Finally had real time to work on my baby
Old 03-11-2018, 12:45 PM
Guner721's Avatar
What do you guys think?
I got my 2004 acura tl with manual transmission in January but have not been able to work on it because i am currently lacking funds i plan on raising it since it is difficult to drive since the tire scraping and am looking into getting a new bumper and side skirt any suggestions or comments should i raise it back to stock?
Old 03-11-2018, 03:23 PM
Wdp_3g's Avatar
There are not very many options for bumpers and side skirts except the type s, a spec, ron Jon, and the versus bumper like listed in you other thread but since you have low funds your only options may be type s or just get the side skirt your are missing because the a spec is around 900. I saw in your other thread you were looking for some websites so some good ones for aftermarket parts are EndLessRPM and Heeltoe
Guner721 (03-11-2018)
Old 03-11-2018, 03:26 PM
Wdp_3g's Avatar
Some cheap cosmetic mods you could do are clean your headlights with sandpaper or a kit, an sti front lip $50 and a roof spoiler from endless rpm for around 100 shipped
Old 03-11-2018, 04:11 PM
Q('.')=O
imj0257's Avatar
uh
Old 03-11-2018, 04:15 PM
Guner721's Avatar
Originally Posted by imj0257
uh
good or bad?
Old 03-11-2018, 05:13 PM
Wdp_3g's Avatar
good or bad?
i think he means how I said sandpaper on headlights it’s not like it sounds you sans it down with really high grit then spray clear coat here’s the video
Old 03-13-2018, 12:10 PM
Received 8,568 Likes on 6,621 Posts
i think your suspension is broken
t-rd (03-27-2018)
Old 03-13-2018, 12:15 PM
Received 16,260 Likes on 11,971 Posts
good or bad?
uh, as in that car has seen a rough fucking life.
Old 03-13-2018, 12:29 PM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
Geez, yet another ruined 3G TL 6MT; makes the value of mine a bit higher.
Old 03-13-2018, 12:49 PM
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
It's a little rough. Nighttime pictures are not good either.
Old 03-13-2018, 02:01 PM
losiglow's Avatar
What's with the wheels? Are they recessed? Usually you see spacers to extend the stance but that guy went the other way I guess he had to do that to lower it that much but it looks :ghey:. Get that fixed right away.
Old 03-18-2018, 09:49 AM
igloo's Avatar
Saw the mustache, where's the sideburns? :gheyfight:
Old 03-18-2018, 08:17 PM
Guner721's Avatar
So far i raised it about half a inch but i feel it still needs some more room
Old 03-18-2018, 08:18 PM
Guner721's Avatar
yea i know my friend is letting me borrow his camera should have some good pictures once the clips for the sideskirt come in
Old 03-18-2018, 08:19 PM
Guner721's Avatar
sticker had been on there since i got the car but with the recent rain in so cal it came off
Old 03-18-2018, 08:22 PM
Guner721's Avatar
looking to get new rims too because he painted them himself and he didnt do too good a job either. But until i can afford some good ones should i sand them down and paint them black? I already ordered black tint for my lights
Old 03-18-2018, 08:29 PM
Wdp_3g's Avatar
if ou think they look bad and black would look better go for it but if ou want to get a good deal on some wheels check your local Craigslist there might be some cheap a few months ago I got a pretty much new set of Konig wheels on some toyo tires for 250
Old 03-18-2018, 09:05 PM
Guner721's Avatar
true but im trying to save up to either get it repainted or get it wrapped
Old 03-19-2018, 01:35 PM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
save for some new driveshafts
Old 03-27-2018, 10:58 AM
5th Gear
dave-four's Avatar
Think I can live with everything except the hood risers. Thought they were exclusive to the Civic boy-racers, and that's only when the engine's swapped and the extra room is needed.
Old 03-27-2018, 12:05 PM
losiglow's Avatar
Yeah, most definitely get rid of those. I don't mind the wheels. It's just that they're recessed - e.g.- closer inwards to the body that they should be. I'm not even sure how that's accomplished. The car needs to be raised a bit and the wheels extended back to stock. It seems to me like he recessed them in order to achieve the drop without rolling the fenders.
Old 03-27-2018, 12:09 PM
Guner721's Avatar
actually the engine is not stock the guy rebuilt it and added raiser to a part of the engine so because of that the hood also needed a raiser im not a big fan of how it looks and might do an engine swap back to original i already have one since my dad had bough one for his tl but the problem ended up being fixed with a motor mount
Old 03-27-2018, 12:42 PM
5th Gear
dave-four's Avatar
Was about to say holy shit why, but I'm guessing for oil pan clearance due to it being slammed? Or is it a J35 block with the 32 top end?
Old 03-28-2018, 10:22 AM
An engine raiser huh..
You sure it wasn't just an Intake manifold spacer or something?
Old 03-28-2018, 10:52 AM
Majofo's Avatar
You're mad confused
The guy probably has an MDX manifold spacer
Replace the spacer with a OE manifold spacer
You need to remove the intake manifold
Make sure you're easy on all the fasteners and re-fasten to spec and in order according to the FSM
No need to do an "engine swap"
I have no idea what a motor mount and your dad's TL have in common
You confused breh
Old 03-28-2018, 10:53 AM
Majofo's Avatar
I must admit that the engine is pretty damn clean
Guy really did love his ride
Probably some stains on the seats
Reggo shit
Old 03-28-2018, 10:54 AM
Majofo's Avatar
Top off your radiator and coolant res
Make sure the cap isn't cracked and tube is still attached
Old 03-28-2018, 11:31 AM
losiglow's Avatar
Looks pretty nice to me.
But 3.2 VTEC panel from a 2G TL
Yeah, I'd remove the intake manifold spacer then lower the hood back down.
Old 03-30-2018, 08:44 PM
GhostTL09's Avatar
Dude I don't know how people gave you straight answers after looking at those pictures and seeing a mustache. I'm absolutely done. The hood is raised and the wheels are sunken in lmao hahaha.
Please restore to previous glory!
Old 04-04-2018, 07:11 PM
B16Power's Avatar
Not my style but to each their own.
Old 04-05-2018, 07:36 AM
Pair of TLs's Avatar
A hood scoop would be lit, eh?
Old 04-05-2018, 10:51 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,651 Likes on 1,116 Posts
Ummmmmmmmmmmmm.
Old 04-05-2018, 10:53 AM
Latent car nut
horseshoez's Avatar
Every time this thread pops up I think, "Please somebody, shoot that car and put it out of its misery"; it would be the merciful thing to do.
Old 04-05-2018, 01:26 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
lol definitely a intake manifold spacer
Old 04-09-2018, 12:51 AM
Guner721's Avatar
After waiting on the clips to reattach the sideskirt i had time to put it together along with raising the car so its not such a pain in the ass to drive. I still have alot i want to do for cosmetics but that will have to wait for a few months when i can afford the mods. For now im going to try and focus on lowering the hood back to stock and fixing the small mechanical problems it has.oh i also restored the headlights like someone had suggested they didnt come out the best but im also waiting on headlight tint which i feel will halp hide the imperfections from my restoration.
Old 04-09-2018, 06:17 AM
Jakes_tl's Avatar
What is the point of raising the back of the hood like that?
Old 04-09-2018, 06:23 AM
teh CL's Avatar
Intake manifold spacer probably.
Old 04-09-2018, 09:47 AM
Guner721's Avatar
Originally Posted by Majofo
You're mad confused
You confused breh
this is why i made this so that i can have people tell me what i have wrong, correct me and help when they can because ive always worked on cars with my dad but just the bare minimum so this car is also a learning process for me.
Old 04-09-2018, 09:52 AM
Keeping all updates in one thread
:merge:
Old 04-09-2018, 10:15 AM
Majofo's Avatar
This is a great place to learn, a lot of knowledgeable members
Welcome!
Quick Reply: Finally had real time to work on my baby
