12 year Retrospective on TL Mods
RAR
12 years and 200k miles later, I'd like to give my updates on Mods, hacks, etc - Those I love vs those I regret doing. Feel free to post yours (if any OG are still around with their cars that is...)
Favorite hacks/mods:
Reverse camera - worth it's weight in gold and still going strong
Angry Dad navi hack - I just love this seamless startup even though I no longer use the built in navi.
<3 My current navi setup:
Magnetic phone holder that fits in the cd slot: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
5 port USB hub for the car which plugs into the cigarette lighter: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
and then of course my pixel with either waze or google maps.
My KW coilovers - love the blend of comfort and performance.
Huper Optic tint - fantastic for heat management.
Least favorite Hacks:
H&R rear sway bar. I believe the bar put too much torque on the frame and cracked the frame.
swapping out my speakers for larger ones that dont quite fit. Sound is good, but if you pull the plastic panel on my door off, they would probably fall out and hit the ground. Should have stuck with the infinitis
Anybody else?
Anybody else?
Acura TL Builder (01-11-2018)
My son has this in his TL-S and loves it. What else are you going to use the CD player for? I may get one for my TL-S.
Thanks for the updates! My 05 TL has 141k and it still runs and drives like its fresh off the assembly line. When I got it ofcourse I had to take care of the usual suspects, HFL module, Navi DVD Drive, Cracked Passenger seat, Cracked dash. I have fixed all those except the dash, I ordered a Coverlay Plastic dash cover for it. Someone was selling a like-new uncracked dash from an 04, however having looked what it involves, I opted out of replacing the dash. Everything works too pristine for me or even a specialist to take everything out and put them back on. Endless broken clips, scratches, chips and cracks from using trim removal tools/screwdriver, buttons and trip creaking. Can’t imagine how that would affect my OCD 😂
LoveMyTL-S (01-12-2018)
Head a da Family
H&R rear sway bar. I believe the bar put too much torque on the frame and cracked the frame. Anybody else?
Reverse camera - agreed
CT-Engineering (formerly Comptech) rear sway bar - tore the metal the brackets holding the links, and broke the links too!.
I've had mine for about 9.5 years now....mods? What are those? The only thing I regret not doing is getting tint done. Every year I think about it...then say no need, I'm getting a new car soon. It has been 6 years and 100k more miles since I started that thought process.
After four years and nearly 80k of 150k:
- My favorite mod are the trunk springs I put in to make my trunk lift up by itsself. Ive got a spoiler so the weight used to make my trunk open but not lift up even half an inch. Now it pops up properly.
- The clavicle pads that go onto the seat belt. Makes it more comfortable in the seat.
Slpr04UA6 (01-12-2018)
Latent car nut
Received 2,005 Likes
No longer own a 3G. But when I did:
Favorite Mods: HFPC's, RV6 J-pipe, BC Coilovers, Lightweight Enkei wheels
Least favorite: Throttle body and intake manifold spacers (made no difference) and racing seats. Racing seats dropped about 60 lbs. from the car, but aren't built to nearly the same quality as the OEM seats which are designed to withstand thousands of hours of wear. And they aren't very adjustable, aren't heated, and aren't as comfortable.
leedogg (01-13-2018)
Mr. Detail
XLR8 v2 J-pipe, TL-S front anti-roll bar and Progress 24 mm rear bar, HID retrofits and full windshield tint (70% is considered clear and legal in Texas) are the mods that helped the most. RSX wheels helped too because they are so light (16 lb vs 25 lb for the OEM 7 spoke wheels) but the 16" size means sticking with the stock rotor size. Haven't done anything appearance wise other than debadging and a full paint correction and Optimum Opti-Coat Pro.
i have a note size phone so i want to make sure my knuckles don't graze it. Currently it sits comfortably behind my shifter infront of the storage compartments, but get some blindspots in 1st and 3rd gears.
Shouldn't be a problem if you put the magnet towards the bottom of your phone/case yeah?
One on the right for me
The short throw shifter and removal of the clutch slave cylinder lock ring (or whatever it was its been years) are the ones I appreciate the most. There is a noticeable difference when I'm driving a TL without those modifications.
RAR
It doesnt get in the way of my auto and I regularly drive with my hand resting there. Be sure to get that model I linked though which positions the phone up high, theres a newer model that has the magnet positioned lower.
So 70% tint for front windshield is legal?
Joecop67 (01-19-2018)
Legend 11
07-26-2004 01:12 PM
