2007-2008 3.5 VTEC Engine Question (J35A3)
Lovin' My TL-S
Quick question...
I've noticed when driving my '08 TL-S (AT) that if I let off the throttle when I know it is in top gear, a few seconds later I can feel a sort of "surge." It almost feels like it is upshifting (the RPM's do go down slightly) but I know it's not shifting because I've tapped the gear selector over into ManuMatic while accelerating lightly, it says it's in 5th on the display, I tap it back over into full auto and ease off the pedal - then I can feel the slight shift thing. I've also counted shifts and I know I can feel more "steps" than 5! Now my curiosity is bugging the piss out of me!
At first I was thinking it was the torque converter locking up, but it would have done that way before getting into the overdrive gears (4th & 5th) right?
My next thought was whether or not the J35A3 engine has cylinder deactivation. I've scoured the net but I can't find anything very technical on the J35A3 engines. Just the basic VTEC and ULEV stuff.
The '08 Accord has a very similar engine (at least it puts out the same 286 hp) and it *does* have cylinder deactivation modes (4 cyl & 3 cyl). Anyone have any good technical/engineering docs on the J35A3 other than a service manual? More like a technical writeup of it's particular VTEC strategy, cylinder deactivation, etc - that kind of stuff.
Thanks guys... My geek side has got to understand these things!
Lovin' My TL-S
Originally Posted by aw1
gradelogic
Yeah, I know about GradeLogic but that holds it in a lower gear on decel down a hill or accel up a hill. It's already in top gear when I feel this "surge" or "step" and I know it's not a transmission shift (by looking at the gear indicator). Also it's doing this on flat road so there's no Grade to Logic!
Maybe I should try this in ManuMatic and then I'll KNOW 100% that it is not a gear shift. Plus, being in SportShift mode would deactivate GradeLogic. I'm 99% sure already though, it's too slight and the RPM's don't fall enough for it to be a shift.
Hmmmm....
grade logic is NOT DEACTIVATED during SS, I try to upshift on the bridges during my commute to save on gas and it will override me for the upshift. When you let off the gas, the surge is the gear disengaging, such as if you are coasting, that will reduce the engine braking felt therefore, the surge.
AZ Community Team
Received 7,770 Likes
There is cylinder deavtivation in the 3G TL - any of 'em. I'd bet my '07 TL-S on it.
However, with this "feature" in the new Accord, there's a good chance (IMHO) it'll show up in the 4G next year.
Lovin' My TL-S
Just trying to follow you...
AZ Community Team
Originally Posted by PacketStorm
Did you mean to say that there is *no* cylinder deactivation in the 3G's and that there's a good chance it will show up in the '09 4G?
Yep. Sorry.
I'd bet my TL-S that there is NO cylinder deactivation in any 3G engine.
(you should've taken the bet, then pointed that out - lol )
I have car ADD
i know what hes talking about... its a noticeable feeling..
say you are driving in mild traffic stop and go, and your going about 30mph or so, you take your foot of the gas. and a split second later the car kind of jerks a and seems to be engine braking and slowing down. or if you are on the parkway doing around 60ish and you take your foot of the gas, you feel a surging/jerking.. i think it has something to do with the drive-by-wire system.....
by the way, the TL-S is NOT J35A3 (i think thats the honda oddysey or ridgeline) its a J35A8....the accord is also J35 block, but it may not be the same. the accord is 268hp, not 286hp.. also, it has I-VTEC, which is a much more noticeable vtec system.. its the same as the RSX..
btw..my friend got the 08 Accord V6 coupe.. and it boogies... my tl-s is still quicker, but his car is pretty damn close... i should ask him to drive his car to see if it does it too.
Lovin' My TL-S
I have car ADD
well, the i-vtec in the accord block will surely make up for its HP loss when compared to the J35a8 block... now.. if we weigh the accord and tl, if the accord comes in 100lbs or more LESS than the TL, they should run pretty closely
csmeance.. not to doubt your readings or findings... but if thats true, then honda has created the first 0% power loss drivetrain in the industry !!! i find it hard to believe that these results were accurate... no car ever puts down what it claims..... @ the hub should be closer to actual BHP, but there should still be some kind of loss, especially in a 5AT transmission.
Yep. Sorry.
im curious to see that article too.... do you have a link?
it would make sense to under-rate the engine for a sales perspective, but i would like to see some dyno graphs and charts...
