Go Back  AcuraZine - Acura Enthusiast Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008)
Reload this Page >
Is the 6MT Slave Cylinder Delay Valve Delete Harmful?
Notices
Old 06-29-2019, 12:04 PM
Registered Member
Hello everyone. I'm a college student who has had a 6MT 3G TL for quite some time. I love the car but holy crap I feel like a newb every time I shift from 1st to 2nd. My other shifts are usually okay, but 1st to 2nd is always bumpy. The only way I ever get it to shift smoothly is if I baby it when I disengage the clutch, but then that ends up making me drive super slowly haha.
I'm seeing that there is a valve that delays engagement of the clutch, and I'm interested in removing it. However, I found this thread on a Civic forum (link attached) where a user wrote that
"You guys do realize that this valve keeps the pressure from blowing the seals over time in upstream part of the system right? It's there to control the pressure feedback when the pressure plate springs release. With it out there is a pulse of high pressure back into the system that puts a lot of extra pressure on the clutch master cyl seals. This valve controls that flow to even out the upstream pressure. Honda puts it there for a reason. This lil trick has been around for a while and I have personally replaced failed parts because of it. It's not like the engineers at Honda put extra crap in there just to hinder performance on the car. If this was a reliable way to run the system i'm sure they wouldn't have included it. By doing this mod you will prob see premature seal failure and will prob end up sitting on the side of the road when the seals fail and the clutch won't engage. Just some food for thought."
I had no idea this was the case. Have any of you experienced bad effects of the delay valve delete? Any advice?
JesseX is offline
Old 06-29-2019, 01:42 PM
Received 14,119 Likes on 10,496 Posts
i've had my car for 9 years with the delay valve deleted for about 7 or 8 years.
my master cylinder is working just fine
justnspace is online now
Old 06-29-2019, 01:45 PM
in Feb 2020, i'll have had my car for 10 years!
The following 2 users liked this post by justnspace:
Saving4aTL (06-30-2019), WDPanda (07-02-2019)
Old 06-29-2019, 02:01 PM
Registered Member
horseshoez's Avatar
My CDV was only done a year ago; from a mechanical perspective, unless you are constantly banging gears and popping the clutch, then there will be no adverse issues with the CDV.
horseshoez is offline
Old 06-29-2019, 02:12 PM
Registered Member
That's good to hear. So removing it is definitely worth it?
Is it hard to remove the slave cylinder? I've never worked on my car and my dad told me it's a difficult operation.
JesseX is offline
Old 06-29-2019, 02:21 PM
Registered Member
srg818's Avatar
Attempting to make those perfect shifts with the valve in place makes it more difficult while putting more wear on your clutch and drivetrain than if you had just removed that valve and had a more predictable friction point in the clutch travel. I've had mine removed over a year with no problems. Don't go banging through gears like it's stolen.
srg818 is offline
Old 06-29-2019, 04:20 PM
One on the right for me
subinf's Avatar
One of the best thing I've done to the car. Probably 200k on the clutch since it was done.
subinf is offline
Old 06-29-2019, 05:25 PM
Slot Machine Lubricator
1black_seven's Avatar
Delete the check valve and get it re-tuned. Hondata will improve the feel of the shifts.
Not having the check valve can put extra shock through the transmission but its not going to kill it. I VTEC every day and have not had an issue.
1black_seven is offline
Old 06-29-2019, 06:39 PM
Registered Member
sockr1's Avatar
I’ve had mine out for probably 6-7 years and no issues at all. Still on original clutch too 126k miles
sockr1 is offline
Old 06-29-2019, 08:59 PM
Rev High; Drive Happy
o4Komodo's Avatar
Whoa! Youíre still around with the TL? Siiick. Is the TL still constantly on jacks? 😂
o4Komodo is offline
justnspace (06-30-2019)
Old 06-29-2019, 09:01 PM
o4Komodo's Avatar
KTuned has these slave master cylinder delete mods but none specifically for the J (not the last time I checked anyway). So Iím confident itís not that big of an issue to worry about unlit as youíre REALLY rough and/or really bad at shifting.
o4Komodo is offline
Old 06-29-2019, 09:04 PM
Registered Member
Thank you for all your comments. It's really good to hear that you all have no trouble.
Does anyone have a master source for removing the slave cylinder? I've been searching for guides and youtube videos but I'm finding that all of these sources are leaving out details like tools. The job is intimidating me but I don't have the cash to get a mechanic to do it haha.
JesseX is offline
Old 06-29-2019, 09:22 PM
Registered Member
sockr1's Avatar
It’s a straight shot in the engine bay I think it’s two bolts
sockr1 is offline
Old 06-30-2019, 06:07 AM
i figured out the trick; if i dont mod it, it wont break!
I havent touched it in the last few years , meaning i'm done modding!
Old 06-30-2019, 06:08 AM
Originally Posted by sockr1 View Post
Itís a straight shot in the engine bay I think itís two bolts
will also need a second hand for bleeding the clutch. unless one can devise a device to hold the clutch fork, like a short block of wood
Old 06-30-2019, 10:28 AM
Rotrex + Comptech TLer
Saving4aTL's Avatar
There is a guide to removing the Check Valve on this obscure thread.
https://acurazine.com/forums/3g-tl-p...harger-965385/
Saving4aTL is online now
Old 06-30-2019, 01:25 PM
Saving4aTL's Avatar
Only thing harmful about the CVD is loosing races knowing you could have otherwise won.
looser move.
Old 06-30-2019, 06:36 PM
Registered Member
truonghthe's Avatar
Received 1,009 Likes on 868 Posts
The only effect you will see on CVD is the motor mount will get torn earlier (like the OEM one lasted anyway).
truonghthe is offline
Old 07-01-2019, 04:43 PM
Registered Bike Offender
Vlad_Type_S's Avatar
Can confirm. Had mine deleted for several years now (idk, like 5?). Just changed the clutch fluid a few weeks ago - no leaks anywhere or any other issues. Just don't dump the clutch to prevent excess hydraulic pressure and large, sudden loads on engine mounts. Shifts are more predictable (note: they aren't easier, necessarily, just more predictable). This mod doesn't cure bad driving. If anything, it will punish your mistakes more severely. BUT at least something that has a predictable feel is capable of being learned.
Vlad_Type_S is offline
Old 07-01-2019, 05:25 PM
Registered Member
sockr1's Avatar
did you do a full bleed or just replace the fluid in the reservoir...debating doing mine as well
sockr1 is offline
Old 07-01-2019, 06:04 PM
Saving4aTL's Avatar
Replace the reservoir fluid twice and it’s no different?
Old 07-02-2019, 12:55 PM
Registered Member
truonghthe's Avatar
I had the mechanic at the dealer flush the entire system not one but twice, we half joke "you got the cleanest clutch fluid in town". The pedal feels definitely better, oh to top that off he also re adjust the pedal point of engagement, the pedal feels good now.
Back to the question of CVD.
Stock form - you will eat motor mounts
bolt on with sticky tires - engine mounts and axle will paying for it.
mods with sticky tires, upgrade axle, motor mounts along with stage 3 clutch - your 2nd/ 3rd gear will living in borrow time.
sockr1 (07-02-2019)
Old 07-02-2019, 05:25 PM
Full bleed. I just bleed the slave, while topping off the reservoir, until the fluid runs clear. I think I used about half a bottle to get it all the way through.
sockr1 (07-02-2019)
Old 07-02-2019, 11:02 PM
Registered Member
WDPanda's Avatar
CDV delete is a must. And learning not to drop your clutch wrong. One time I did a vacuum bleed no problem. 2nd time i had a problem. Now I will only do the 2 person bleed for the clutch.
WDPanda is offline
horseshoez
56
08-22-2018 04:55 PM
Skier4lyfe303
24
09-04-2016 09:28 PM
Matthewyu
07-15-2012 06:22 PM
bigg_86
01-25-2012 01:57 PM
Ron A
07-30-2008 07:17 PM
Quick Reply: Is the 6MT Slave Cylinder Delay Valve Delete Harmful?
