'05 TL to '08 Type-S parts compatability
2011 ZCP E92 M3!!
which parts will install and function right?
right now im trying to do the steering wheel and the guage
dose anyone know if it will work?
all post any other type-s parts that u installed or know will work on a 05 base
so far i changed: front bumper and added front lip
rear bumper and added rear lip
exaust
headlight and taillights
spoiler
front grille
exaust
spoiler
front grille
exaust
spoiler
front grille
exaust
spoiler
front grille
As far a gauges, the wires are different and the controls are different as well. You would need to rewire the whole thing and pray it works.
With all the money you spend upgrading, you could have bought a TL-S and had the 3.5L!
As per the announcement in the performance section, your thread has been as well moved to the main section.
2011 ZCP E92 M3!!
i know but my 05 got totaled and got 20 k plus the car as salvaged...so i fix it for 8500 with all type s exterior parts...and mufflers....now im jus trying to add sum other stuff...want to buy the type s but probli wont...i rather save up more for the 09 m3 =D
Pm me man, i wanna ask some questions about your conversion please...or email me MYWS62FAST4U@YAHOO.COM
exaust
spoiler
front grille
exaust
spoiler
front grille
The can fit, you just have to have the right amount of money. the wheel can be put on, but you will need to rewire the plugs for the controls on the wheel and as well you will need a new airbag from the 07's.
What's the point for all this really?
'10 Hyundai Genesis Coupe
2011 ZCP E92 M3!!
the seat covers for just the 2 front seats would cost abot 1700...i think if u get lucky enough to find it in a junk yard it would really cheap...but i doubt u wud find a type s in any junk yard..mine already has a navi...i wanna change the guages but im not sure if it work right
Ryan Christopher
I bought the car new in 05 and there was no Type-S option at that time. There are plenty of reasons why someone would just upgrade what they have, rather then buy another.
The point is that people like the look and want theirs to look like it without going out to buy the car. In my case, it is much cheaper to upgrade the parts from the Type-S, rather then taking on a $650 car note for the Type-S. As you can tell from the sig, I was upgrading long before the Type-S was available.
I have car ADD
This fits
- Exhaust
- Pre-Cats
- Suspension (TL-S is slightly stiffer)
- Rear Sway Bar
- Brembo Brakes (need a few extra parts)
- Seats
- Door Panels
- Body Bumpers/Panels
- Headlights (04-05 TL need different Ballasts & Blinkers)
- Taillights
- Side Markers
- Side Mirrors (little modification needed)
- Fog lights (little modification needed)
Does NOT fit
- Gauges
- Direct engine swap (07+ UA7 has different tranny)
- Exhaust
- Pre-Cats
- Rear Sway Bar
- Seats
- Door Panels
- Taillights
- Side Markers
Does NOT fit
- Gauges
I have car ADD
Yes, brand new list price vs. list price, Rotora is Cheaper and larger...
The only thing that comes to mind for me is...
There is no difference between the OEM 5AT vs 6MT brake hydraulic system.. .same M/C same VSA module, same EBD.... but the 6MT uses a different ABS sensor.... so if you are putting the larger Rotora Kit on the car, one would think using the ABS sensor from the 6MT might prove to help
5AT brakes are MORE likely to go into ABS, then the Brembos.... even though Rotora Kit is design for the 5AT, and is "supposed" to work flawlessly... i think adding an ABS sensor from a 6MT/Type-S might help the Rotora Kit work more effectively on your 5AT car
2011 ZCP E92 M3!!
wat do u mean by rewire the plugs for the steering wheel? will i need some other parts other than the full steering wheel?
94 DC4 RS LSV/Turbo
if you are good at wiring yes, you need a module that I beleive is in the tl-s and you need to buy all those connections... good luck it won't be cheap unless you have a totaled tl-s at ur local junkyard (I might have seen a tl-s in a junkyard earlier today... I can check if you really want anything off it)
Hau_nguyen91
03-25-2016 10:39 PM
