Clutch fluid change
Old 06-11-2019, 06:17 PM
Imadreamer's Avatar
Clutch fluid change
I ordered some brake fluid to replace old clutch fluid. Can you just empty reservoir and refill without bleeding system? I don’t want to get air in system since I’m not familiar with it.
Old 06-11-2019, 06:18 PM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
you can't run it dry without bleeding the system.
Old 06-11-2019, 06:56 PM
Acura TL Builder's Avatar
Just suck our most of what in the reservoir, drive a few city miles. Repeat 1/2 times more and you have changed the the fluidmentirely.
Just don’t suck out all the fluid at once or it may introduce bubbles.
Old 06-11-2019, 07:01 PM
Imadreamer's Avatar
Good input that’s what I’m going to do now. I believe you can do the brake fluid the same. I got gm fluids on the way for transmission change too. Thanks!!
Old 06-11-2019, 11:29 PM
Brake fluid and power steering fluid.
Old 06-12-2019, 07:51 AM
BROlando's Avatar
Received 1,163 Likes on 874 Posts
If you suck the fluid out and then go for a drive, you will now have air in the system.
I would suck all the fluid out. Then do a 1 man bleed with an old bottle and a piece of vacuum hose.
Watch some youtube vids on this. Its easy.
Old 06-12-2019, 08:06 AM
You don’t suck it All out.
You replace what you sucked out Before driving.
Old 06-12-2019, 09:35 AM
truonghthe's Avatar
just gravity bleed the system by running a silicone tubbing, let the gravity do all of the works.
BTW here what mine looks like lmao.
Old 06-12-2019, 09:45 AM
Imadreamer's Avatar
How many miles was that?
Old 06-12-2019, 09:46 AM
Imadreamer's Avatar
Ok I’ll check it out
Old 06-12-2019, 09:51 AM
truonghthe's Avatar
142k miles on the clock when that picture was taken.
Old 06-12-2019, 09:52 AM
Imadreamer's Avatar
I meant how many miles since last fluid change?
Old 06-12-2019, 11:00 AM
truonghthe's Avatar
142k miles, the fluid never got replace before.... this is the beauty of buying car with 3+ owners who refuse to put money toward maintaining lol. I am paying for it now
Old 06-12-2019, 11:21 AM
Imadreamer's Avatar
Lol ok I got ya! That’s like me I got to make sure I do a pm on it so I know it’s been done and ready to go.
Old 06-12-2019, 08:06 PM
truonghthe's Avatar
hell my mechanic half joke "you got the cleanest clutch fluid in town" we end up bleeding it twice.
Old 06-12-2019, 08:37 PM
Imadreamer's Avatar
Yep try to keep everything new as possible.
Old 06-14-2019, 09:25 PM
Imadreamer's Avatar
I just finished changing trans fluid and what a difference it made!!! 3rd gear like butter now! Old fluid was clear as water and stunk up garage lol.Chaned oil Mobil synthetic and reset oil life also. Wandering how Acura set up their oil life if it was for mileage or how you drive it? With synthetic should I go through an extra oil cycle???
Old 06-15-2019, 12:46 PM
BROlando's Avatar
What kind of M1 synthetic did you put in the trans?
Generally, synthetic MOTOR oil isn't a good idea for a transmission.
Old 06-15-2019, 06:05 PM
Imadreamer's Avatar
Synthetic was put in motor and transmission fluid was ac delco white bottle $20 a quart
Old 06-15-2019, 09:22 PM
Imadreamer's Avatar
Cleaned it up today . 5.5 hrs!!😓
Gumby309 (06-18-2019)
Old 06-18-2019, 12:09 PM
truonghthe's Avatar
AC Delco synchro FM makes a day and night difference in shifting lol, even my mechanic admit the Honda MTF wouldn't make the 6 spd shifting smooth as the FM.
kixo
08-15-2015 08:32 PM
chunky
05-04-2015 06:50 AM
dljohn
11-04-2012 11:24 AM
zax123
07-13-2011 11:26 PM
thelastaspec
06-13-2011 12:59 AM
Quick Reply: Clutch fluid change
