AC compressor not turning on - looking for insights
Old 04-22-2019, 12:01 PM
skierz's Avatar
Hello gurus. My ‘04 TL with 178k miles did not blow any cold air the first time i turned on the AC the other day ( after not turning it on all winter). I also noticed that the click / faint ‘woosh’ sound doesn’t happen when i push the AC button on. Does that mean the compressor needs to be replaced or does the compressor cut off / not activate if the Freon is super low / empty. Obviously hoping for the latter as a compressor replacement seems costly. The fan blows just fine. Thank you!
Old 04-22-2019, 01:26 PM
Nytetime6's Avatar
It could be low on freon or the clutch is bad.
Old 04-22-2019, 02:32 PM
skierz's Avatar
. Thank you for reply. Would love freon cause the compressor to not turn on?
Old 04-23-2019, 02:16 AM
Iggy's Avatar
Yes. There's a low pressure switch in the system which disables the compressor if system pressure is too low.
Old 04-23-2019, 10:22 AM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
As mentioned, the culprits may include low freon, bad compressor clutch, bad AC associated relays, or bad pressure switch.
You can jump the clutch relay to check the compressor clutch.
Old 05-19-2019, 10:04 AM
thegrinch911's Avatar
Following this so far. My compressor clutch seems to engage and so the relay is fine. But there is no cold air. I checked the coolant level and the refill bottle goes to red and tells me consult a technician. I can tell the compressor engages because of an increase in RPM when AC is turned on. Any ideas here? Thanks!
Old 05-19-2019, 03:15 PM
Turbonut's Avatar
Should see what the pressures are before trying to add refrigerant. Heater control valve working properly/off so as no hot water
into the heater core?
Old 05-20-2019, 07:46 AM
Talking
How do you check the heater control valve?
Old 05-20-2019, 09:12 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
if pressures are in the red you may have a clogged a/c line or debris caught in the evap/condensor or txv valve...
tsx504
1G TSX Problems & Fixes
03-16-2015 10:22 PM
poisx7
01-21-2011 01:23 AM
wjk
06-03-2006 01:36 PM
DerrickM
04-20-2005 01:05 AM
chadr
10-06-2003 01:27 PM
Quick Reply: AC compressor not turning on - looking for insights
