Anyone knows how to take off the driver's side air vent?
Old 02-06-2006, 12:03 AM
not vtech... VTEC!!!
kennyc's Avatar
I got some rattle I need to get rid of.
Old 02-06-2006, 12:27 AM
CTS-V Import Slayer
MichaelBenz's Avatar
PM me your email address and I will send you help.
Old 02-06-2006, 12:37 AM
kennyc's Avatar
PM sent! Thanks!
Old 02-06-2006, 07:16 AM
Registered User
rbf351's Avatar
all you need to do is pull it, and it pops out
Old 02-06-2006, 07:35 AM
kennyc's Avatar
hmm... I'll try that. thanks!
Old 02-07-2006, 08:33 PM
Kandyman's Avatar
Please post what you find and how you fix it. I too have a rattle in the drivers air vent (and I suspect the front passenger vent also).
Old 02-07-2006, 08:38 PM
kennyc's Avatar
I "fixed" it this afternoon. I'll do some road testing and post my result in couple of days.
Old 02-07-2006, 09:34 PM
whatjones911's Avatar
Do you really just pull it out??
Old 02-07-2006, 09:35 PM
JustinZ's Avatar
just wiggle and pull the corner out
prolly the easiest thing to remove in the whole car
Old 02-07-2006, 09:37 PM
kennyc's Avatar
yup! very easy.
Old 02-07-2006, 10:02 PM
Ok thanks guys. By the way, anyone know how to take out the front center vents? I have a rattle there too.
Old 02-07-2006, 10:25 PM
Administrator
Ron A's Avatar
Received 1,001 Likes on 572 Posts
Here's a scan that should help.
Old 02-07-2006, 10:40 PM
Thanks Ron A!
kennyc's Avatar
Very helpful Ron. Thanks!
Old 06-03-2014, 05:31 PM
smb123's Avatar
Wink Integra 1999 GSR with Moonroof DS air vent removal
I found out that, in order to remove the driver's side air vent, if the car has a moonroof, you have to first remove the roof switch because there is a screw behind it.
1) So, you need to first remove the knee panel by removing two screws at the bottom and another in the coin tray. I needed to remove the coin tray to get at the screw but someone with younger eyes could probably do it without.
2) Once you get the knee panel off, you can get to the tang that holds the switch in place. There is a slot underneath the switch. You can use a flathead to depress the tang (it is toward the front of the slot. Then you need to release the connector to the moon roof switch. That also takes a bit of work with a fine flathead.
3) Once the switch is out, the screw is clearly visible and easy to remove.
4) then, with a gentle tug, the air vent comes out very easily.
Old 06-03-2014, 07:11 PM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
good info man, very useful here on the TL forum...
02-25-2020 09:57 AM
jblessing
08-08-2018 09:43 PM
acura_dipset_tl
01-01-2016 03:02 PM
PortlandRL
09-14-2015 12:01 PM
08 NBP TL
09-08-2015 08:49 PM
Quick Reply: Anyone knows how to take off the driver's side air vent?
