electrical buzz just as door opened?
Old 03-03-2004, 08:17 PM
TimC's Avatar
Question electrical buzz just as door opened?
Has anyone noticed or heard a slight and quick electrical sounding buzz when the driver's door is first opened after unlocking? I hear this sound momentarily just before the beep sound in the memory seat setting when "driver 1" detected, and return to the set position. I do not think it is the mirror motor, and I hear it before the seat motors engage. Thanks
Old 03-03-2004, 08:22 PM
vtechbrain's Avatar
Well I thoght it was the mirror or seat motor but you ruled those out. The only things that move are the seat and the mirror.
Old 03-03-2004, 08:29 PM
TimC's Avatar
thanks. the sound is pretty quick. in my 01 TL, I would occasionally notice a simailar sound just as the power door lock motors acuated
Old 03-03-2004, 10:07 PM
daikon38's Avatar
headlights?
it could be the headlight shield moving into position?
Old 03-03-2004, 10:32 PM
bdowell's Avatar
I heard this same noise in my S2000, I know exactly what you are talking about but do not have a clue what it is. Fuel pump is my only guess?
Old 03-04-2004, 06:03 AM
TimC's Avatar
Thanks for the input. Sounds like the car is getting ready for something. I did not know there was a shield on the headlights. tell me about it. The fule pump is another good explanation. Probably shold not be concerned. If something breaks, I'll know it
Old 03-04-2004, 06:14 AM
Cesspool of Knowledge
żGotJazz?'s Avatar
It's a solenoid that covers part of the headlight output when the beams are in the "low" position. This is the default "power off" position.
I think you can test to see if this is your "mystery sound" by turning off the car while leaving the high beams on, and then letting the headlight auto-off feature turn off the beams. The solonoid should release when the auto-off turns off the headlights. When you turn the car on again, the high beams will turn on, which will also turn on the solonoid (and maybe reproduce your sound). This will be more of a "pop" noise, though.
Marcelechka
Home & Garden
188
09-11-2022 11:53 AM
mlody
12-04-2019 02:11 PM
gatrhumpy
19
12-31-2015 04:22 PM
chiu0nthls
3G MDX (2014-2020)
09-28-2015 03:46 AM
Quick Reply: electrical buzz just as door opened?
