Acura TL Type-S 6MT physical Top speed
TL 6MT (Final Drive: 3.285)
Gear/ Gear Ratio/ Redline mph
1 ------ 3.933 -------- 39.7
2 ------ 2.478 -------- 62.9
3 ------ 1.700 -------- 91.7
4 ------ 1.250 -------- 124.8
5 ------ 0.975 -------- 160.0
6 ------ 0.770 -------- 202.6
TL Auto (Final Drive: 4.428)
1 ------ 2.563 -------- 45.1
2 ------ 1.552 -------- 74.6
3 ------ 1.021 -------- 113.3
4 ------ 0.666 -------- 173.7
5 ------ 0.480 -------- 241.1
The following 3 users liked this post by csmeance:
Latent car nut
Received 2,005 Likes
Even with a supercharger, ain't no way a TL is ever going to see anywhere near 200 mph unless you drive it off a HUGE cliff.
Latent car nut
I guess we'll need to watch the old Charlie Sheen movie Terminal Velocity to find out.
FGbG-Tech CyberModz3D (08-14-2020)
The inconvenient truth
Even at 149mph @5100rpm in sixth gear it still has a lot more left but the fuel pump cutout will prevent anything >150mph.
Latent car nut
While there may well be some pedal left, my bet is if you somehow defeated the speed governor there is little chance of a 3G Type-S getting above 165 on flat ground with no wind.
Hondata allows you to remove the speed governor.
Wing, splitter, and those little aerodynamic bits on the lateral sides of the front bumper should keep it stable at high speeds.
In congruency with a damper system, wheels and tires.
Latent car nut
Regardless, still won't get a 3G TL anywhere near 200 mph.
I really doubt a rotrex kit will ever make 1k hp. Itd probably be pretty hard to reach 700whp with a blower. Youre gonna need a turbo and a ton of money to modify the block and internals. But Good luck if that's your goal
@Saving4aTL Be the change you want to see in the world.
200mph 3G TL can't be done? Well not with that attitude you can't!
GO GET IT!
GO GET IT!
The following 2 users liked this post by nist7:
Acura TL Builder (06-25-2019),
GO GET IT!
GO GET IT!
The following 2 users liked this post by Acura TL Builder:
FGbG-Tech CyberModz3D (08-14-2020),
nist7 (04-01-2019)
Wanax
3G RDX (2019+)
03-01-2019 12:53 PM
