05' Honda Pilot 3.5 heads on 05' Acura TL
would this work? would the 3.5 heads mate up without a problem to the 3.2 block? My valves went and I need new heads. I've seen quite a few Honda Pilot heads but not too many TL heads. I was wondering.
Are you high Aznboi? Where have you seen a pilot J35 head on a TL J32 block? I wouldn't for any number of variances.
Are you stupid? I seen it done before it’s the same damn head and are like 50 a pop if you are lucky and quick and easy fix for bent the valves. It’s not like you are replaced a tls heads with a crappy head. Same goes for the odyssey heads.
Its the same bore 89mm it’s not like you are replacing the monoport exhaust with individual port per cylinder heads like the j35a4, j32a2
If it's a direct match, then why would you need to use the pilot gasket?
JarrettLauderdale
04-29-2022 06:20 AM
BadgerNation
09-15-2004 08:49 PM
ferrari527
08-05-2003 04:00 PM
