Change transmission fluid in a type-S
LUV MY 2007 CBP TLS
Hi guys, been reading a lot of threads regarding changing the transmission oil on the TL 5AT, but what about the Type S...i know it has a whole different transmission (like the RL ) than the base TL so when do i have to do the fluid change on it, do i wait for the MID to tell me or is there a mileage i should do it at...
thanks for your help
change the fluid every 20-30k miles. some people like to wait longer to change the fluid and sometimes never because of our weak trannys. A trannsmission can become used to the old fluid in it and by changing it make cause a tranny to fail ( I dont believe it ). Honda doesnt recommend a tranny flush and i dont either for this particular car. Just do the good old 3x3 also do a search in this forum and you will find good stuff.
A 3x3 every 30k miles is still a very good idea for the 3G TL.
WOT in the new ATLP V2s!
One guy at the dealer told me every 15-20k and another tells me a service light comes on at 100k! I'm at 39k and want to do this asap, I do mixed driving highway vs city traffic. The dealer also quoted me $105 for a drain & refill! I think I go do it myself or get it done cheaper elsewhere.
LUV MY 2007 CBP TLS
That's the problem you can't get a straight answer form the dealer, one tells you wait for the light the other tells you do it every 20K, it's annoying
VERY! I'm nervous about it cuz my trans went out on a 2nd gen at 95k, less than 5k under the certified coverage. I think I'm just gonna get it done soon but trying not to pay the dealer $105k. Every other shop gives me weak shitty answers like "we use an all purpose oil, works perfect in very car"...hell no.
LUV MY 2007 CBP TLS
i would then buy the oil from the dealer and do it myself in that case...seems to not be that hard but do we need to do the 3 x 3 like the the 3.2or just a flush and refill?
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
I flush 3 quarts and fill up with 3 fresh new quarts of honda z1 every 25K in my girls 06 TL. A 3 X 3 is overkill, just pull the drain plug for the tranny next time u change your oil and put the plug back on and then refill 3 new quarts and you will be fine!
im hitting 55k miles and plan on changing mines next month also, any recommended ATF people are using? hear about mobil 1 ATF which is fully sythetic and amsoil ATF also or should stick with regular honda z1? thank!!
I just went to dealership and the service manager told me the trans fluid should be changed every 30 thousand miles. I dont know if this is a pitch but I'm getting mine done. Cheap money if it saves a transmission.
Yeah but they make tons of $$$ giving you wrong info & getting people to service their cars there. You can do a drain & refill yourself, that is what is recommended about every 30k depending on your driving style & amount of stop & go traffic. The flush should only be done by a professional & I've been reading its not as recommended as we used to think. The dealer wanted to charge me $105 for a drain & refill yet the 3 quarts of trans fluid are only $8.95 at the same dealer...I'm gonna do it myself, its as simple as an oil change.
i dont know if the dealership duz the 3x3 fill and drain process, it would be best if you did it yourself. I think they only drain 3 quarts and put three fresh quarts in. i doubt they even touch the transmission filter
If you check the owner's manual you will see that the ATF replacement is determined by the MID; unless you drive in stop and go or mountainous driving. If you are in the mountains or stop and go you change at 60K and then every 30K.
What I found interesting was "replacement" is just a single drain and fill; not the 3x3.
BTW, the ATF filter can only be accessed as part of a transmission overhaul so no dealer is going to do anything with the filter.
Yes it is. I bought my TL-S with 46k on it and I thought the trans shifted hard so I took it to the stealer to have them look at it. They said it was fine but I had them do a fluid change. I'm sure it was just the 1x3. It cost me 40 bucks but didn't change anything. Car still shifts hard and has lag. I'll just beat on the trans till it dies and then get a new one.
My Garage not
1 Post
i've done the 3x3 before. now i just do a 1x3 every time i change my oil. i might be wasting money on fluid but i don't trust the tranny all that much.
LUV MY 2007 CBP TLS
Hey Izzy thanks for the update, still didn't do mine, its winter here (can't do it myself) so i guess i will have it done on my next oil change
No problem...hopefully your oil guys can do it, thats what I thought too and the guys at the oil place I go to either didn't feel like doing it with 30 minutes left to closing or the Acura parts are hard to get at as they said. They recommended a shady, runned down trans place down the street...so of course I ended up having the dealer do it. It does feel pretty good, I was not liking my shifting during take off...I did not drive aggressively on the way home but might push it a little more this weekend.
I was a newbie once too.
Youre probably gonna get flamed for resurrecting and old thread and me for replying but just trying to help out
3x3 means you drain the tranny oil put in new oil and do it 3 times same day.
so drain oil put in new oil run through gears, drain oil, put in new oil run through gears, drain oil put in new oil.
1x3 means you drain the current tranny oil and put in new oil and do it 3 times but once every month.
i hope im right
i hope im right
Goose,
Thanks for helping me out. Not sure why we'd get flamed. I would guess it's better to respond to an old thread than start a whole new one.
Seems to me that either method is a bit excessive. Why not just drain it then replace it and be done?
Because when you drain it, you only get the amount of fluid that is not locked up in the trans, so about three quarts. Doing a 3x3 replaces a good portion of the fluid, but still not all of it.
