Notices
Where is an easily accessible vacuum line?
Old 08-28-2018, 12:06 AM
New Member
Just finalizing a deal for a 2014 RLX SHAWD with 80k KM on it. I want to use CRC intake valve cleaner and the easiest way is through a vacuum line (or so im told) like the brake booster what would be the easiest line to access and where would it be. Also would love recommendations if there are easier/better ways to do this.
RLXSH-AWD is offline
Old 08-28-2018, 09:11 AM
▒JDM ¥ KING▒
MuGen7Modulo's Avatar
I don't think you have to do that at all.
MuGen7Modulo is offline
justnspace (08-28-2018)
Old 08-28-2018, 09:14 AM
Received 14,050 Likes on 10,443 Posts
the manifold operates under vaccuum.
however, agreed with Mugen7, there is absolutely no need to use it.
by design, the manifold gets dirty from the EGR and PCV. your cleaning endeavor will be futile because the manifold is designed to get dirty.
justnspace is offline
Old 08-28-2018, 03:16 PM
Registered Member
moose66's Avatar
Just curious . . . . . .what would cleaning it do? Does it function differently clean?
moose66 is offline
Old 08-29-2018, 07:01 AM
Registered Member
miner's Avatar
Plus, if cleaner is ingested too quickly bad things can happen.
miner is offline
Old 08-29-2018, 07:08 AM
the PCV and EGR are designed to recirculate back into the intake manifold, depositing an oily film and some carbon chunks.
in theory; a clean manifold will create less air turbulence from less carbon deposits.
One can keep the intake manifold clean by adding an oil separator, otherwise known as an oil catch can.
moose66 (08-29-2018)
Old 08-29-2018, 08:07 AM
Registered Member
moose66's Avatar
So what's the true benefit? Increased performance? Better gas mileage? OP, forgive me for hijacking your post to get educated.
moose66 is offline
Old 08-29-2018, 08:30 AM
in theory; marginal power increase. Keeping things clean for optimal air flow.
in real world applications; there is no perceived increase in power, mpg, etc, other than piece of mind that your intake manifold is clean.
Old 08-30-2018, 01:43 PM
neuronbob's Avatar
Received 3,503 Likes on 1,766 Posts
I'm learning here, too. Welcome to AZ, OP!
neuronbob is offline
Old 09-01-2018, 10:06 AM
Grandpa
George Knighton's Avatar
Received 2,506 Likes on 1,413 Posts
Originally Posted by RLXSH-AWD View Post
I want to use CRC intake valve cleaner....
I'd like to ask you to please not do this, unless the dealer has identified a specific problem (which he should solve himself, and in a different way).
The injection system of the J Motor in the SH-AWD is unique, and it in fact uses hybrid injection systems depending on what it is you are doing and what you are demanding of the motor. Usually, you will find this kind of drivability enhancement in cars costing many thousands more, and we should leave it alone.
In the discussions related to the long term viability of this system, dealer representatives are advised not to expect anything to do along those lines...for hundreds of thousands of miles.
George Knighton is offline
The following 4 users liked this post by George Knighton:
hondamore (09-01-2018), MuGen7Modulo (09-01-2018), neuronbob (09-03-2018), pgeorg (09-02-2018)
Old 09-01-2018, 12:52 PM
▒JDM ¥ KING▒
RLXSH-AWD, just listen to George. Plain and simple... "J Motor in the SH-AWD is unique"
knice
Second Generation TL (1999-2003)
07-27-2015 09:49 AM
BillG49
Second Generation RL (2005-2012)
05-01-2012 10:04 PM
JayK
08-31-2011 07:06 PM
yoolykeme
Home Theater & Electronics
02-12-2007 03:23 PM
CLPowersWife
Ramblings
09-27-2006 03:31 PM
Quick Reply: Where is an easily accessible vacuum line?
