ACURA TL 2004 manual 6 speed transmission fluid
So I recently bought this car and I do not know what type of transmission fluid to use. Some people have recommend me Penzoil synchromesh, others have told me to use any 10w20 oil, which should i use ?
[MODERATOR NOTE] - Thread moved to model-specific forum.
-------Tim-------
https://acurazine.com/forums/3g-tl-p...grades-972494/
From the people who own the 6MT......
Cliff Notes: ACDelco Synchromesh Friction Modified
Latent car nut
Received 2,005 Likes
As has been stated, use ACDelco Synchromesh Friction Modified; if anybody tells you different, they don't know what the hell they are talking about.
Or you can use Acura's newer MTF which is very similar to the GM Synchromesh Friction modified! The old acura MTF isn't very good and causes a lot of 3rd gear problems!
Latent car nut
Not sure what you mean by Acura's newer MTF; when I bought my car in May of 2017 it had just had a fluid change with "Honda Genuine HG" Manual Transmission Fluid "Advanced Protection New and improved formula for Honda vehicles". The thing is, as soon as that MTF warmed up, the third gear grind/pop-out issue would be very much in evidence. As soon as I put in ACDelco Synchromesh Friction Modified, the problem went away. I've driven over 30,000 miles since I made the switch, and the problem hasn't resurfaced even once.
On my 05 TL I have over 30k on my Honda MTF with the car at 208k No grinds, pops or anything else with this trans. Shifting rpms doesnt matter either. Just sharing my experience with my car.
Latent car nut
jbird1974
1G NSX (1990-2005)
06-28-2014 02:20 PM
TimTim
03-08-2010 06:02 PM
ernesto1924
12-22-2009 08:15 PM
idkjai
08-12-2009 11:16 PM
