Base '07 AT 45k miles or Type S '07 AT 80k miles?
Hey Everyone! I've been a lurker here on and off and decided to join AcuraZine since I might soon be able to own my first 3G TL.
I'm hoping to get some advice and opinions regarding two privately owned TLs i've narrowed my search down to. Estimated price is in parentheses.
07 Base CGP AT 45k miles (~$12.5k - $13.5k)
- dashboard has lots of cracks on passenger side and some above the steering wheel
- steering wheel has cover on since it looks like the wheel is worn out
- hydraulic hood lifts do not work in holding hood open
- Car otherwise drives well and everything else seems to work (AC/electronics/ebony seats are in good condition, etc...)
- did not run carfax yet
07 Type S CBP AT 80k miles (~$14k - ~$15k)
- two 6-10in. cracks on passenger side
- rear spoiler paint is worn out or damaged but isn't bad
- rear bumper has scratch on bad looking they backed into something but is minor
- clean carfax
- tires, motor mounts, windshield (crack), and AC clutch replaced recently
- taupe interior in good shape
- car drives well and looks like it was taken care of
Both are in overall good shape other than what was listed above, but will have an Acura mechanic do an inspection before buying. I drive about 6k miles per year.
Sorry, having trouble posting pics.
Should I worry about the 80k on Type S? Which car is the better value and is there anything I should watch out for?
Thanks in advance and looking forward to learning more about 3G TLs!
- clean carfax
Regarding the S, the two 6-10" cracks...where are they? Also on the dash?
80k on a TL is nothing.
But I personally would not buy a TL with a cracked dash.
If I were in the market for a 3G today, I would get the Type-S.
The following 2 users liked this post by ggesq:
justnspace (12-11-2014),
LS5 (12-12-2014)
holy shit, that's a close one!
both are pretty similar in price and condition(from what I can read)
it's gonna be a tough decision because its so close.
would you rather save a few grand to buy the Base TL?
or spend a few grand to get the type-s?
personally, with condition of cars being similar, i'd get the type-s all day.
the type-s is the latest and greatest iteration and has a few extra features than the base.
granted; both cars are in great working condition.
if the type-s was displaying some kind of abuse, I wouldnt touch it.
So, basically its up to you to investigate which car you want.
Registered Bunny
- clean carfax
- clean carfax
Hydraulic lifts to prop the hood don't work (wtf?) and the owner didn't replace them even though it's a cheap part? Tells you about what kind of owner that person was. It's one thing to not change a flaky reverse light bulb, but the hood struts take 5 minutes at best to change.
I would worry more about the base one than the Type-S one. People owning the Type-S seem to pamper their car a bit more, or at least in this case it seems true. Can't vouch for these people going a bit hard on the car sometimes though.
LS5 (12-12-2014)
Neither. Pass on both
I picked up my base 04 with 16k miles for around $13k and not one flaw on the car. It was brand new. Maybe the lowest mileage TL on this board.
I'd pass on both. A cracked dash will always look shitty. I can't believe they're asking that much for cars in neglected condition. Worn out paint on the type a spoiler? How does that happen?
You also don't know what kind if damage is behind the bumper. Just because the outside looks ok, doesn't mean behind is the same case. I remember seeing a Porsche with "minor" cosmetic damage to the rear bumper and one of the exhaust pipes. Didn't look bad at all. Until the shop dismantled it and ended up needing 5 times the original expected price in repairs.
I'd hate to have to look at a cracked dash every day. It's the one thing you stare at every time your in the car. Plus, that's no good for resale. It'll probably just get worse over time. You can replace it, but it requires a bunch of work and money.
The following 2 users liked this post by TacoBello:
LS5 (12-12-2014)
Newer member here... I am lucky enough to currently have a base '07 in Silver Metallic and an '08 Type S in Nighthawk Black Pearl. Go for the Type S, hands down. But not this one - keep looking and find one in better shape. In my experience no matter where you are they pop up all over, all the time. And further advice, go with either the Silver or the Carbon Bronze on the Type S. The paint on either of those two colors just holds up so much better. The paint on my base '07 is flawless... but sunny day here today in Cincinnati and doing all I can to avoid looking directly at the paint on my Type S!!
The following 2 users liked this post by wil5on0701:
LS5 (12-12-2014)
worn out paint on spoiler is pretty common on some of the TL's. I've seen it on a couple alrdy. its weird because its just the spoiler part, but trunk is fine. and yes, 100% original factory paint in all cases
LS5 (12-12-2014)
I bought an '07 TL-S earlier this year at 75K miles and bought with no worries. But this winter I'll be doing a t/belt job along with a suspension refresh, so keep in mind maintenance that will need to be done over the next 20K miles. I believe the manual calls for t/belt at 100K or so miles, but I like to play it safe.
As far as the two cars you've listed, I would pass on the base model. Seems like it wasn't well taken care of. The TL-S seems OK based on what you've posted as long as you're willing to deal with the dash cracks. If it were me, I'd keep looking. But as far as reliability is concerned, the TL-S is a solid car at its core.
it's strange the base has all those issues with low miles
mine has 58K now, and has none of those issues...
definitely get a car fax on that one...
Received 6,470 Likes
Take the Type S.
If the dash crack at that mileage I would stay away from both car.
Slot Machine Lubricator
OP if it makes you feel better my car has 131k miles now and the only major problem it had was a bad starter, which is premature for the miles.
I just changed my compliance bushings two days ago and all they had were some minuscule cracks.
These cars have been pretty reliable, granted every manufacturer is going to make a Dud once in a while.
LS5 (12-12-2014)
Thanks so much to everyone for their replies and valuable opinions!
Sorry it's been busy and I didn't have time to post a reply.
ggesp - yes, the two cracks are on the passenger side dashboard of the Type S
TL-GIXXER - there was actually an '06 AT ASM with ~20-25k low miles selling for about $13k but I wanted to stick with '07-'08 models
wil5son0701 - Thanks for the insight as an owner of both models!
1black_seven - nice to see your car still running strong and that it's relatively problem free
Will review the Type S condition especially with the cracks on the dashboard before making a decision at $14k. I'm still keeping an eye out for new sales.
Zonian22
11-14-2015 01:20 PM
handsom-hustla
11-13-2015 05:04 PM
Zonian22
09-02-2015 08:19 AM
