2006 TL rockauto motor mount and trans #
9th Gear
Hello all...
This is the part number from rockauto..
#DEA A4544 Transmission mount
# 104-1895 Transmission mount
DEA A4599HY MOTOR MOUNT
DEA A4526HY MOTOR MOUNT
I order these in 11/2013 but it was too cold to install... Im having someone do this next week
Rockauto does not sell the motor mount near the firewall... I could not find it
But i wanted to contribute to the fourm
DeathMetal (05-16-2014)
tihomirbg (05-16-2014)
Would you guys use the aftermarket brands for the transmission mounts?
I need to replace my transmission mounts, not sure if it's worth going OEM.
The side mount your talking about near the throttle body isn't a engine mount. That's a transmission mount.
The side engine mount for the TL is on the passenger side near the power steering and washer fluid reservoir. You'll have to remove plastic cover to reveal it.
As for oem or aftermarket for the transmission mount I couldn't tell you.
I paid $150 for oem cv axle instead of $70-$80 for aftermarket. I don't mind paying extra
I have an '04 TL w/ 118K that a Honda and an Acura dealership both said had all bad engine- and transmission mounts. The Honda place wants $935+4 hours labor to replace them, including programming the mounts. I can tell you now that this will NOT go over well with the Minister of Finance. So, I have some questions. If I can afford them, I'll use OEM parts.
1. How many of the mounts have vacuum lines to them?
2. WTH is "programming" the mounts? Calibrating them? Wouldn't you just hook up the vacuum lines to the mount after installing them?
3. I plan in replacing them myself. Would a dealership program them after I install them?
4. Any sage advice?
5. Are the mounts a problem with these models?
4. Any sage advice?
1. 2, front and rear
2. It's BS, there's no such thing. There is however, neutralizing the motor mounts, which is a simple extra step during the installations
3. No such thing as programming a motor mount
4. Not really, since you aren't doing it yourself so it wouldn't matter what advice I give.
5. They wear quick, but it's not really a "problem"
thornton102 (05-30-2014)
joflewbyu2
10-08-2015 11:16 AM
STL TL-S
09-23-2015 08:52 PM
