10mm or 11mm bleeder valve size
I have looked and looked and cannot find a straight answer. If there has been one I am sorry for this post. The manual states the bleeder screw is 11mm but thats for manual cars, are the automatics the same or are they the 10mm like some have suggested?
Also, the correct hose size to put on the bleeder valve thats nice and tight but still fits, 1/4 inch dia or 1/8 dia. or something else?
Thanks for the help, this is the last thing I need to do to complete my brake job.
The following 4 users liked this post by BreezyTL:
"Put a wrench on it and find out" is not an answer" I understand I could have figured it out, but that's the point of a forum to ask a question to see if someone had the answer before I went and tried to "figure it out" If you dont know the answer then dont respond.
samplemonster (11-18-2021)
Forums are for questions to ask when you are stumped... Did you ever go out and try something before you took the time to write your question? I am sure it took longer to write the question than it would to go look for yourself. Something so simple shouldn't need a thread about it.
For example:
How do you open a box of cereal? Some people say you slip a finger under the flap and slide it to the side but you may get a paper cut. If you don't want a paper cut rip it in half. I don't know what to do!?!?
FFS, some people are so damn lazy these days!
For example:
thoiboi (09-14-2016)
oh snap, look what i searched for, very first post Page 19-18 has bleeder screw called out as 10mm.....
https://acurazine.com/forums/third-g...-041-a-578017/
im being helpful even though you are being rude dude...like they said you are gonna buy a 10 mm wrench, it will most likely have a 11mm on the other side.
The following 2 users liked this post by UlsterBoy13:
EvilVirus (09-14-2016),
Oh Sickest TL (09-14-2016)
seriously, it only takes a few minutes to figure this out. Its not like its a bolt inside the cylinder head that you can't get to until your whole car is apart... Sorry if you are a softy and can't take forum banter, but come on. If you can't figure this out you shouldn't be doing a brake change. Id leave it up to the profeshinals!
oh and 1/4" tubing from all the DIY's on here.
OP, if you don't have a 11mm and ESPECIALLY a 10mm, you have NO business working on your car, the 10mm wrench is the master key on all Honda cars.
Spoonfeeding answers is definitely not something the more veteran members of this site like doing in cases like these where a quick search, or like everyone mentioned, running out there and just putting a wrench on there, or even better, having both on hand would solve.
You're old enough to have some common sense, utilize it.
And if you're unfamiliar with the Googlez, here's how you do it: Let me google that for you
Let a mod close or delete this as to not clog up the site with pointless posts.
It's okay OP, it's the Internet, Here you go, I'll be helpful:
The reason why Service manual specifically says M/T are 11mm is because they use the Brembo 4 piston calipers (same as Type S). The A/T Base TL's will have a regular 2 piston caliper and per the manual, have a 10mm bleeder screw (highlighted above)
I think the confusion is people mainly refer to this page of the SM:
I use my fingers to open and close the bleeder valve, because I'm not a pussy loser
justnspace (09-15-2016)
So Jawknee posts the same page I linked to and Jefe says he did all the hard work?! Fml...I suppose it's cuz I am foreign right? And I don't drive a Datsun? And I don't know what size socket to use to make my emblem glow??
i hate you all
i hate you all
EvilVirus (09-15-2016),
also i didn't see your post and just went through the entire SM to post it for OP
It's because you blocked me isn't it??? And no one quoted my helpful post!!!
i forgive you!
i forgive you!
who's talking?
RIP AltarBoi
In the ass!!!
We are dick heads, so suck us
We don't just give out answers
But if you want some tips
We'll give it to you
#justthetip
#justthetip
EvilVirus (02-04-2019)
Latent car nut
Received 2,005 Likes
Time to put your Nomex on dude, the stunt you just pulled is not going to gain you many friends.
