B&M Transmission cooler
I’m having trouble finding the right inlet and outlet hoses that I can tap into with my transmission cooler. Does anyone know which hoses are best for this application? Please and thank you
Acura TL Builder (08-12-2018)
Right or wrong, here's what I did. my cooler came with about 2.5ft of 3/8" hose. I connected it to the cooler in a loop, placed the cooler where I wanted it and fed the loop through the bulkhead. I found the spot in the loop to cut so that both lines would reach without kinking and made the cut. I removed the original line that linked the two pipes shown connected with new hose, reused the hose clamps and installed in no particular order (just adding in series with factory cooler, flow direction doesn't matter). here's how it looks directly below where the battery normally sits.
SilverBullet_RENAMED
2G CL Frequently Asked Questions
66
10-03-2011 07:52 PM
tommyt1777
2G CL Transmission Recall Q & A
12-25-2009 08:38 AM
tommyt1777
12-06-2009 08:02 AM
shinybluecls
10-02-2007 08:01 AM
08-12-2002 06:09 PM
