3G Manual Gearing Ratios
Old 03-10-2019, 04:31 PM
Underestimator's Avatar
Hi all. I was a little bored and made a chart which depicts all of the gearing ratios and how they relate to each other while at different engine speeds.
The left 2 columns represent the difference of the ratio of the current gear (in bold) to the ratio of the desired gear. For example shifting from 1st to 6th has a ratio of 0.20, meaning whatever RPM you are in in 1st gear, 6th will be 1/5th of that.
The middle columns under Engine RPM show what RPM the engine would be at for all given gears. The blue highlighted section is the speed at which the vehicle will be traveling at, given the gear and engine RPM (I calculated the speed by referencing my approximation of 6th gear @2000rpm = 59mph).
LoveMyTL-S (03-20-2019)
InWI
23
06-26-2009 12:16 AM
BLACKOUTCL
10-02-2002 01:04 PM
Nashua_Night_Hawk
09-30-2002 12:05 AM
pgatour1
08-27-2001 07:02 PM
Crippen
04-13-2001 08:50 PM
Quick Reply: 3G Manual Gearing Ratios
