05' Honda Pilot 3.5 heads on 05' Acura TL
Old 04-08-2018, 01:53 AM
cast.aluminum's Avatar
would this work? would the 3.5 heads mate up without a problem to the 3.2 block? My valves went and I need new heads. I've seen quite a few Honda Pilot heads but not too many TL heads. I was wondering.
Old 04-08-2018, 01:12 PM
thisaznboi88's Avatar
Yes t will fit use the pilot gasket. Or you can buy ported tls heads with no camshaft
Old 04-09-2018, 08:39 AM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Are you high Aznboi? Where have you seen a pilot J35 head on a TL J32 block? I wouldn't for any number of variances.
Old 04-09-2018, 08:22 PM
Are you stupid? I seen it done before it’s the same damn head and are like 50 a pop if you are lucky and quick and easy fix for bent the valves. It’s not like you are replaced a tls heads with a crappy head. Same goes for the odyssey heads.
Its the same bore 89mm it’s not like you are replacing the monoport exhaust with individual port per cylinder heads like the j35a4, j32a2
Old 04-09-2018, 08:52 PM
Majofo's Avatar
If it's a direct match, then why would you need to use the pilot gasket?
Old 04-10-2018, 05:21 PM
wait..haha so does it match up or not. now I'm scared
JarrettLauderdale
04-29-2022 06:20 AM
cky03
10-02-2007 05:22 PM
Dan
Motorsports News
10-04-2006 12:50 PM
BadgerNation
09-15-2004 08:49 PM
ferrari527
08-05-2003 04:00 PM
Quick Reply: 05' Honda Pilot 3.5 heads on 05' Acura TL
