A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
Old 07-21-2010 | 05:46 PM
Majofo's Avatar
Here's a basic DIY guide for you guys considering on doing the 105k service yourself. Below will be the basic list of materials and tools you need to complete the job. Feel free to add anything that I may have omitted in the writeup.
A few notes about the task, find at least a half empty garage to do it and give yourself the weekend to complete it. Start early Saturday morning and if you're lucky and everything goes right, you're done early Saturday afternoon.. If not.. late Sunday Afternoon.
Most importantly, I take no responsibility if you attempt this DIY and fuck something up.
Parts
Timing Belt
Drivebelt
Water Pump
TB Adjuster
TB Auto Tensioner
TB Idler Pulley
170F Thermostat
NGK Laser Iridium plus #6994
Brake Cleaner
Anti Seize
Thread Locker
PB Blaster
2gals Coolant 50/50 (silicate free - Honda Type 2 / Prestone)
Shop Towels
Tools
Hydraulic Jack
Jack Stands
Wood Block
At least a 2' Breaker Bar (Can be rented at Autozone for free, or bought at AZ or HF for ~$20)
Impact Sockets & Extensions - CP 19mm
10mm, 12mm, 14mm, 17mm socket set, deep neck and normal
10mm angled / elbow wrench, standard metric wrench set
Torque Wrench at least 200 ft lb spec (Can be rented at Autozone for free)
Mirror, Magnet, Metallic tray, Gloves (optional but very useful)
Pan to hold used coolant
Gloves
Prep
Engine cool
Dry covered secure place - garage
1. Remove all covers, unplug battery, raise front end and put up on jacks, remove front pass wheel, remove lower front splash guard.
2. Remove Rad Res, Remove spark plugs, place coils in a safe location - helps when turning Crank and cams to leave them out until after TB job.
3. Unhook PS res and tuck it out of the way, Remove drive belt, remove belt tensioner (learned the hard way)
4. Place jack with wood block under oil pan to support engine, remove side engine mount bracket & side engine mount
5. Turn CP to line up the CP, rear & front cam marks (1st piston TDC position) - verify front, rear might be off a little.
6. Remove CP bolt.. ffffuuuu!!! If you can get an impact wrench, get one. Otherwise don't be pussy, wedge the hex tool with a breaker bar & using another breaker bar, remove CP bolt. I used 2' breaker bar and impact sockets & extensions to get the job done. I soaked the bolt in some PB, not sure if helped but I got it off. It should be easy to remove after the initial pop.
7. Remove upper and lower TB covers. Don't pry the covers off otherwise you might damage the seal on the edge. Remove remaining engine mount bracket.
8. Get all the timing marks in spec with the body, remove idler pulley, remove CP, remove TB, remove adjuster, remove auto tensioner
9. Open radiator cap on top and then open up bottom radiator cap to drain Coolant from rad.
10. Don't bother with rear engine coolant drain, it's a PITA bleeder valve to get to.. I was able to open it up but not a lot of coolant came out. I consulted 240sx and he said they just pop the WP and let the coolant spill out in the shop and to spray down with Brake cleaner to evaporate everything. If you want to bleed it from the rear of the block get a 1/8” long hose leading to your fluid container and open up the valve with a wrench. If you decide to open up the WP without draining, put l long tray underneath the area collect the coolant and pack paper towels around the CP sensor assy.
Remove the Water Pump. Soak up excess coolant and spray down CP area / WP seal and Timing Belt cover areas with lots of Brake Cleaner. Wipe Clean. Make sure CP area is completely dry and WP seal areas are clean as well as timing belt cover areas.
11. Install new WP, Idler Pulley, Adjuster, Auto Tensioner – tighten battery tie down against adjuster
12. Check your TDC marks and install new TB starting at the CP – counter clockwise. There should be ZERO SLACK all the way to the adjuster. All the slack should be at the adjuster / tensioner. Tighten idler pulley to spec once TB is on.
Check your TDC marks again after the belt is on
13. Clean up CP gear and shim with brake cleaner, reinstall shim (should be lip out) & CP. Clean up CP bolt and lubricate end threads and neck of CP bolt between head and washer with fresh oil. Install bolt loosely and cycle crank six times, check TDC marks (front / rear cam & CP marks). If they don't line up, redo TB installation. Wedge the hex tool again to keep the CP from moving and spec in the bolt to 181 ft.lbs.
14.Replace timing covers, side mount bracket, drivebelt tensioner, check TDC marks for sanity. Remember.. check TDC marks with block not covers. Replace Drivebelt starting at CP, push tensioner back and slip top of Drivebelt over PS pump pulley. Replace Side Engine Mount, clean up securing bolts first. Torque into spec. Release jack from oil pan.
Thermostat
1. Remove intake, remove securing bolts on thermostat
2. Replace Thermostat with new one / new gasket.
Spark Plugs & Burping
Install plugs and coils. Make sure to apply anti seize to end of the thread on the plugs. Replace Rad Res and refill rad. Do a triple check on all harness connections and look for any missing bolts, etc.. Verify everything is back together. Don’t forget to secure the PS Res. Plug in battery and tighten clamps. Start the car and let it get to op temp to burp the coolant system.
Put the car back together and on the ground then take it for a ride.. the SM says to put it on the street and keep it in 2nd then let it drop from 2.5k down as part of the relearning drive cycle but I think it's only applicable when interfacing with the HDS. Not sure..
But other than that, that's it. I'm sure I left some stuff out or neglected to mention some things but that's the basics of the 105k service. I recommend doing a valve adjustment at this time as well. It's an additional few steps after the TB removal but definitely worth it. I have new heads that have been ported with new hardware going in as well, so with my limited time I opted to skip the valve adjustment.
Special thanks to MisterFubar for selling me his Timing Kit at such a good price and 240sx acura tech for the inside tips on the job.
The following 174 users liked this post by Majofo:
03max6spd (10-27-2016), 04ManualTL (01-19-2019), 04TLOK (07-20-2015), 05TLdcc (08-25-2013), 3.2TLc (10-10-2013), 6for2 (11-25-2019), 85IrocZ-28 (02-16-2014), 93LT1 (10-29-2012), 94Auto (07-19-2021), 9632tl (04-13-2013), Acur8Lady (08-29-2014), Acura TL Builder (12-26-2017), Acuraluvr (05-17-2014), Acuraman101 (09-15-2016), Acura_Dude (03-30-2013), ADay2Long (09-15-2016), aiea_tl (07-13-2015), alex2192 (05-29-2012), alltrull (10-19-2019), Americandream (03-02-2013), ashaman (05-23-2014), austinjh (12-24-2011), AZ4035 (06-07-2013), barryb97 (08-17-2013), BassMekanikdB (05-23-2016), BC2G (03-20-2014), BeezleTL85 (10-01-2015), BengalsIronMan (06-10-2014), Bleizge (10-03-2018), blk 3g type s (09-26-2014), bluetl04 (01-19-2016), BMA1078 (09-10-2014), Booger1 (07-05-2013), BreezyTL (04-12-2016), Buggernuts (12-13-2017), Bun_Bo_Hue (02-02-2012), candrews (04-18-2016), Cecallred (01-12-2018), chedda13bc (07-08-2013), cheekoo (11-08-2011), Chrisman2k (02-14-2014), closetprisoner (04-27-2013), cokorote (01-22-2014), crazydragonX4 (08-02-2012), CrisRai (03-01-2016), csbert (09-03-2021), d1sturb3d119 (10-08-2013), Dafried (01-03-2014), Danith93 (03-05-2014), dannyz (04-21-2013), darkdeuce (12-30-2012), Darren's TL (04-30-2014), database (09-02-2013), DeathMetal (08-25-2015), deematic (10-27-2014), djkurious (05-06-2013), DjMikeSkillZ (06-14-2014), DMZ (09-25-2012), EagleEye (11-04-2015), ebelp (07-29-2014), ej1serge (02-24-2014), ekrekel (10-18-2011), ekxtreem (03-31-2013), EvilVirus (06-03-2019), eyedrop (03-06-2015), ez12a (06-17-2012), FCVadi (10-17-2011), flexer (11-19-2014), Flip 2 (01-19-2015), gogators22 (11-06-2011), gt1 (09-26-2014), hadokenuh (07-15-2015), HJChen42 (08-03-2013), hondazex (03-11-2015), I hate cars (02-08-2014), idunno271828 (02-25-2015), iHeartmyHonda (04-14-2014), ilias (09-18-2020), iTzVlad (04-02-2016), J1simon (09-25-2013), jauman (12-31-2014), jaydlee9 (11-19-2016), Jboat (09-25-2015), JD TL-S (03-04-2015), jfatteh (10-20-2014), jgj925 (03-04-2013), jiggad369 (07-01-2012), JMiles_T (11-29-2014), JoshD_99EM1 (06-17-2014), jptypeS (10-23-2012), kettlepress (06-17-2014), Kobeone (06-14-2012), lantzsharp (10-03-2019), LazLong (06-14-2011), Legend2TL (12-02-2013), LeggoMyEggo (08-13-2014), LeMix (07-07-2016), LGcbp8 (03-09-2016), LivewireRacing (05-12-2016), LoveMyTL-S (01-22-2016), maddog0z (05-17-2013), madpoz (04-02-2013), MaIcAnAcK (06-25-2015), mannytonio (03-02-2014), MarsTillyS_07 (08-17-2015), maska (07-10-2013), mellwhead (05-27-2014), mlody (02-14-2016), Morrissey25 (04-21-2014), MrTee12 (09-22-2017), mrtrojanap7 (02-17-2012), mteele (01-14-2013), Murders23 (12-26-2015), MyBabysBaby (08-07-2013), NittanyGen (07-16-2016), nvthis3 (06-16-2014), onesiktl (03-19-2014), osvaldo516 (11-16-2012), panzerkiller13 (04-17-2018), paperboy42190 (09-15-2012), patgard (01-31-2012), Pte. Jerry L. (06-07-2013), redbeard1 (01-27-2020), rkpatt (07-05-2015), RL09 (09-09-2016), rmartin (03-23-2015), Rob Daddy (05-11-2016), rockstar143 (01-31-2012), rod1667 (04-08-2013), Rolf65 (10-06-2023), Rollen (07-17-2014), RONE (11-11-2015), rossv1 (03-25-2013), RxWorld (03-21-2014), S41N7 (10-07-2013), Sandan (07-26-2017), sbr (06-16-2018), shamal (11-01-2014), SHOstopper1992 (06-16-2014), Sohan24 (07-21-2019), Sonnick (09-14-2012), Sorin Busi (10-21-2015), Speedy3 (07-25-2016), Spen_cer (03-10-2015), srg818 (04-22-2014), stevenator56 (11-29-2016), stkh22 (05-04-2017), stljim2005 (03-10-2014), swoosh (06-06-2012), TACORICAN (12-04-2014), talmadgeryan (10-06-2013), terrylin101 (05-03-2012), thenamesian (08-26-2012), theonlybfc (10-23-2017), thirtyfour (05-03-2014), thoiboi (03-17-2015), Timbert (06-13-2015), TL Luver (04-19-2013), TL4GX2 (06-23-2020), topdawg68 (05-18-2013), topdollr (02-24-2014), tpoony (01-11-2012), triax37 (11-15-2011), TRIOD3SIGNS (04-23-2014), tsxymazda (09-27-2014), turbo_oxide (10-27-2014), VanGuy (07-04-2013), vic06b (07-02-2011), vinuneuro (03-17-2014), Wallyjee101 (10-01-2014), wilspainar (07-10-2017), wjo165 (05-28-2014), YeuEmMaiMai (11-07-2013), zoostation (12-27-2013) and 169 others liked this post. (Show less...)
Old 07-21-2010 | 06:37 PM
swoosh's Avatar
takin care of Business in
holy fuck....
great write up bro....i vouch for 3G Garage !!!
i wont even attempt to do it myself....i know am good at screwing up....and i dont wanna mess up that bad.....but none the less great write up for someone who is a little more mechanically inclined than me
joejsn (08-29-2014)
Old 07-21-2010 | 07:11 PM
Majofo's Avatar
Anybody can do this as long as they have the right tools and mechanical knowledge.
Old 07-21-2010 | 07:19 PM
Etohprn247's Avatar
KoolKatz..
Nice write up, thanks...
Old 07-21-2010 | 07:26 PM
myblack04tl's Avatar
Awesome write up, very detailed.
Did you get any grease on your pink fur, you look clean as a whistle!!
Old 07-21-2010 | 07:41 PM
mmade22's Avatar
200,000 mile club
Majofo with another great thread. Thanks for doing a detail DIY thread! Love it man.
Old 07-21-2010 | 08:25 PM
Dino81's Avatar
yes thank you for the DIY! great job!
Old 07-21-2010 | 08:59 PM
swoosh's Avatar
practice makes a man perfect !!!
imma drive up to ur place so you can practice this once on my car LOL
LongLurkerTL12 (04-06-2020)
Old 07-21-2010 | 09:52 PM
This is a great write-up!
I just did this on my CLS-6 and it is exactly the procedure I followed, except on the CLS it is helpful to loosen the PS pump and position it up and out of the way.
The only thing I would note is that the long timing marks on the cam pulley spokes can ONLY be utilized initially when the TB covers are ON the car. The portals on the TB covers provide a reference line to use with the cam pulley spoke line when TDC being determined.
When the TB covers are removed, the lines on the cam pulley teeth are utilized along with the marks on the block behind the cam pullies for TDC.
The only reason I mention this is because the picture above has all of the lines circled in red with the TB covers off of the engine. Which was a little confusing.
In essence, If you line up the long line on the cam pulley spoke with the reference line on the TB cover portal for #1 cylinder TDC, remove the TB covers, the reference marks on the cam pulley teeth should be in their correct position with the lines on the block as a check.
Old 07-21-2010 | 09:59 PM
04 silver bullet's Avatar
I just did mine at 104000 just because of a Blown head gasket. It was a pain in the ass changing the gaskets. Anyone else had a head gasket blow
Old 07-21-2010 | 10:36 PM
Majofo's Avatar
Good to know. IIRC they were all in line which is why I circled both but don't take my word for it. I did use the top of the cam teeth as my main point of reference.
dawidocl (03-12-2012)
Old 07-21-2010 | 10:47 PM
Majofo's Avatar
I put it out there for the 3G fam to follow in your footsteps..
You can tell my garage floor is still bare. You know what my next project will be... well after I change the TCC solenoid on the X..
I bathed in Goop..
Thanks guys.. I hope it helps you out down the line. Feel free to bump the thread to ask any questions / request pics (I have a lot) when it comes time.
Ouch.. it's happened to several members. Luckily I haven't been through one on the TL but I'll be putting in new head gaskets when I install the new heads.
As long as you bring Grey Goose, pizza.. and all the parts.
Old 07-21-2010 | 11:30 PM
swoosh's Avatar
am in kansas where you at LOL....i have done the spark plugs and the serpentine belt already (along with UR pulley )....only water pump and timing belt remain
Old 07-22-2010 | 02:10 AM
acura_dipset_tl's Avatar
AM To WDP In My Garage
Nice write up 3G Garage Worthy IMO
Old 07-22-2010 | 02:21 AM
01tl4tl's Avatar
good time to remove the intake manifold and clean the EGR ports
they like to plug up at about 75kmiles
Old 07-22-2010 | 08:54 AM
AMUA6's Avatar
ScoobyZINE
Much thanks Majo! VERY NICE!
Old 07-22-2010 | 10:21 AM
DMZ's Avatar
DMZ
Head a da Family
Congrats Majofo! You win the best DIY post of the year award!
This will help those who are considering doing this on their own decide whether they really want to do it themselves. Even though I was a mechanic in my earlier years, I'll still pay the dealer for this labor as my mechanics tool set with everything needed was stolen once upon a time and my 'crawling under' days are over.
I'll still stick with all OEM parts like the water pump with the lip for the o-ring. Dealers willing to do the job with your own supplied parts will only install OEM's anyway.
Old 07-22-2010 | 10:24 AM
pimpin-tl's Avatar
The only part that is really confusing about these DIY, why are you all using the battery tie down? I can't see why in the pictures. Maybe if someone can do a drawing?
Great DIY otherwise!!
Old 07-22-2010 | 10:28 AM
Majofo's Avatar
It's to secure the adjuster so it doesn't spring out from the auto tensioner.. I really don't see a need for it, maybe for the install but not for the removal.
Old 07-22-2010 | 10:51 AM
Majofo's Avatar
lol.. thanks.. Some dealerships do the timing belt job alone for less than $700. That's a good deal in my book. I think Hamilton Honda was doing it for less than $400. They're obviously not making a dime but I'm sure they find upsells or issues during the install they can bill additionally.
If you find a good deal, or at least find a good reputable and honest shop, go for it. I'm super cheap. If I can save a buck I'll do it, plus it's still fun to wrench on the car. It's treated me well thus far so I'm going to do the same. Next DIY from me will be the Dash cover.
Old 07-22-2010 | 11:12 AM
bshevchuk's Avatar
What city are you in Majofo?
Old 07-22-2010 | 11:38 AM
Hapa DC5's Avatar
אני עומד עם ישראל
wow fantastic write up man..
Old 07-22-2010 | 12:13 PM
Majofo's Avatar
Austin
Old 07-22-2010 | 12:29 PM
swoosh's Avatar
i was actually planning a trip to austin....shit....how ironic....never seen texas so me and my girl were thinking of a 4 day trip to see dallas/austin/houston/san antonio.....
and i was telling her i have heard nothing but great things about austin....lets move there....good weather all year long and yada yada....
i might just make it a 5 day trip and get this done too....what say majofo ?
Old 07-22-2010 | 09:01 PM
DMZ's Avatar
DMZ
Head a da Family
Originally Posted by buttholebilly
I hope your finger breaks through the toilet paper!
And if you work for the city of Newark, NJ, you soon won't have toilet paper to break your finger through.
Just today, Newark's mayor Corey Booker announced the city no longer has money to buy toilet paper.
NO KIDDING!!
Old 07-23-2010 | 10:27 AM
Majofo's Avatar
Too bad buttholebillz doesn't work for New Jersey.
Old 07-23-2010 | 01:31 PM
pimpin-tl's Avatar
Austin
Good, when I get high enough, I can have you come down to help me on mine in SA!
Old 07-24-2010 | 02:31 AM
mmade22's Avatar
200,000 mile club
I thought it was a DIY so you didn't need any help. He explained how to do it in detail so it's a do it yourself...Geti it? DIY? Why do you need the op's help?
Old 07-24-2010 | 03:48 AM
cjTL's Avatar
I'm Craig
Wow. Just wow. Amazing job.
Weird question...does the car feel any different after this? That spark plug looked baaad.
Old 07-24-2010 | 09:55 AM
Majofo's Avatar
lol.. it's all good. I knew I'd get those responses once I revealed my location. Luckily most of the guys in Austin that are on the board are gear heads.
To be honest it feels much better / smoother. I don't feel as much of a heat soak issue so it could be related to the thermostat but I have yet to test the old one. My mpg went up 1-2 mpg's. Those Bosch Plats were toast. I pulled NGK Iridiums out of my X after 105k and they still had a bit of a tip.. The plat's looked great otherwise and the TL did run fairly smooth before the plug change. I have also put it into vtec a couple of times since the install and all is good... and yes.. I did exclaim vtec just kicked in yo!.. my gf was not amused.
Old 07-24-2010 | 11:42 AM
Whdrms's Avatar
e92TL
wow great write up, though im mechanically retarded and probably cant do it myself even with this lolll
Old 07-24-2010 | 11:45 AM
l_brandon96's Avatar
prop to OP for taking time and effort for this. am gonna get everything ready to do it myself, any socal members wanna give a hand? pizza and drink will be avail all day haha
Old 07-29-2010 | 10:37 AM
Bogdan TL's Avatar
I was looking at the parts diagram on www.acuraoemparts.com
I get all the main parts - TB, auto tensioner, idler pulley, water pump, thermostat.
What gaskets do I need ? And two identical drive belts ? Do you have a copy of your parts invoice ? How much did you spend on parts ? I did the math and it's like $400
Old 07-29-2010 | 11:00 AM
swoosh's Avatar
^^^ i think some dealer is having a sale....everything you need for $295 shipped....some like that....dont know what all is included in it but well give it a shot !!!
Old 07-29-2010 | 11:06 AM
Bogdan TL's Avatar
which dealer ?
www.curryacuraparts.com is selling the parts for the tb replacement only- drive belt,TB,WP for like $250. But if you add the idler pulley, auto tensioner...
Old 07-29-2010 | 11:11 AM
swoosh's Avatar
^^^ there you go buddy
https://acurazine.com/forums/3g-tl-2004-2008-93/complete-timing-belt-kit-special-%24295-763445/
Old 07-29-2010 | 04:28 PM
Majofo's Avatar
I bought the kit from MisterFubar who sold his TL before doing the timing belt service so I don't have a full invoice. Several of the parts aren't "OE" (OE doesn't mean higher quality),which will save you some coin like the Gates Water Pump and the Stant Thermostat. The presitige acura deal is decent, I've seen better and I've seen worse. Make sure you buy the idler pulley if you go with the special because it doesn't appear to be part of the kit. I bought plugs & coolant at Autozone. I definitely recommend you guys get the NGK Laser Iridium plugs, they're around $7 / each but usually AAP or AZ will put out a 10-20% off coupon every other month.
Old 07-29-2010 | 05:00 PM
swoosh's Avatar
part# IZFR6K-11 for lazy asses ....coz i know that questions is coming up next LOL !!!
93LT1 (10-29-2012)
Old 07-29-2010 | 05:50 PM
MyTL09's Avatar
B A N N E D
Someone is selling a tb kit for 230 in the black market
Old 07-29-2010 | 06:11 PM
DeathMetal's Avatar
Fearless DIY Guy
Fucking AWESOME. Really, man...great level of detail, this is fantastic.
Are you in Jersey?
UNIVERSE_04 (12-06-2012)
