What does these lights means on my 2014 acura rlx dash?
all these lights pops up on my instrument panel for a couple days and then dissapears. it reads: "Vehicle Stability Assist (VSA) problem,Forward collision warning (FCW) Electric Power steering problem, Brake System, & Hill Assist Problem
Might be time to have your battery checked or replaced. Either way I would go to the dealer and have diagnostics performed. My SH had a similar issue when delivered, I replaced the battery and have never seen the lights again. |
I had the same experience as AP8ESQ. My Sport Hybrid sat on the lot for a long time and after I took delivery, when I started the car, I got several warning lights and eventually the car would not start . They replaced the battery and I haven't had a problem in the three years since then.
While this diagnosis of your problem is anecdotal, replacing the battery is probably the best place to start. Good luck - let us know how the problem was resolved. |
Originally Posted by AP8ESQ
(Post 16265145)
W!elcome to the forums. I deleted your other thread since it asked the same question but all you got there was a bunch of wiseguys answering with crap replies.
I added the Hill Assist Problem to this thread. |
Originally Posted by Ron A
(Post 16265167)
I can also attest that is the battery that needs to be checked first. I saw this happening to a RLX when I went for a test drive recently.
Originally Posted by MuGen7Modulo
(Post 16265269)
A new [sic] battery might've sat around too long. Whether it's the battery or something else, these cars are probably a little too complicated to do anything other than have the dealer look over it. IMHO. |
Originally Posted by George Knighton
(Post 16265363)
What he said. :-)
(Post 16265363)
What he said. :-)
(Post 16265145)
update: I just ran a battery test & the battery is good! |
Another problem that can trip those lights, is when the rear wheels actuators are not working properly.
That is for the RLX P-AWS, and they control the rear wheel steering. |
Funny timing! My wife just texted me saying that she was taking our 2014 RLX ELITE out of the garage and got these 3 warnings : lane keeping assist problems; lane departure warning problem and adaptive cruise control problem.... any idea on what that might be? |
Originally Posted by Ysl_Sly
(Post 16265942)
thanks just got the battery checked, it is in great condition!
By any chance had the car been sitting for a couple of days when the warning lights came on?? That seems to be part of the pattern when the battery is the issue. As pgeorg mentioned, other problems could be at fault, but a charging system/battery issue is still my first guess. Good luck getting to the bottom of this. Seeing all those warning lights is certainly disconcerting to say the least. |
Originally Posted by Kgb2016
(Post 16267239)
Funny timing! My wife just texted me saying that she was taking our 2014 RLX ELITE out of the garage and got these 3 warnings : lane keeping assist problems; lane departure warning problem and adaptive cruise control problem.... any idea on what that might be? Good luck |
https://cimg8.ibsrv.net/gimg/acurazi...42ef807d6.jpeg https://cimg1.ibsrv.net/gimg/acurazi...094d8864f.jpeg https://cimg3.ibsrv.net/gimg/acurazi...d17bd2a44.jpeg The car is spotless -cleaned and detailed just a few days ago. I checked the front grill and there are no any dirt there. After driving to Costco and starting the car again, all lights were out and no more warnings. Weird thing! I’m still taking it to the dealer on Monday just in case. I don’t think it’s a battery issue since only certain light came on. thank you for your input! Much appreciated! |
An update: dealer run all kind of tests and found one more faul code - dirty radar sensor. Cleaned it up, said that there wasn’t actually any dirt or derbies there. Cleared the codes. That was on Monday, since than - nothing. They also checked the battery and it was fine. So I hope that was just a glitch... |
Warning sign on my dash board
My 2014 Acura RLX has a warning sign on the dash.
VSA, Precision all wheel steer problem, forward collusion warning and Lane departure warning issues. |
As you can see from the prior posts in this thread, I would get your battery checked/replaced ASAP as that is the likely culprit. I just went thru this same ordeal in my 2014 Advance and it was in fact the battery needing replacing. OBTW, I bought the battery at Costco ( Interstate with unconditional 3 yr. warranty out the door for $105).
You will have to remove old battery yourself and replace with new as Costco does not do installations any longer nor do they have charging circuit testing capability, so I used my dealer to provide confirmation charging components were not the problem. Good Luck!!! Demosan |
Dashboard light error
(Post 16265088)
