Notices
Third Generation TL (2004-2008)
Buying 2005 tl advice
Old 03-30-2019, 06:46 AM
New Member
Liked 0 Times in 0 Posts
Thinking about buying a 2005 tl with no navigation for 8k.It only had 1 previous owner, excellent service history and has 73k miles. The exterior has no scratches/dent/peeling. Interior seats has no rips, only thing wrong is the entire dashboard is cracked. Good deal or no ?
819_eg is offline
Old 03-30-2019, 05:29 PM
dj5
Registered Member
Liked 14 Times in 13 Posts
$8k is not a good deal for a 05 auto TL especially with a cracked dash. Good deal would be around $4-5k. You can get a auto 08 TL-S for $8-9k.
dj5 is offline
Old 03-31-2019, 04:28 AM
WTF?
Midnight Mystery's Avatar
Liked 247 Times in 221 Posts
This would usually run about $7K where I am. It's surely a nice car, but it does have a slight amount of wear.
Get it down to $6K or less then you're doing pretty well!
Midnight Mystery is offline
Old 03-31-2019, 09:04 AM
Registered Member
horseshoez's Avatar
Liked 808 Times in 602 Posts
I agree with the others, $8,000 is nearly double what you should pay for a fourteen year old car with a cracked dash and a problematic automatic transmission.
horseshoez is offline
Old 03-31-2019, 01:37 PM
Registered Member
Liked 9 Times in 8 Posts
5k max. IMO
jaydubz is online now
Old 03-31-2019, 04:46 PM
csmeance's Avatar
Liked 1,017 Times in 710 Posts
If it's got good tires, the compliance bushings are not torn or have been replaced, timing belt/water pump done within the last 2-3 years, good brakes and A/C you can go as high as $6000.
BUT, if it's got any of those wrong the price starts falling! Timing belt should be done every 7-10 yrs/105K miles since rubber ages and the belt can snap ruining your engine for the small amount of $1000.00. Tires can easily be $500. A/C can easily be $500. Brakes can easily be $500. Compliance bushings + Labor is at least $250.
csmeance is offline
Old 03-31-2019, 10:28 PM
Registered Member
PhilB81's Avatar
Liked 13 Times in 10 Posts
pretty low miles considering age, but I agree with everyone that posted above me.
Also, can someone remind me which years the Auto transmissions were more reliable 06 and up?
thanks
PhilB81 is offline
Old 03-31-2019, 11:09 PM
WTF?
thanks
2004 is complete garbage.
2005 is barely tolerable.
2006 aren't that bad.
2007-2008 are pretty much bulletproof!
Old 04-01-2019, 04:13 AM
Registered Member
horseshoez's Avatar
I've never seen any evidence to suggest the 2006 automatic transmission is any more reliable than the 2004; that and unless I'm missing something, they have the exact same engineering build and manufacturing code.
Old 04-01-2019, 04:23 AM
WTF?
Something about how the lubrication jets work, from what I hear.
I can't say for sure and horseshoez is probably right, but word around here is that the 2006 transmission is more reliable than the 2004. Car Complaints also supports this claim, but I'm unaware as to the reliability of the source of the information provided.
Either way, I'd sleep a little better having an 06 AT vs an 04 AT...
Papa smerf
20
12-13-2013 03:12 AM
SilasW
09-15-2013 09:31 PM
wajo22
21
08-09-2012 08:46 PM
sunilvarma
First Generation TSX Discussion (2004-2008)
07-13-2010 08:32 PM
Memout
Second Generation TL (1999-2003)
15
07-24-2001 12:33 PM
Quick Reply: Buying 2005 tl advice
