A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
Old 10-15-2013, 03:27 PM
  #641
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
Nope, I made it only public to those that wear close toed shoes. This ain't India, sucka...
I adapt
when hot, toe open baby....unlike people in FL who wear crocs all year long
Old 10-15-2013, 06:20 PM
  #642
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
Betty banned crocs. I used to though!
Dey slippery when wet though, friggin dangerous!
Old 10-15-2013, 07:13 PM
  #643
swoosh's Avatar
^^^ awesome....Betty has great taste IMO....
CROCS should be banned
rockstar143 (10-17-2013)
Old 10-15-2013, 07:30 PM
  #644
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Take it to the ramblings thread you nimrods
Old 10-16-2013, 10:29 PM
  #645
spartan76's Avatar
Forgot to mention this....when i recently did my timing belt job, the acura tech that loosened my CP bolt, when i told him i'm doing the thermostat said "I wouldn't bother, on the 2004 and newer TL's, in 10 years I've repaired one that failed. They never do, just wait till it blows, which won't happen"
The honda tech that helped me confirmed on the Honda V6 accords she's only fixed one or two, said "yeah it's optional in my opinion"
Old 10-17-2013, 09:03 AM
  #646
#1 Super Guy!
94eg!'s Avatar
I have a 25 yr old Honda with it's original thermostat. Still works perfectly.
I have/had 5 Hondas total over the years and the only time I had to replace a thermostat was on a imported JDM motor swap. It was stuck open. I imagine the engine sat in a yard or warehouse for some time with no coolant in the hoses. This must have ruined the thermostat.
I don't replace them as "regular maintenance".
Old 10-17-2013, 09:46 AM
  #647
It wasn't too much money to buy a new one, maybe I'll return it though. Is it somewhere that access is much easier while doing the TB service? Or is it just as easy to get to any time?
Old 10-17-2013, 10:27 AM
  #648
swoosh's Avatar
^^^ might be a good idea to do it now since for the thermostat you will have to drain the fluid to replace the thermostat....
when you do the TB job, you drain the fluid anyway right, so might not be a bad idea to do it now, else you will either have to wait until the next time you have to do the job (another 105K) or if the thermostat fails (which is made clear that it might not happen)....
Old 10-17-2013, 10:34 AM
  #649
Majofo's Avatar
It's not the failure of the tstat, it's the spec. It's common for the tstat to go out of spec when opening and closing.
Old 10-18-2013, 12:11 PM
  #650
#1 Super Guy!
94eg!'s Avatar
And yet the cars always stay within their "normal" operating range. Even in 120* heat of Las Vegas. Just saying.
Old 10-18-2013, 01:40 PM
  #651
I'm actually considering changing out the top/bottom radiator hoses while I'm at it too...they seem flexible still and have no signs of dry rot but they're one of those things that tend to burst at the most inopportune time and they're now 10 years old.
Old 10-18-2013, 01:46 PM
  #652
swoosh's Avatar
they hold up just fine....I recently changed that to run a higher psi rad cap (which I never got to)...
if you want to change a hose out, look into the 2 hoses which take the coolant from the block to the TB and back....those had gotten "brittle" if you will....I swapped them out when I did the TB coolant bypass....
Old 10-18-2013, 02:29 PM
  #653
Majofo's Avatar
Hoses are probably fine.
Old 10-18-2013, 02:47 PM
  #654
Well, they're $27 for both on Amazon. Good peace of mind. We'll see.
Old 10-18-2013, 02:55 PM
  #655
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
^Agreed. If everything is going to be drained and apart why not spend that extra little for new and sexier hoses?
Are there quicker to open thermostats for the J?
Old 10-18-2013, 04:50 PM
  #656
I'm "the J"?
Old 10-25-2013, 05:47 AM
  #657
06 6spd TL BAGGED
nokiaboy808's Avatar
was anybody recommended to change the oil pump seals? my acura dealership told me that it tends to leak and is a common problem so it should also be changed when doing your 105k maintenance. Another private shop that specializes in acuras told me the same thing...
Old 10-25-2013, 08:45 AM
  #658
#1 Super Guy!
94eg!'s Avatar
Nope. I still have my original front main seal on my 89 CRX with 225k miles (using Redline Synthetic).
Old 10-25-2013, 09:32 AM
  #659
the overexplainer
ez12a's Avatar
in most cases its a very minor leak like the RMS, unless something like that bugs you.
cars are such unrefined machines in general, it's bound to leak one fluid or another.
nokiaboy808 (10-28-2013)
Old 10-25-2013, 09:49 AM
  #660
JJH
JJH's Avatar
I changed both the front and rear main seals along with the cam seals when I did the 105k service and clutch install.
It's a piece of mind thing for me. I would rather not have to get in there again if they did start leaking profusely, which is totally unlikely.
rockstar143 (10-25-2013)
Old 10-25-2013, 10:17 AM
  #661
ROBBIEVO's Avatar
Do you guys recommend going above the timing belt and water pump? I was told nothing but those 2 items needed to be replaced, but everything else I see the tensioner etc is also replaced.
Old 10-25-2013, 10:40 AM
  #662
the overexplainer
ez12a's Avatar
i would, since you can get all 5 pieces (tensioner, tensioner pulley, idler pulley, water pump, belt) in a kit for less than $200.
You're already in there, you might as well change them. They're a simple bolt on affair. Plus do you really want to trust those pulleys and bearings for another 100k miles?
ROBBIEVO (10-25-2013)
Old 10-25-2013, 10:48 AM
  #663
Majofo's Avatar
ho, long time no see braddah. The oil pump seal does leak. I didn't do a reseal on mine because I didn't see a leak but it is common. It's not like the seal will catastrophically fail and you'll be replacing a quart a week. If you do reseal the pump, get the vtec solenoid valve filter and oil pump o-rings. You can see them pictured in my kit (currently in a box in my garage)
btw, how much they want to charge you to reseal + tb job?
Old 10-25-2013, 10:57 AM
  #664
Majofo's Avatar
Rob, as you can see from the DIY and from posts from other members, the other components were showing signs of failure. Judge for yourself.
The following 2 users liked this post by Majofo:
ROBBIEVO (10-25-2013), rockstar143 (10-25-2013)
Old 10-25-2013, 11:16 AM
  #665
ROBBIEVO's Avatar
Ya kinda figured that, just wanted to make sure. Anything else I should be looking at? I just bought it last weekend. Probably gonna order new mounts as well.
Old 10-25-2013, 11:18 AM
  #666
Majofo's Avatar
Definitely a good time to replace the side engine mount. As you can see, mine was destroyed.
The auto tensioner for the drive belt might also be on it's way out. Mine is still running well, but there are few members here who eventually replaced theirs after going out of spec.
Old 10-25-2013, 11:20 AM
  #667
JJH
JJH's Avatar
Vtec solenoid seal located almost directly above where the oil pan drain plug is. Very common for it to start leaking. The oil pools on the bottom of the drain pain and most think that the drain plug bolt is leaking when in reality it's the vtec solenoid seal. That was also replaced.
Serpentine belt tensioner if you have a chirping noise in the morning.
Old 10-25-2013, 11:34 AM
  #668
the list keeps growing!
Old 10-25-2013, 11:58 AM
  #669
maharajamd's Avatar
Hoff is going way above and beyond what he really needed to do. I assume partially because he was in extra deep because of the clutch.
If you're not doing the clutch a lot of that stuff, unless they are issues, don't need to be touched.
The following 2 users liked this post by maharajamd:
JJH (10-25-2013), rockstar143 (10-25-2013)
Old 10-25-2013, 12:00 PM
  #670
JJH
JJH's Avatar
Yes I'm anal it's not necessary to do all of those seals I just did em because why not? They are relatively cheap and not much extra work/labor.
Old 10-25-2013, 01:00 PM
  #671
Thanks, Chad...
I take the same approach, Justin...but I won't be replacing clutch, obviously so I'll limit myself.
Old 10-25-2013, 01:58 PM
  #672
iKnowrite's Avatar
Thanks For The Image Really Helpful
Old 10-25-2013, 01:59 PM
  #673
swoosh's Avatar
^^^ i know rite
Old 10-25-2013, 03:27 PM
  #674
Majofo's Avatar
This is not ramblings
Old 10-25-2013, 04:40 PM
  #675
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
First I've heard of that recommendation...and no, I didn't. No issues at 142K...
Old 10-25-2013, 04:43 PM
  #676
nfnsquared's Avatar
For an extra $100, it's no brainer IMO (tensioner + pulley). My tensioner was fine, but others have found them leaking at the 105K service...
Old 10-28-2013, 06:14 PM
  #677
06 6spd TL BAGGED
Haha yeah i barely come onto on here anymore unless im looking for parts or advice on something. I went along and got all the gaskets and seals replaced also. I got a good deal on the labor since i had my most of my own parts. Lets just say if i never know a couple of people that work at acura, it would have been a lot more lol
Majofo (10-28-2013)
Old 10-28-2013, 10:45 PM
  #678
Majofo's Avatar
Definitely need a good hook-up, especially for safety inspection and recon Good to hear everything is done.
Old 11-24-2013, 11:33 AM
  #679
nfnsquared's Avatar
Well, coming up on 3 years since I did my TB change and all of a sudden I get PS moan. Hmmm, I'm wondering if the O-ring went bad. I pop the engine cover and the PS reservoir and whole area around it are covered in PS fluid. WTF?
Upon closer inspection, I discover that the reservoir is no longer in it's holding bracket. I put in back in and check all the hoses and connections. Everything seems solid. Only after a power wash of the area do I discover the issue: There is a gash in the side of the reservoir where it apparently rubbed against the serpentine belt when the reservoir came loose from it's bracket. It had worn through the plastic just enough to leave a pinhole for the fluid to leak out of.
Lesson learned: be sure you firmly seat the reservoir back in it's bracket when you're done with the TB change. It might be a good idea to periodically pull the engine cover to check. I don't think I've had that cover off more than 5 times in 3 years...
Old 11-24-2013, 03:39 PM
  #680
Majofo's Avatar
ouch..
Quick Reply: A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
