Best oil for '07 TL Type S
You can go beyond that but I prefer to keep it at 5k.
A lot of people hate on Fram filters but I think they're ok. I guess...
They're usually cheaper than other brands though.
There are literally dozens of threads on this subject, ranging from scientific to opinionated.
A vast amount of knowledge is contained within them. That is why:
"SEARCH" IS YOUR FRIEND
Amsoil is the only oil that is ever inside anything I own with a motor. With the use of their filters you can safely have extended oil change intervals which saves you money and helps the environment. Please don't take my word for it do your own research. There is no better oil.
amsoil is the only oil that is ever inside anything i own with a motor. With the use of their filters you can safely have extended oil change intervals which saves you money and helps the environment. Please don't take my word for it do your own research. There is no better oil.
Amsoil is an extremely trusted name in the oil business, so if they say 25K, they have the evidence to back it up.
Most of us are unwilling to take the risk, so we just use the standard length changes.
I'm sure we will hear more on this in the near future.
The 25,000 mile oil change is for normal conditions whatever that is. For extreme conditions which is what most of us drive in it is 15,000 or one year. I get to 15k before one year with my TL so I change it then. It is important to use thier Eao filters if your going to do extended oil drains. No problems for me and I have been using it for years!
One of the mods, I can't remember which one, is acting as a guinea pig on this one. He is running extended length, and sending in the oil for sampling.
Do you think the quality of the oil and the performance it gives is well worth the premium paid on their products? I've read somewhere to use EAO 20, but that's not on Amsoil's recommended list of oil filters on their site...
Yes, I would use their EAO 13 (I think that's what is recommended on Amsoil's site for TLs). That's pretty awesome to skip every other routine oil change.
If you abide by the extended length change, then you didn't spend any more money. You saved money
Do to matching the flow of the filter with your Acura, I wouldn't recommend a different filter.
Hahaha! You're right! Thanks for all the help and info!
i think soo highly of mobil 1, that i put the dirty(5kmiles) oil in my lawnmower and if the wifes car is low i put some in there too...how bad could it be...
i think the bottom line, is this is all subjective, and as long as you follow drain intervals that meet the manufactures recommendations, you should be fine...
Amazon prime for free shipping or make 3 orders (6 filters) for free shipping.
[QUOTE=vinnier6;11924735]i think soo highly of mobil 1, that i put the dirty(5kmiles) oil in my lawnmower and if the wifes car is low i put some in there too...how bad could it be...
QUOTE]
I like that idea! When I first bought my John Deere 42" lawn tractor three years ago, I changed out the oil very early with filter in the hope that the mower would last. I actually did that twice way before the suggested hours.
Only did I realize that the POS was really an MTD with green paint.
It uses nearly 1/2 quart of oil every 1 1/2 hours of cutting time.
Instead of giving it the best care, I could have been using my old oil, as it surely wouldn't have made any difference......as there probably aren't any rings to be found in the engine!
QUOTE]
Seriously, there have been some pretty in-depth studies on this forum that included cutting several filters in half, and the OEM is not a high quality filter.
Since you are using Amsoil anyway, switch to the Ea Absolute filter.
You'll be glad you did
Alert
I just went to place an order with Amsoil, and the Ea013 is not available WTF!
I called tech service, and they said something happened just today, but don't know what, to cause them to discontinue that particular filter.
They are supposed to e-mail me an update when they figure out what is going on.......and I will pass it on.
I have started another thread on the topic of the Amsoil Ea013 being discontinued.
It was found by the factory to have reached its capacity before the 25,000 mile mark.
It is discontinued, and no longer available. Amsoil recommends the WIX filter as replacement.
