Notices
Third Generation TL (2004-2008)
AV6 2007 Accord Trans on 2005 Acura TL
Old 03-29-2018, 10:40 PM
New Member
Hi guys,
My trans is on its way out on my 2005 Acura TL
I know how bad the automatic Acura TL transmissions are so i went out and started researching the best option.
After doing heavy research on this forum and others, I learned that an AV6 2006-2007 Accord Trans Non-Hybrid is the best choice
and it will fit the Acura TL.
The AV6 swap involves swapping in a transmission from an Accord V6. This transmission has the exact same gear ratios as the TL Type-S and is virtually a direct bolt on replacement, with some parts that need to be swapped.
In general, Honda 3-shaft 5 speed transmissions are interchangeable. Since Honda made some changes that greatly improved the reliability after 2005, what most people are doing is replacing their 2nd gen TL transmission with a unit sourced from a 2006 or 2007 Honda Accord V6 (non-hybrid).
Source: https://havenergarage.blogspot.com/2...ra-tl-av6.html
Most of the information that i've found is basically for 2nd Gen Acura TL's
There's not too much detailed info for a Accord AV6 trans swap on 3rd Gen TL (although some had said that it will work)
This saturday, I will be swapping a 2007 Accord V6 Automatic transmission w/ 91,000 Miles in a 2005 Acura TL (Automatic)
If anyone has done this before on a 2005 Acura TL or has any knowledge of what i should look out for, PLEASE COMMENT!
Some say yes it will work and some say no it wont fully function, if you've done this and its been working for you i'd like to hear from you.
b1aze360 is offline
Old 03-29-2018, 11:27 PM
Registered Member
guitarplayer16's Avatar
Received 2,236 Likes on 1,657 Posts
Straight swap but you need to use the TL position range switch
guitarplayer16 is offline
b1aze360 (03-30-2018)
Old 03-30-2018, 11:57 AM
New Member
Have you done it? or know someone that has on an 05?
b1aze360 is offline
Old 03-30-2018, 01:23 PM
Registered Member
Jackass's Avatar
There have been multiple threads talking about this in the past month or two. Pretty sure in those threads there are links to the bigger thread that has all of the AV6 transmission swap details in it.
Using Google: site:acurazine.com/forums/third av6 transmission
https://acurazine.com/forums/third-g.../#post13952475
MODS: Can we find or create something in the garage about this? Seems to be coming up in the forums more often and searching for a conclusive answer isn't exactly the easiest. The majority of us who have been around for a while know it off the top of our heads, but someone new will not easily stumble across the correct threads.
Jackass is offline
EvilVirus (11-01-2018)
Old 10-31-2018, 02:43 PM
New Member
Originally Posted by b1aze360 View Post
Hi guys,
I am planning on doing this also. Was it a straightforward swap? My 05 TL transmission is not taking high or reverse.
geocap is offline
Old 10-31-2018, 03:20 PM
Received 5,846 Likes on 4,687 Posts
Ill work on it
thoiboi is offline
The following 2 users liked this post by thoiboi:
EvilVirus (11-01-2018), Jackass (11-01-2018)
Old 01-03-2019, 03:56 PM
New Member
is the converter straight bolt on or do I need to get one from an TL?
geocap is offline
Old 03-01-2019, 09:02 AM
Registered Member
Finished 07 BAYA AV6 into 06 TL
I used 2007 Accord V6 5sp auto with the sticker on the front with the BAYA label and put it in a 2006 Acura TL. I used the converter that was with the AV6. Now, my TL did have this metal shim on the converter and I did move it over, and of course I replaced the o-ring on it as well.
My other notes:
If you are going to replace the rear main seal, youíll need to either get the special seal driver (recommended in the FSM), remove the rear block plate, or go to the hardware store and make a one time use seal driver. Not a single seal driver set you can rent at the part stores has one big enough.
The harness and sensor (position range switch). I changed the harness. So far the sensor hasnít been an issue and the connectors on both ends look the same, but I figured better safe then sorry.
I did replace the axle seals just to be safe.
Everything alse bolts up.
TacoTom1967 is offline
horseshoez (03-01-2019)
Secreta Manny
Second Generation TL (1999-2003)
15
03-02-2019 09:40 AM
shawn.m
08-13-2016 09:50 AM
SatinSilverAV6
Racing & Competition
10-09-2010 10:03 PM
JUBIE
01-08-2006 11:38 PM
Quick Reply: AV6 2007 Accord Trans on 2005 Acura TL
