A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
#602
Got all my parts in...I figured whether I do it myself or not, it'd be good to source the parts on my own. I'm getting the confidence to make it happen.
When you say rear cam gear moves, is it as simple as putting it back in place to line up all marks once you put the new belt back on?
#603
the overexplainer
#605
the overexplainer
its doable, bro
you've done way more work than I have on your TL than me and I managed to do it my first try lol.
Think of it this way, everything for the TB DIY is bolt-on. the most force you'll ever use in the entire job is the Crank pulley and getting it lined up. The rest requires only a little bit of strength. just take your time and bring a mechanically inclined friend. The most i had my friend do was the cover bolts and as a second set of eyes to triple check lol.
rockstar143 (10-14-2013)
#606
takin care of Business in
Received 4,732 Likes
Jeremy, just ask how much a tech will charge you if you provide him with all the parts....if its 200-300 bucks, it might not be that bad....
but if its anymore, you might wanna give it a try....PS: I totally think you can do it though
#607
yes, just rock it back into alignment.
#609
Just put a socket on the pulley bolt and crank it back to TDC:
....Had everything TDC and pulled the old belt off. Reached over to get the new belt and heard a "clang". Thought a tool dropped. Looked around the floor of the garage, nothing. Oh well. Went to put the new belt on and WTF, the rear cam sprocket was off about 1/8 turn CW. Cranked it CCW to TDC, lots of pressure so I pulled the rear plugs just to be sure. Cranked it back, still the same pressure, pulling the plugs didn't make any difference.
Got it to TDC but went just a little too far and "clang", the sprocket spun 1/8 turn CCW. So, moral of the story is there is a "sweet spot" right at TDC. Go either side of that and the valve spring pressure may spin the cam. No big deal, just move it back to TDC....
Majofo (10-15-2013)
#611
Either direction is fine. We're only talking about 1/8 turn or so, not a full revolution.
Edit: and just to be sure, this applies to the cam sprockets (most likely it will be the rear cam sprocket).
#612
^^^ THIS
if you miss the mark, you can turn it back....dont go for a full revolution...
#613
Thanks, NFN/Anil. And I'm assuming once belt is off, it's something that can just be turned by hand. I had read about marking old belt, cam sprocket, then transferring marks to new belt to be sure you're on the exact same tooth. Overkill?
Also, this kit I ordered...although it looks IDENTICAL and the water pump gasket sits in the channel and doesn't fall out does NOT appear to be an AISIN pump. Koyo bearings, Aisin tensioner, Gates belt (got new iridium, gates thermostat and fel-pro valve cover gaskets) and a Chinese water pump that seems to mimic the Aisin with everything but the name stamp and it has a polished impeller.
I'll post a picture soon.
This is what I got. I almost got the AISIN water pump timing kit but that brought a Thai belt and NOT GATES. I figured if I was to do a no name brand on either of the two, I'd rather it be the water pump than the Timing belt.
J.
J.
#614
the overexplainer
J.
Amazon.com: Gates TCKWP329 Engine Timing Belt Kit with Water Pump: Automotive
J.
i was the one that marked the belt at each sproket before removal and lined it up with the new one. Overkill? maybe, but it took the guesswork out completely as to whether or not i skipped a tooth.
rockstar143 (10-15-2013)
#615
Get out of here Anil! You've never changed your timing belt
Better to be safe than sorry. I didn't mark the belt, but I didn't bitch wrist it.. it was taut to say the least.
Regarding that Chinese kit you bought..
Overkill?
#616
Needs a 930
We were real careful and the gears didn't move. Real simple to turn it back. We had the plugs in when we first turned it but then took them out and it was easy. It's really not difficult.
I've got about 300 miles down since we changed out everything and yesterday evening I noticed a kind of whispy? sound when I get on the gas. 1500k or lower and you get hear it. Any ideas? Maybe we messed up that pulley when the belt tried to jump off?
#617
acuratech239 is a Acura master tech local to me who has probably done hundreds of timing belts (you can read his post in the first page or two as he gave me some tips on the job as well), has seen some failed Chinese pumps.. better hope that's not yours.
#618
Did you make sure you had TDC on the cams and crank pulley? Wouldn't hurt to check again, but my guess is it's the auto-tensioner and drivebelt making noise. Easy check is to remove drive belt and see if the noise goes away. Also check that you replaced the power steering res to the clip, you wouldn't be the first to belt burn one.
BeezleTL85 (10-15-2013)
#620
#623
Congrats!
A heads up: If you notice a strange humming/moaning/whining sound in the next few days, it's probably the drive belt auto tensioner or the path of the drive belt on the auto tensioner pulleys. About day 3 I noticed the noise. I popped the drive belt off the crank pulley and started the engine...noise was gone. Put the belt back on...no noise. Don't know if flexing the AT did the job or if repositioning the belt on the AT pulleys did. I pretty much had the belt centered on both pulleys before and after...
BTW and FYI, my old TB looked to be in excellent shape...
I used that same kit, no issues so far: 36K miles and just short of 3 years... and plenty of others have use that same kit with no reported issues...
The following 2 users liked this post by nfnsquared:
BeezleTL85 (10-15-2013),
#624
#625
You dolt J, that's a Gates pump.. see the 5957 stamp. You'll be fine, just don't bump the o-ring out of the track.
#627
#628
make sure its a big one
#630
Nothing is big enough for you..
#631
well lets just saw YOU dont have anything BIG enough for me
#632
I went to Joshua Tree National Park.. all too puny for your bingus.
#634
the overexplainer
but yeah, that kit is the same in the OP, soo after all this time, i think we're good.
plus the original pump on mine was leaking at around 70k. maybe this china one will be better.
#635
Boys, thank you much. I don't know if it's a good or bad thing but I put a lot of credence into the advice I get on these boards. Although I've come a long way, I will admit that even I'm not above the occasional newb moment where I just need reassurance for uncharted territory. I will run a dab around the entire gasket to ensure that it sticks in the channel while being placed, no worries!
I'm hoping to be in a 2 car garage home in the next few months...that'll give me the space I need to know I can have the car taken apart for a solid 3 days and knock this all out with plenty of time. I plan to pull battery, intake, intake manifold, valve covers...do the valve adjustment and work my way back. Should make it easier to do with most of that stuff out of the way.
#636
^^^ that should make it very very workable....
I would suggest AGAINST taking the runners out...you will spend a lot of time (some bolts are well hidden) and it wont save you any/much more space....
while you are soo deeep in, why not replace the spark plugs as well (not sure if you said you gonna replace them as well)
#638
^^^ your picture about must have been photobucket....my laptop is smart to ignore all low resolution pictures automatically
#640
It's not where it's manufactured, it's who manufactured it. Armadildo assumed that because it was made in China, it was a knock-off and not a Gates / OE pump. I know exactly how J's install is going to go..
