Accidentally put in 93 octane...
So naturally I'm getting crappy gas mileage.
I was just wondering if its possible to "balance it out" (I'm at half a tank of 93) by adding a half tank of 89 octane.....resulting in an average of 91?
Or is this the worst idea of all time?
Thanks either way,
Thanks either way,
Are you serious? Lol I thought that 91 was manufacturers spec....and the engine's compression ratio is optimized for 91. I definitely get better gas mileage with 91...I guess I never really thought about it past that
acura recommends anything 91 and above...
I've run 87 octane for over 167K miles, no issues
put water in the tank, its will balance thing out automatically.
Higher octane fuels just resist knock/pre detonation better. 91...93, close enough.
Some states/areas have 91 as the highest available standard pump gas octane. Other places get 93.
I'm sure the car runs fine on anything 87 to 100ish+ octane.
Wow. Just wow. I mean ignorance is bliss my friend and I am jealous honestly of the blissful life you must lead. You will be fine. Dont even sweat it, these cars will take any gas from what ive seen.
Engines rated for 87, however, don't know how to use higher octane and it would be a waste of money putting in a higher octane (unless your engine is knocking).
strange indeed lol
Latent car nut
Received 2,005 Likes
If you're getting crappy gas mileage it has nothing to do with the 93 AKI (do not confuse the U.S. AKI rating with "octane) fuel you put in your car. FWIW, the fuel where I live is 87 AKI, 89 AKI, and 93 AKI; I only use 93 and today after a few days of driving my nephew around to see some sights here in New Hamster, I filled up; my average speed was 50 mph (probably 70% highway, 30% urban), I drove 428.4 miles on 14.263 gallons which works out to just over 30 mpg. Not exactly what I would call crappy gas mileage.
Latent car nut
Latent car nut
That plus a likely reduction in fuel economy and I highly doubt running regular will result in any savings at all.
A forty-five cent delta between regular and premium? Yikes, don't know where y'all live but around here the delta between 87 and 93 is only twenty cents.
Latent car nut
Agreed on the "yet another octane thread". I'm thinking it might make sense to lock this one as the OP has already had his answer covered several times.
I've run 87 octane for over 167K miles and it hasn't affected MPG at all. And any thought that VTEC works better is just that, a thought. I recorded multiple WOT runs to near redline on Torque Pro and didn't register any timing pull whatsoever on 87 vs 91 octane.
And yeah, the delta is $0.45 - $0.55 up here.
Latent car nut
Granted I've never put a J32 on a dyno, but when I was with Mercedes we put lots of the (then new) 3.2 liter V6 motors for the (then newish) W210 E-Class on dynos and ran them with different fuels; there was always a noticeable reduction in power in the mid to top RPM ranges and a reduction on BSFC (which has a direct correlation to fuel economy) across the board when lower octane fuel was used.
I've never put a J32 on a dyno either, but if timing isn't being pulled throughout the entire power band, then no power is being lost. And for 167K+ miles on 87 octane, I still get 30 MPG on the highway.
Latent car nut
So what you're saying is you don't really know, you're just guessing.
If timing isn't being pulled and MPGs are the same, how would any power be lost?
Latent car nut
You have absolutely zero way of knowing whether timing is pulled or not; when an engine is running at WOT, there is a very conservative fuel map being run which is very-very rich. Long story short, it doesn't surprise me you saw no difference at WOT.
Oh, but I do. OBDII data doesn't lie...
So you're admitting that there's no difference in timing whether running 87 or 91 at WOT? Got it, thanks for confirming my results
And like I said, if timing isn't being pulled, then there's no loss in power. And it's backed up by no change in MPG for 167K miles...
I think we are missing the point of the OP's post. He says, "Accidentally put in 93 octane... So naturally I'm getting crappy gas mileage." Running the car on a higher octane gas shouldn't result in "crappy gas mileage". Something else must be going on here.
This thread cant be serious, worried about putting in 93 octane. It seems the cheaper gas gets around here the bigger the divide between 87 and 91. 93 is outrageous at the stations that have it, I settle for 91 and I get pinging at that.
Clickbait OP.. same as his "catastrophic cup holder failure"
Latent car nut
You will not convince him horseshoe. This debate has been going on for the last 12 years. Never mind the fact that he lives in N. Dakota where I imagine he doesn't have high temps beyond 80 degrees and does mostly highway driving.
Ive used 87 twice since new and 231k miles later on my 05 and both times driving in this FloriDUH heat I experienced decreased MPG and loss of performance.
The following 3 users liked this post by ggesq:
Latent car nut
Hey, I just wanted people to respond haha...
Either way, thanks to everyone else from getting me up to speed. I ended up just burning the entire tank and it evened out to 25mpg average (on the trip computer, at least) while the previous weekend I hit a 30mpg average on my way to Chicago w/91....though most of my recent driving was highway as well.
Sorry for causing another argument lol
Hmmm, not sure where you got North Dakota from; per my profile I live in New Hampshire. Granted this summer has been wonderfully temperate in that we've only had maybe a dozen or so days over 90°F, that said I've also lived on SoCal, Texas, Georgia, and Virginia, so I know well the effects heat can bring.
The following 3 users liked this post by WheelMcCoy:
As for price difference it is pretty standard now in PA that it is X for 87, X+20 for 89, and X+50 for 92-93. Or even more sometimes, especially at top tier stations.
I remember when I was first driving and gas was 1.99 for regular for longest time and it was always 10c more for mid and another 20c more for premium and just about everybody had pricing within a few cents. Nowadays they change pricing all of the freakin time and the pricing is always different lol even within franchises a few miles apart.
iWhine S/C 6MT TL
