3G Acura TL bulb sizes list 3G Garage #G-077
#41
I think LEDs for drls would be best, but you most probably will get an error message in the dash. If you go to VLEDS.com they just made a harness for our TL's so we can install any LEDs with no error message. I would suggest probably 5K for the brightest white color. Check out this thread for more info.....https://acurazine.com/forums/3g-tl-2004-2008-93/v-led-new-drl-harness-784319/
o4Komodo (06-12-2016)
TSXinity (05-10-2012)
#44
#46
So just so I am clear:
- Fogs take 9006/HB4s. Does this include the Accord fogs?
- I have a 2006, so do the DRLs also take the HB3/9005s, or is that just for the 07-08 & Type S? Or is it also the same as the fogs - 9006/HB4s?
#52
I just replaced one of the seat heater switch bulbs in my 08...got the bulb from the Honda dealer,,,have to remove the rear console but you don' have to remove the switch, just peel back the silver tape on the switch to expose the bulbs.
#53
I have compiled all bulb sizes for everything in the 3G Acura TL for everyone's references. Enjoy.
All models (04-08 and Type S):
Rear turn bulb(2ea): 7440
Reverse bulb(2ea): 921
Ceiling(dome)(4ea): 2825
Doors(2ea): 194
Trunk(1ea): 2825
Vanity mirrors(2ea): 2825
License plate(2ea): 168
Glove box(1ea): 74
Center console(1ea): 74
Brake, side markers and high mount stop: all L.E.D.
*The 2825, 168, and 194 are all the same size with different wattage.
5watt, 4watt, and 3watt respectively.
HID main beam - D2S Osram 60404 bulbs for all models (4300K stock)
Front turn signals:
04: 7443
05: 7443
06: 7443
07 base: 7443
07 Type S: 1157
08 base : 7443
08 Type S: 1157
Fogs for 04-06 models use 9006 bulbs.
Fogs for 07-08 and Type S models use H8 (35w stock wattage).
DRLs (07-08;Type S) uses HB3/9005
Doors(2ea): 194
Trunk(1ea): 2825
Glove box(1ea): 74
Front turn signals:
04: 7443
05: 7443
06: 7443
07 base: 7443
07 Type S: 1157
08 base : 7443
08 Type S: 1157
The following 2 users liked this post by I<3JDM:Acura:
JohnWilson (11-27-2022),
Megan McCarty (12-28-2020)
#54
Foglight Bulbs replace with LED?
Does anyone know if these would work for foglight bulbs replacement for 06 TL?
its 9006/HB4 with 18 SMD LED foglight bulbs
here's the link http://www.xenonplanet.com/9006hb4-w...foglight-bulbs
Thank You
Thank You
#61
Naming question
All of my lights work ( 04 TL base ).....except the passenger side orange light that is next to the headlight. I was looking into replacing all of the bulbs at the same time.
These are the parts in my cart from Rock Auto : Headlight 9005 , Daytime Running Light 9005. I am assuming the light bulb behind the orange lens cover is the 9005? I just want to confirm the correct part numbers and make sure that the one that is out is actually the Daytime Running Light.
Last edited by kfalisi; 07-21-2017 at 08:32 PM. Reason: Wanted to correct parenthesis spacing and capitalization.
#63
#65
Doors(2ea): 194
Trunk(1ea): 2825
Glove box(1ea): 74
Front turn signals:
04: 7443
05: 7443
06: 7443
07 base: 7443
07 Type S: 1157
08 base : 7443
08 Type S: 1157
Doors(2ea): 194
Trunk(1ea): 2825
Glove box(1ea): 74
Front turn signals:
04: 7443
05: 7443
06: 7443
07 base: 7443
07 Type S: 1157
08 base : 7443
08 Type S: 1157
#67
So it turns out the bulb size for the DRL/Fogs (innermost bulbs in the housing) is actually 9005, not 9006. Apparently the 9006s are for lower output/ low beam or fog light purposes, and the 9005s are higher output, so it might be a better idea to just use the 9006s and make them fit, via this mod thread because light output is not my goal here.
wusty23jd
09-24-2015 11:41 AM
Skirmich
09-15-2015 06:41 PM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
