Acura TL 3G (2004-2008) CV Axle Replacement
Hi everyone,
Does anyone know the difference between a
2004-2006 Acura TL Drive Shaft Assembly Left Driver side (44306-SDD-A00)
and
2007-2008 Acura TL Drive Shaft Assembly Left Driver side (44306-SEP-A10)
Are they essentially the same part? If not, what is the difference between them? I am trying to replace my driver side cv axle and was able to find a cheap oem 2005 acura tl driver left cv axle that I want to use to replace my driver left cv axle on my 2008 acura tl. Thank you.
and
They have different transmissions between the 04-06 and the 07-08 so the axles are going to be different as well..
Latent car nut
Received 2,005 Likes
Just one data point here, I put new DuraLast axles on my TL in May and I cannot recommend them. I'll be yanking them in favor of a set of new OEM axles in a few months.
some time I buy aftermarket parts but Axle and steering rack and pinion isn't on that list, I strictly use OEM or OEM supplier if possible.
Latent car nut
I do as well, however, a fellow AZ member had a set of brand new DuraLast axles he was selling for $100. I took the gamble the Duralast units would work well; I lost that gamble.
Not much on AZ Duralast produts, but $500 for a couple OEM half-shafts pretty steep price. I'd buy a couple from RockAuto for $100 (lifetime warranty) and keep the present units for backups in case you need to return the new units for any reason.
Head a da Family
https://www.rockauto.com/en/moreinfo...429130&jsn=327
Rockauto has different brands at different times. Haven't had a problem.
Go be the guinea pig and report back!
Latent car nut
The Duralast axles have a lifetime warranty as well. The fact is, I want smooth axles, and if $500 will do the job, then it is a bargain.
Johnny2003TL-S
06-11-2013 08:38 PM
johnny911
11-18-2011 10:06 PM
