Another Lower Grill Variation (Modification)
Dr. Feelgood
Hi, ALL!
This is what I did to my lower grill. Let me know what you think!!!!
Peace !!!! No comments on the car's cleaniness....it rained and I had no time to wash it but I had time to put the mesh on the grill.
Dr. Feelgood
sorry guys, here is a smaller image
Silky Smooth
That looks great... I would do that same thing, and I would definently do it in black mesh. How much were all the parts, and how hard was the installation? The slit across looks great, please fill us all in, alot of people are going to want to do this...
That does look good.
I put all the pictures in the first post and deleted the second one so it's easier to see everything.
If you could tell all these guys how you did it, that would be great.
Audio Enthusiast
Originally Posted by 05TLTony
Hi, ALL!
Dr. Feelgood
Thanks for the great feedback guys. Believe it or not, it is the original grill on our cars right now. All I did was dremel out all the horizontal bars and left the big middle one alone. I then cut the grill to fit the existing platic molding and JB Welded it onto the frame. Before I welded it with the epoxy, I kept it in place with 20 inch galvinized wiring found at Home depot. Just let it sit for about 1/2 to 1 hour to cure. (FYI, the grill frame is very thin so to make things easier, place epoxy on the messh and the frame to get a strong bond. If you put the epoxy on the rim of the grill and put the mesh over it, you will not get a tight hold. Don't worry about putting too much epoxy in the back side of the grill frame because you will not see it once installed.)
The middle chrome part is Doge chrome door molding I bought at C.A.P.
Also, wear protective eye wear and gloves. The mesh is very sharpe. I use gutter or tin snips to cut the mesh.
Dr. Feelgood
Originally Posted by NFLblitze1
do you think you can do a write-up DIY with pictures?
Dr. Feelgood
NFLblitz1,
I am thinking of doing the upper grill as well. When I do so, I will definitely take pictures and do a write up. I won't be for another week or so. I hope you can wait.
Youse Gots Sacked
i hope i can wait, its just ive been thinking about putting mesh in the lower grills for awhile but i wasn't so sure how it would look based on pictures ive seen on the forums...but this is just a great idea and it looks so good...and it seems feasible to do
Dr. Feelgood
Oh, the cost for every thing was
$2.39 for the chrome
$1.98 for the galvinized wire
$4.95 for the JB Weld
$5.95 for the gutter guard (mesh) only used 2 of the 6 pieces
alot of cutting
alot of cutting
Team Nighthawk member
The mesh looks great!! I've been thinking of doing it as well, however, I've heard that mesh can disrupt airflow to the intake. Is this true?
Dr. Feelgood
how long would u say the whole modification took you?
Dr. Feelgood
Dr. Feelgood
Originally Posted by XjoEnX
hey tony where did you buy the mesh grill? u said they come in 6 pieces?
Oderint dum metuant.
Those do look good! And they just put a Home Depot 5 minutes from the house...might have to check this one out...got WDP so I'd have to paint mine black first.
Great job on the install...very clean and professional looking...keep us posted on the upper grille.
