Notices
Third Generation TL (2004-2008)
Codes popping up
Old 07-12-2019, 12:01 PM
Registered Member
Exclamation Codes popping up
having some code pop up on dash was wondering if anyone has seen them before b1007 10, b1008 10, b1010 10, b1006 10, b1005 10, b1011 10, b1144 30, b1225 51, b1233 51, b1235 51, b1843 95, would anyone know what codes these are 08 tl types
KingLouie is offline
Old 07-12-2019, 12:05 PM
Received 5,925 Likes on 4,754 Posts
when multiple codes pop up like this, you should check the battery. low voltage on a battery throws some obscure codes on the computer.
thoiboi is offline
Old 07-12-2019, 12:18 PM
Registered Member
just put in a new battery and my radio and nav are not working as well. what could this be
Old 07-13-2019, 09:14 PM
Registered Member
Jackass's Avatar
Bad battery (yes I know you just swapped it), bad cables, bad clamps, bad alternator....it could be lots of things. Go back and get the battery and alternator tested. Check that the battery clamps and cables are clean and solid.
Jackass is offline
Nicknackzz13
08-03-2018 11:04 AM
woowoo
05-23-2011 10:03 PM
synth19
Second Generation RL (2005-2012)
02-06-2011 10:49 AM
RKeatF1
Second Generation CL Discussion (2000-2003)
11-20-2007 06:56 AM
Chauncey
Second Generation TL (1999-2003)
05-31-2005 07:58 PM
Quick Reply: Codes popping up
