'04-'06 ABS/VSA modulators should be recalled- complain to the NHTSA
410,000 Odyssey's and Element's are being recalled because the brakes fail because the VSA/ABS modulators leak air into the system.
http://www.google.com/hostednews/ap/...xFiRwD9EFSEIG3
Acura/Honda has been aware of the exact same problem with the RL, TL and TSX for 2.5 years and all they've done is issue a TSB for our cars.
http://www.in.honda.com/Rjanisis/pubs/SB/B07-041.PDF
Interesting....Here's the link from the HondaLink homepage:
http://www.ahm-ownerlink.com/mainten...ent_recall.asp
It gives a little more info. The air gets in during the VSA self-check, so one must assume this happens each time we start our cars. I personally have never had a problem, but it kind of concerns me that the potential for brake failure/reduced performance exists for our cars based on a designed operational procedure.
Wonder if the 3G VSA modulator-control part numbers cross-reference with the Honda VSA M-C part numbers?
I have a problem where the brake pedal goes closer to the floor as you're slowing down, each time the trans downshifts. I figured it might be a bad brake booster.
Now I'm wondering if this is what I'm experiencing from the wording of the Odyssey recall:
"gradually exhibit a pedal height that gets lower (closer to the floor) before the vehicle stops."
soft pedal can be needs fluid flush- moisture gets absorbed from the air and makes pedal feel funny plus detroys brake parts
acura says start flushing brake fluid at year 3, smart people do it every year
That will give an overall weaker feel as moisture compresses and brake fluid does not.
If you have a weakening feeling while stopping- make an appt with the dealer
There are a number of secret warrantys- where a TSB may say if certain things found it becomes warranty...
I have car ADD
It almost killed me 2 years ago.....
https://acurazine.com/forums/3g-tl-2004-2008-93/umm-curse-continues-part-6-blackura-no-more-622819/
After having the master cylinder replaced several times, and Acura not being able to fix my complaints.. i upgraded to a BBK thinking it would resolve my problems....
after my wreck, insurance investigators discovered i had a faulty VSA modulator, and it was pumping air into the lines, which kept busting the seal on the Master Cylinder. it also kept clogging the drivers side brake line.
The TSB was released from Acura 2 days before my accident
Full of water...
i have something similar to this too, but i want to say i have always had this issue...3 years now. on my way home i have a pretty steep road that has a stop sign at the bottom. i slowly press the brake to slow, not too firm, then it kinda automatically goes further down and engages MUCH firmer. not sure if this has something to do with the angle of the car and it feeling like i am not braking hard enough so it helps me out. definitely something i want to keep an eye out for...thanks for bringing this to our attention again!!!
I have car ADD
Here is a link to the TSB
https://acurazine.com/forums/3g-tl-problems-fixes-114/new-tsb-04-06-tl-brakes-623310/
It was released July 31st 2007... I wrecked my car July 24th
iWhine S/C 6MT TL
Indeed they should! Ever fucking time I have an ABS event my brake pedal feels spongy and like total crap. In which the only fix is bleed my brakes during lunch.. Which makes it even more a pain in the ass are the brembo brakes because of the clear coat finish on the calipers. You have to really take your time and watch where the brake fluid goes other wise say good bye to the clear on those fancy calipers.
They're supposed to have a list of affected models after April 13. If the RL, TL and TSX aren't included by then, I plan on contacting Associated Press and seeing if they're aware of the TSB. Someone should put pressure on these manufacturers. It's enough that the quality on these cars is shit without major issues like this one.
i had this problem early last year where my pedal would just go down to the floor, and it would take some pumping to build pressure in order for the brakes to slow down/stop the car...
since my car is under warranty, i took it into Acura telling them i suspect it was a bad master cylinder leak... i got an 09 loaner and my service mgr calls me to tell me that the VSA/ABS module is defective... pumping air into the master cylinder as the TSB states... they replaced the module for me, flushed the brake fluid, and it has been okay ever since...
i still remind myself to be aware of my braking though, after i spoke to blakura and read that this similar problem almost got him killed...
F-SPORT
Back in 07 or 08 when i went in for service for my 06 TL the service guy told me that my brakes are soft, and they told me if i had to push harder to brake and i told them everything seem kinda normal to me, but they found something wrong with my brakes and they went ahead and did the change for me while i was there!
https://acurazine.com/forums/showthread.php?t=622819
Have had the same problem. Car was at the dealers for about 3 days and at the end they tell me that i needed to have bleed the brakes and put lubricant on the caliper slide pins. I said B.S. did what they suggested and it was better, i'll give them some credit. Then slowly it's been getting worse and worse. Just printed the TSB and will be dropping the car off once again and hope this time they solve the issue.
Hi there,
I'm wondering how to get more information about this problem found in your post about the VSA modulator=control unit?(The Honda link doesn't work!) More:
After a hard ABS stop, I noticed my brakes were much softer than usual. After doing some internet digging and found this thread and TSB. I have an 05 TL with 78000 miles that I bought certified almost three years ago. I am planning on calling the dealer where I bought my car from, and hoping for a goodwill TSB repair. Any tips on how to negotiate a free repair?
I don't understand how a simple lower ball joint job where I had to remove the calipers could go so bad.
I am definitely going out to the NTSB site to register a complaint, but I wanted to check here about other Acuras with VSA problems.
In July '14 I took my '05 MDX in to the dealer for the most recent VSA recall.
Approximately 5 weeks later, I experienced what appeared to be my Antilock Brakes engaging quickly for a short burst, first on the driver side, for about 10 quick pulses. It felt as though I had driven over the small lane bumps, but there was nothing in the road. This was when the VSA warning light and triangle appeared. Later that day when I returned to my car, the light was not on, but within 5 miles, the same thing happened again, this time coming from the passenger side. The light has been on since that time.
This sounds like the problem that was occurring that the recall was supposed to fix (which I was not having any problem until after they "fixed" my car).
Of course I took it back to the dealer to have the computer codes read and diagnose the problem. They performed the diagnostics and did the troubleshooting protocol and could not find anything wrong. The next step in the diagnosis is to replace the VSA / ABS module with a known working unit - which will cost $1500 for just the part and $500 for labor. Of course this part almost NEVER goes bad, so they don't have it on hand and I would have to order it. And, they don't even know if this will fix the problem, it's just the next step in the diagnosis.
The dealer does not believe that it is related to the recall work that was just done, but I do not see how it just happens to have a problem with a part that almost never breaks so soon after it was patched. I contacted Acura and of course they reached out to the dealer and say that it isn't their problem.
Has anyone else had this problem? I love this car, but $2k and it might not even fix the problem?
Thanks, Linda
PS. The day I picked it up after the recall service, the rear view mirror had a bubble in it. I know that this is a common problem, but really bad timing for it to happen. Oh, and I've had 2 vent clips break off. Sigh.
Thanks, Linda
For the last few weeks my brake pedal has been slipping halfway to the floor before engaging.
When I push the brake pedal it seems to have no pressure, goes down about halfway, and finally activates the brakes. Once it engages, it never slips any further and holds pressure; however, the pedal is at least halfway if not more of the way down. If I let the pedal go and try it again, the pedal usually engages normally. Later on, it randomly happens again where it slips half way down. This is super scary when I go to brake and feel as if I have no brakes.
I'm not familiar with TSB's. Is it free for me to have my car inspected for this issue and does it cost me anything if they agree this is the issue?
Registered Bunny
This isn't really related to the topic, if you don't have one in the Problems & Fixes you should create one there. We can help you there.
SUPRMN84
10-07-2015 09:46 PM
HeloDown
09-08-2015 06:51 PM
