Yayy for VALVE ADJUSTMENT (PICTURES INSIDE)
iWhine S/C 6MT TL
My car has been making a tapping noise from the top end. I did my 1st adjustment a month ago and was rushing through it and made the noise worse.. Geez thanks..
I decided today was the day to take my time and go through with it again. Adjusting valves is all about feel, it's something you have to do over and over again to get it correct. This time around I finished in 5 hours. 1st time was about 7 hours and in which 3 1/2 of them were just sitting around talking and not really working. It's not hard it just takes time. So here it is.. For anyone wanting to do this well this will provide you with an idea on what's involved.
Oh boy here we go
Tool and proceedure ready
Here we go
Point of no return
Time to line up my 1st cylinder of the day
Adjusting time
BTW the pictures don't show it but I had the lower intake ports covered and for which ever head I wasn't working on at that moment was also covered. Coolant bypass hoses under the TB were closed off other wise they would spill lots of coolant.
Oh boy here we go
Here we go
Point of no return
Adjusting time
iWhine S/C 6MT TL
It's not really, just takes a lot of time. It's harder to do the back head because of it's location.. But other than that it's a learning curve.
nice writeup.. and you're absolutely right about having to feel it out. I've done probably 50+ valve adjustments when I was a tech and everytime I would do it twice just to be sure.
Its not hard at all, just takes time and some care. and the appropriate feeler gauges
btw, i love the wheel combo on wdp, looks badass
04WDPSeDaN, thanks for the nice photo documentation. I've wondered how hard it was to get the jewelry off to adjust the valves. Do you recall if the adjustment nuts were 10 or 12 mm? I have access to a valve adjustment tool for 10mm jam nuts.
Adjusting those back ones looks like a pain...
I have close to 90k miles and could really use a valve adjustment. Still debating if I want to do it myself or just let the dealer take care of it on the 105k mile tune-up.
iWhine S/C 6MT TL
The problem I have is still there at this point I have to run other tests like vtec rocker test and see why I still get a ticking noise at idle.. Stay tuned there shall be more pictures in the up coming days.
shamal (12-14-2014)
iWhine S/C 6MT TL
This noise is pretty loud when cold and as it's warm the noise gets quiet and sometimes goes away for a few seconds then comes back then goes away then back then away.. I am getting close to giving up on this..
iWhine S/C 6MT TL
UPDATE:
Problem found. I have 2 intake rockers stuck on vtec. This seems to be a very strange and common issuse.. So common that the intake rocker shaft is on back order... Go figure..
So each Vtec rocker is 150 x 6
and each intake rocker shaft is 56 x 2
You get the idea... This really sucks.
Interesting, I didn't know the TL used a roller valvetrain...
How many miles are on this engine?
iWhine S/C 6MT TL
For myself I only plan on replacing only the intake/vtec rockers with intake rocker shafts. I would be saving 500 or so because I am not touching the exhaust rockers with shafts. I shall have pictures today if they are still suck on vtec...
BTW I have the thank my boss for helping me through my recent problems and including this one. Not to many people would really care.
Ak Ting Up
So, How do you know if you need a valve adjustment ?
My engine runs silky smooth and no ticking what so ever (137K). What are the indications that your valves are out of adjustment ?
53k right now... What gets me is I rarely drive this car hard and take high priority in maintance and going the extra step but this is totally unacceptable. Between all intake/exhaust rockers and the shafts they sit on plus valve covers gaskets your looking at $1600 in parts alone...
it's me, Alan Rickman.
Yeah soo... how does one do a vtec test? I've read somewhere that Honda's generally require valve adjustments every so often.. when do we know it's time ?
seems to be the trend...the more you hit vtec...the more you tick
iWhine S/C 6MT TL
i am very calm with my car. Hit vtec maybe once every 2 weeks.. I barely take it that high.. besides gas is going up up up
iWhine S/C 6MT TL
Vtec test is simple... As you go to adjust cylinder number 1 it's already put in Top dead center. While there before adjusting anything you should be able to push the middle rocker down without problems. If it doesn't move by itself but rather with the 2 other rockers then you sir have a bad intake/vtec rocker. With my luck the intake rocker shafts are on back order for 3 months... GJ acura anyone want to buy my POS car?
It will make a nice tick tick tick tick then go away once fully warmed up..
Sorry for all the questions, but what oil have you been running? Were both failed rockers on the same head?
iWhine S/C 6MT TL
Castrol edge 5-30 for the past 2k with o.e filter
one rocker failure for each head.
Performance wise yes I notice more gain to be honest. Power band felt like a rubber band. Weird to explain but This is my car and I noticed this noise when it was very quiet. Over time it got louder and I got concern. As of now I have my car put back together because I am not waiting 3 months for parts while my car is taken apart.
BTW i picked up this car at 24k, the guy who owned this before me didn't take much care of it. he drove this car from NJ To FL a few times so I'm sure he must have raced a few guys and down shifted hard into another gear it would only make sense.
Cookie N Cream TL
1 Post
hello 04wdpsedan, i wanted to ask is the valve adjusement under warranty if u have extended warranty because the dealer told me it isnt becuase its maintence and the dealer told me i would need 2 adjust my vavles and im having a lil ticking sound but its not that loud if everything is off and you can hear a lil bit but you said something about an intake what is that about? i drive alot and i have a fujita cai, you think something got into my intake?
7th Gear
the only time i hear a ticking noise from my engine is when im in a drivethrew and im right next to the wall with my window down, would this be the same ticking noise that yall are talking about?
Registered but harmless
Received 1,102 Likes
Ticking sounds from valve train while at idle, which increase w/rpm, or slight loss of acceleration/sluggish acceleration.
Valve adjustments are maintenance, as valves can get out of adjustment over time. OP is referring to adjusting the intake and exhaust valves, not the cold air intake.
A ticking noise can come from different places for different reasons (heat shield, idler/tensioner, valves). For the valves, the ticking noise would come from the top of the engine at idle. Open the hood and see if the ticking is from along the top of the motor.
iWhine S/C 6MT TL
iWhine S/C 6MT TL
To Will Y. Thank you for your awesome replies! You are right about everything.
If I can grab a camera to record this I will. Valve noise will be heard when you open your hood and hear it from that VTEC cover. TICK TICK TICK, the noise will get faster as you hit the gas from idle to 1,500-2,000. As your car fully warms up the noise will change to either GONE or very faint and will go away and come back but will always be faint. If this isn't the case and the noise is always there you might have a different problem and (a) or a (Few) rockers are completely bad.
acura says `check if it needs a valve adjustment` at 100k miles!
that would mean do a valve adjustment- the ones out of spec needed adjustment
A reasonable person does it.. and the water pump-timing belt job, sooner than 105
Many of the same parts have to be removed, so save time or money
Check owner book maitenance -Severe Service -and see if you qualify
As for the car with bad shafts- call acura at 1-800-382-2238x5
The phone person cant help you,, but will write a compaint file and a real acura manager will call you back.
Simple Valve adjustment is NOT warranty item
BUT
Parts that have failed at approx 50k miles should be GOODWILL WARRANTY- where corp can allow anything it wants
Your engine should not have this problem- `common` or not!!
Thats in the same league as a trans failure 1k after warranty= acura can step up
Back in the day, they didnt step up for gen2 and lost a class action- now gen2 has a 7yr 109kmile trans warranty
gen3 should look into the valvetrain problem more,, and get some relief from acura
If no one reports a problem to corp- they dont know about it
BUT
iWhine S/C 6MT TL
BUT
BUT
BUT
BUT
iWhine S/C 6MT TL
UPDATE:
I contacted Acura Corporation, they told me to send my car to Acura and let them figure out the problem so that they can discuss on a warranty claim.
It's been 4 days now and Acura is locating the problem with something in the heads.. Well duhh I could have told them that as well lol. They are not charging me labor to find the problem but I do owe the service writter a nice bottle of hennesy.
I should have an idea by wensday on what the problem is and what acura decided to do as far as a warrenty claim goes.
UPDATE:
Please be sure to update us with any information they give you.
Question though: When you said that Acura to you to send your car to "Acura", what does that mean? Did you have them tow it to Ohio or I guess what I'm asking is where you sent the car.?
iWhine S/C 6MT TL
This is great information.
I got the Shifts
heres a DIY i made a couple of months back. its for a 2g but the instructions still apply (minus the valve clearance specs)
https://acurazine.com/forums/2g-tl-1999-2003-98/valve-adjustment-diy-progress-643700/
hmmm I have the same ticking and I'm quickly approaching 90k.... something tells me I'll need more then a valve adjustment. I did buy my car w/ the CPO... so I wonder if I should have the dealer look into the noise as a possible warranty issue
iWhine S/C 6MT TL
iWhine S/C 6MT TL
