Notices
Third Generation TL (2004-2008)
2005 manual won't go into gear
Old 06-04-2019, 09:10 PM
New Member
I am looking at purchasing a 2005 TL with the following problems:
Car was runs fine, clutch needs to be changed. Car won’t go in gear when the vehicle is on the ground. On a jack it goes in gear but clutch will not disengage.
Any ideas?
Simple (LOL) clutch change, possible linkage, or transmission problem?
Has 190k miles on it.
jhutch58 is offline
Old 06-05-2019, 09:40 AM
Registered Member
Did you check the level of the clutch fluid reservoir? Probably the clutch master or slave cylinder would be my guess but with those miles might as well do a new clutch/flywheel also
90foxnotch is offline
Old 06-05-2019, 02:40 PM
Registered Member
WDPanda's Avatar
A failing clutch would be slippage or hard pedal. A non engagement senario means you need to look at your hydraulic system and possibly the clutch pedal bracket mount.
Start with fluid level, then see the slave cylinder fork if it's making full extension.
WDPanda is offline
Old 06-05-2019, 04:22 PM
Registered Member
My guess is the pressure plate self adjusting mechanism failed and worked its way the whole way out causing the clutch to be permanently engaged. My old Audi S4 had the same type of LUK clutch pressure plate and this happened to me. I don't think it's super common, but it can happen.
acvega is offline
001Stunna
12-11-2017 11:37 PM
mohammad najaar
Acura RSX Discussion
01-15-2017 10:18 PM
Vtec_nae
06-27-2013 12:29 AM
nujunglist
First Generation CL Discussion (1997-1999)
07-22-2004 12:41 PM
kuan48
Ramblings
05-22-2001 03:04 PM
Quick Reply: 2005 manual won't go into gear
