Bad valve adjustment or need fuel system cleaning?
https://drive.google.com/open?id=1Rj...wiCSPBGbTveoPL
Hello,
(Link to video above)
I took my car in for a valve adjustment to my local mechanic a week ago, and I can't tell if the job was done correctly or not. Little back story, my car pulled up a CEL with misfire codes and I was advised it needed a Valve adjustment and a fuel cleaning by a local honda dealership. I didn't want to pay the honda price so I took it to a mechanic who normally works on my vehicle. he said he could do the VA in a day so I booked the service. On the day of service I received call stating that the VA was going to be another day. The mechanic advised me they were having trouble setting the valves to spec (due to buildup?), and might have to leave them a little loose which would cause a ticking sound. he also stated they will try and get the CEL removed. a bit nervous now, I agreed and let them keep the car another day. on the next day the car was ready and the mechanic advised me that they adjusted the valves to the proper spec and removed the CEL. so i'm happy with the news I pick up my car and on the ride out the car starts stalling on every turn. took it back and was told my throttle body was dirty and needed to be cleaned. they cleaned it and I went on my way. car drives fine by i'm worried because I hear a ticking and whining noise now. i'll attach a video when I can, this form does not take MP4s. My first question is regarding to the video i'll post soon... does this engine sound right? and my next question is should I get a fuel system cleaning? My car has also been taking longer to start and when I kill the engine it does not sound as clean as it use to. 150k miles 6-speed 2004 acura tl. any input is apreaciated. Thanks!
Hello,
Upload to youtube.
That sounds like it might be the idler pulley or tensioner for your drive belt..
Bwahahaha!! What a load of crap.
What, you couldn't afford $300 for a Honda shop to do it?
And IMO, unless your engine had more than 150K without a VA, it's a waist of time and money...
Blown engine?
Does this sound like a blown engine? Sounds like knocking but hoping it's something that can be fixed ? Bad video but you can hear a fast knocking sound around 2000 rpm
@RysTL04 i merged your posts because they are likely related..
JTC05
3G MDX (2014-2020)
15
02-01-2017 04:25 PM
Acurian24
1G RDX Problems & Fixes
08-14-2016 09:18 PM
danny_isr
11-26-2007 09:01 PM
