue
Old 11-17-2011, 12:21 AM
  #437
2007 6SMT Type-S
So here are a couple videos to show what's going on. The 1st one was taken within the 1st 5 mins of LED operation. Everything works like it should. >5 mins and I start getting the orange blinking on the correct side, and the white is blinking on the other side. I only get the screwy opperation on the front LEDs. The rears operate flawlessly.
Correct Opperation:
http://img195.imageshack.us/img195/1787/z2e.mp4
Incorrect Opperation:
http://imageshack.us/clip/my-videos/100/d92h.mp4/
(sorry they are links. I don't know how to embed videos from Image Shack)
Old 11-17-2011, 12:24 AM
  #438
Registered Member
Try it with the car running, the blinking could just be pulling a little too much voltage for your battery. Just a thought?
Old 11-17-2011, 10:32 AM
  #439
KBPftmfw
I'm looking for either 2 of the 0.12ohm resistors or 1 0.24ohm resistor. I will obviously pay for them. PM me or leave a reply in the thread if you can help a brother out.
Thanks!
Old 11-17-2011, 10:38 AM
  #440
2007 6SMT Type-S
That was how I 1st noticed it. I was sitting at a light waiting to make a R hand turn and noticed the ground on the driver's side was "flashing".
Quick Reply: G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
