fuel injector cleaning
Has anyone got the injectors professionally cleaned. I've been experiencing a loss of power and hesitation on my car and am thinking that maybe the fuel system needs to be cleaned. I was thinking that because I only put 93 octane fuel in it that I wouldn't need to. Am I right? The car has about 13K miles on it.
Find it hard to beleive your injectors are that dirty by 13K, unless you used bad gas that let them clog up or I beleive there were some issues with GAS that had too much ethanol in it, was destroying injectors.
using 93 just reduce the usage of cleaner. valvoline vp053 cleaner work great. anytime i put 89 octaine gas for too long in my tsx i feel it. a quick shot of cleaner in the tank and its back to new.
maybe a dirty air filter?
Its simply time for routine cleaning of the injectors
Doesnt anyone watch those Shell commercials?
See gen2 thread Seafoamed the Ol Tl
exact product they use in the machine- only for 6-8 bucks a can
you add 1 can directly to 1/4 tank to clean the injectors and 1 can into manifold vac line to direct clean the valves and piston tops
have fun!
have fun!
Originally Posted by lowgrowl
Is there any harm in using a product like chevron techron. It was recommended
WalMart has good quality fluids and filters at very good prices. I get 6 bottles of injector cleaner for about $6.
Brand name premium gas has detergent additives in it.
Shops don't take the injectors out to clean them; they just run a cleaner through the intake manifold. It's usually unnecessary and a waste of money as far as I'm concerned. In the rare cases when it is needed, you can do it yourself.
Originally Posted by Xpditor
Chevron Techron is very good, if a little pricey. Almost any injector cleaner will work as a preventative against buildup of deposits on the injectors. I put a pint of whatever is on sale in the gas tank about once a month.
Yeah the dealership wants like 2 bills to clean the injectors. I think I'll try the chevron first. By the way does cleaning the injectors produce a noticeable improvement in power and mileage. That's what i need.
With only 13k, your injectors shouldn't be clogged if you've been using brand name premium (93) fuel.
I can't really answer if you will get increased power/performance since I have never let mine get dirty to start with.
If you performance has decreased, I would replace the air filter with one from the dealer (I don't know any after market air filters for the TL). That would be my first suspect for a loss of performance and it can get clogged in 13k if you are in a dusty part of the country.
Good. Luck. You might want to check the sub-forum PROBLEMS & FIXES to see if there is some further info in there.
Also, check the 3G GARAGE.
Let us know how you make out.
Registered Member
13K miles IS too soon to start seeing the kinds of things described here. Unless the poster has been using "cheap" gas or hitting stations when their tanks are being filled by a gas tanker truck (even then, the fuel filter should have picked up debris). He could always take the car by a good shop and get the engine codes read to see if anything shows up. Could also be a sticking throttle body butterfly valve.
Mike's Silver Bullet
13k = under warranty.
Take it to the dealer.
Could it be that you just got used to the acceleration?
Have somebody with you stopwatch it up to 60 mph, see what you get.
Good Luck.
Good Luck.
Registered Member
Good Luck.
Good Luck.
Thoughts?
Honestly, it could be any of the above.
One of the more likely causes is a tank of bad gas.
Run the rest of that tank out, refill at a different station (different brand, too), and if it still has the symptoms, then take it to the dealer.
Registered Member
Originally Posted by gammah
If you need to clean your fuel injectors, use this stuff: B&G 44K. It works wonders!! I think this is the stuff they use at dealerships to clean fuel injectors. You only have to pour one can and fill up one full tank.
Gammah
Gammah
Best to go with something like Chevron Techron.
Registered Member
Good Luck.
Good Luck.
The dealership has told me that if there's anything wrong with the car the check engine light would appear. The guys really don't take a curiousity about figuring out problems. It seems like they just want you to come in for routine services and shut up. I think acura sales/service leaves alot to be desired.
Here is the real info once again from a guy who used to sell this service:
Go buy 2 cans of Seafoam- read gen2 thread Seafoamed the Ol TL
this is THE stuff they use in the machine
Our method is better because we go direct into a vac line and the gas tank
The machine simply takes a can of gas with cleaner and runs into the fuel system normally- no vac blasting action anywhere- you can add cans to your gas tank for same result!
Chevron is good- and if you read their website- it is only good from the pumps minimal doseage as maitenance and will ~eventually~ clean deposits.
They say to use a bottle of their stuff in a tank now and then for max cleaning and its pricey
93 octane is no better than 91 at low altitudes- 87 is a no-no all the time
I'm still betting on bad gas, though.
Gammah
Gammah
Seafoam is not what we use in the machine most if not all use BG products as seafoam has been around for so long because it was made for 2 stroke marine engines reason for the name. Yes it does clean but not as well as using BG cleaner just using 44k in the tank alone cleans better. I know a lot of you think the dealership fuel system cleaning is a rip off but it really isn't when done properly I'm a Hyundai master tech and Hyundai due to the GDI fuel system is notorious for carbon build up just like BMW. We recommend cleaning every 15k service and u would be surprised the amount of carbon build up at 15k but once complete and we look in the cylinders they are back to new again. A lot of BMWs I've had to literally remove the manifold and have to wire brush and soak the piston tops and clean the valves because they are so carboned up from not being serviced and using poor fuel quality. Everyone thinks 93 octane is the same from any gas station and that's the farthest from the truth. Shell V power is the best fuel you could use then Citgo and Sunoco and Mobil. You can feel a difference going from Valero 93 to V Power even in my Harley it literally picks up power and throttle response when using V power because of its additives
As mentioned, there is/are better cleaners out there, especially with what the dealership offers, but I have had good luck with seafoam. I ran 2 cans through (not back to back) and it cleared up my injectors. The dealer agreed that afterwards the flow as within spec. Worth a try for the cost.
Head a da Family
Whatever you do, STAY AWAY from the no name brands like Delta. They sell surplus gas that has nothing added.
Never knew of that website. Good to know about the off-brands too. I always stay away from them, more from what I have heard through the grapevine though. Nice to see some data behind the reasoning.
dave steady jr.....
i have the OTC tool to hook into fuel line and use compressed air. problem is i'm not sure how to connect to my 2005 mdx. the fuel lines look like quick connects no fitting that i see in OTC manual...
do you know what i need to connect it to mdx?
joflewbyu2
08-18-2019 10:38 PM
joflewbyu2
10-08-2015 11:16 AM
