Battery Tender install
peter6 (09-11-2018)
Did you clean up that ground bolt before installing it? If it's painted underneath, it won't make very good ground.
I had enough length of wire I could've ran it to where the negative battery cable mounts to the inner fender. I didn't feel like taking the battery out to get access to the bolt. The threaded hole and bolt are not painted, so I just installed it as you see. The battery tender charges the battery with no problems.
Waddy
Dating & Relationships
74
11-24-2004 03:43 PM
