E-85 gas
ethanol is just alcohol made from corn and other grains.
gasoline is what probably damages paint and I think it happens over time....like if you constantly spill gasoline on paint, then the clear coat will eventually get damaged and cloudy....which then could eat away at the color paint..
E85 is more corrosive than gasoline that's why Flex Fuel cars was implemented. I'm not sure how much more corrosive E85 is than gasoline but E85 will eat paint faster than gasoline. Just keep that in mind when you spill E85 on paint.
justnspace (06-15-2017)
Everything I've read says E85 is not much more corrosive than gas. You'd probably have to have repeated, prolonged exposure of your paint to E85 to cause permanent damage.
But E85 shouldn't be anywhere near your 3G TL!!
justnspace (06-16-2017)
Flex fuel was implemented because E85 is more corrosive than gasoline...?
The Flex Fuel cars are basically the same car with its twin non flex fuel car with the exception of the upgraded fuel system to handle E85. Flex Fuel cars can use both E85 and standard gasoline. Non flex fuel cas are not authorized to use E85. End of story.
Latent car nut
Received 2,005 Likes
Many (most, all?) Flex Fuel engines also have higher flow rate fuel injectors to enable the richer mixture necessary when running E-85.
Higher fuel pressure is not a game changer. There are plenty of high performance engines using higher fuel pressures on standard gasoline without issues.
Latent car nut
You cannot have higher flow rate without higher pressure. Likewise, there are plenty of engines running high flow rates that are still not authorized to use E85.
You cannot just increase the fuel volume and use E85 without issues in the long term.
It's the fuel E85 that's more corrosive than standard gasoline is the game changer.
Latent car nut
Not necessarily, only if the pressure is high enough to compensate for the larger orifice size.
Latent car nut
Okay, now this discussion is just getting silly. Modern fuel injection systems run a regulated pressure; the pump is more than capable of compensating for the higher flow rate injectors. That said, many manufacturers also specify a different fuel pump, although whether that is because of the corrosive nature of E-85 or the need for higher flow from the pump, or both, I haven't done enough research to say which manufacturers do which. Long story short, the pressure in modern fuel injection systems remains stable regardless of whether the engine is idling or running at WOT up near redline.
HowStuffWorks
Latent car nut
And your point is?
Latent car nut
I think that has been well established; I ask again, what's your point?
Latent car nut
Latent car nut
Time to give it up, we all know E-85 is corrosive, and we all know that the fuel systems, fuel pump, lines, injectors, and other components are somewhat different between two otherwise identical cars, one FlexFuel and one not.
Following thread creep, sent further astray by your posts with (initially) incomplete and misleading information.
Latent car nut
Ahhh, I see you're a legend in your own mind. I'm done here.
mada51589
4G TL Problems & Fixes
11-25-2016 08:08 AM
