2014 Acura RLX Technical Service Bulletins
Forum Contributor
Received 1,391 Likes
2014 Acura RLX Technical Service Bulletins:
TSB 13-002 - 2014 RLX: TQI and New Model Service Information
Applies To: 2014 RLX - ALL
http://www.urvi.net/forumfiles/SB/B13-002.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/B13-002.PDF
TSB 13-001 - 2014 RLX: TQI of the Navigation System
Applies To: 2014 RLX With Navigation – ALL
http://www.urvi.net/forumfiles/SB/B13-001.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/B13-001.PDF
TSB 14-004 - 2014 RLX Sport Hybrid: TQI and New Model Service Information
Applies To: 2014 RLX Sport Hybrid - Technology, Advance
http://www.urvi.net/forumfiles/SB/B14-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-004.PDF
TSB 14-005 - 2014 RLX Sport Hybrid: TQI of the Navigation System
Applies To: 2014 RLX Sport Hybrid - ALL
http://www.urvi.net/forumfiles/SB/B14-005.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-005.PDF
TSB 12-012 - IMA Battery Exchange Program
Applies To: 2014, 2016 RLX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B12-012.PDF
http://techinfo.honda.com/rjanisis/p...nu/B12-012.PDF
TSB 13-008 - Product Update: Audio-Navigation Unit Software Update
Applies To: 2014 RLX (excluding Sport Hybrid) - ALL with navigation - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B13-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B13-008.PDF
TSB 13-026 - A/C Moans From the Engine Area
Applies To: 2014 RLX – From VIN JH4KC1F..EC000001 thru JH4KC1F..EC003549
http://www.urvi.net/forumfiles/SB/B13-026.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-026.PDF
TSB 13-033 - Center Console Armrest Has Wrinkle-like Streaks
Applies To: 2014 RLX – From VIN JH4KC1F..EC000001 thru JH4KC1F..EC006662
http://www.urvi.net/forumfiles/SB/B13-033.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-033.PDF
TSB 13-041 - P-AWS RTC Actuators Moan When Making Small Turns
This bulletin has been replaced by either 23-022, Warranty Extension: 2014–19 RLX Rear Toe Control Actuator Moan When Making Small Turns or Warning Lamp Comes ON, or 23-021, Warranty Extension: 2013-14 RLX Rear Toe Control Actuator Moan When Making Small Turns or Warning Lamp Comes ON.
Applies To: 2014-15 RLX - ALL
2016 RLX - From VIN JHK4C1...GC000001 thru JHK4C1...GC000408
http://www.urvi.net/forumfiles/SB/B13-041.PDF
http://techinfo.honda.com/rjanisis/p...nu/B13-041.PDF
TSB 13-043 - Safety Recall: Rear Lower Suspension Arm Bolts May Be Loose
Applies To: 2014 RLX – Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B13-043.PDF
http://techinfo.honda.com/rjanisis/p...nu/B13-043.PDF
TSB 14-007 - Incorrect Folding Mirror Option Appears on MID/Navigation Screen
Applies To: 2014 RLX - Base, Base with Navigation - ALL
http://www.urvi.net/forumfiles/SB/B14-007.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-007.PDF
TSB 14-014 - Vehicles with Navigation: Audio Turns Off After Using HFL, No Sound/Static in Rear Headphones, and Other Listed Issues
http://www.urvi.net/forumfiles/SB/B14-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-014.PDF
TSB 14-021 - Wind Noise At Upper Rear Corner of Driver/ Front Passenger Windows
Applies To: 2014 RLX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-021.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-021.PDF
TSB 14-025 - Timing Belt Chirps
Applies To: 2014-18 RLX - ALL except Sport Hybrid - ALL
2019 RLX - ALL except Sport Hybrid - From VIN JH4KC1...KC000001 thru JHRKC1...KC000064
2014 RLX Sport Hybrid - ALL - ALL
2016-18 RLX Sport Hybrid - ALL - ALL
2019 RLX Sport Hybrid - ALL - From VIN JH4KC2...KC000001 thru JHRKC2...KC000369
http://www.urvi.net/forumfiles/SB/B14-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF
TSB 14-028 - i-MID Reads “12 Volt Battery Charging System Problem” with DTC P16E3
Applies To: 2014 RLX - ALL - From VIN JH4KC1...EC000001 thru JH4KC1...EC007765
http://www.urvi.net/forumfiles/SB/B14-028.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-028.PDF
TSB 14-031 - Steering Column Screeches When Moving
Applies To: 2014-16 RLX - ALL - ALL
2014, 2016 RLX Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-031.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-031.PDF
TSB 14-034 - i-MID Reads “12 Volt Battery Charging System Problem” with DTC P154A
2015 RLX - ALL - From VIN JH4KC1...FC000001 thru JH4KC1...FC000811
http://www.urvi.net/forumfiles/SB/B14-034.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-034.PDF
TSB 14-038 - Safety Recall: Front Seatbelts Will Not Extend or Retract Properly in Extremely Cold Weather
Applies To: 2014 RLX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B14-038.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-038.PDF
TSB 14-040 - Front Suspension Clunk or Rattle When Driving over Bumps
Applies To: 2014-15 RLX (Excluding RLX Sport Hybrid) - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-040.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-040.PDF
TSB 14-047 - Front Door Sash Outer Trim Is Loose, Warped, or Causing a Wind Noise
2014 RLX Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-047.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-047.PDF
TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs
Applies To: 2014-15 RLX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-048.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-048.PDF
TSB 14-051 - Safety Recall: Headlight LED Lens Film Delaminates
Applies To: 2014-15 RLX - ALL - Check the iN VIN status for eligibility
2014 RLX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B14-051.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-051.PDF
TSB 14-052 - MIL Comes On With DTC P2176
Applies To: 2014 RLX - Base, With Navigation, With Technology Package, and With Krell Audio Package - From VIN JH4KC1…EC000001 thru JH4KC1…EC002282
With Advance Package - From VIN JH4KC1F9.EC000001 thru JH4KC1F9.EC002727
http://www.urvi.net/forumfiles/SB/B14-052.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-052.PDF
TSB 15-001 - Vehicles with Navigation: Audio Turns Off After Using HFL, No Sound/Static in Rear Headphones, and Other Listed Issues
Replaces S/B 14-014, Vehicles with Navigation: Audio Turns Off After Using HFL, No Sound/Static in Rear Headphones, and Other Listed Issues
Applies To: 2014 RLX (not Sport Hybrid) - ALL with navigation - ALL
http://www.urvi.net/forumfiles/SB/B15-001.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-001.PDF
TSB 15-015 - Driver’s and/or Front Passenger’s Seat Cushion and Recline Covers Are Loose
http://www.urvi.net/forumfiles/SB/B15-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-015.PDF
TSB 15-017 - AcuraLink System Status Indicator Is Red and DTC B1403 Will Not Clear
Applies To: 2014–15 RLX - ALL with navigation - ALL
2014 RLX Sport Hybrid - ALL with navigation - ALL
http://www.urvi.net/forumfiles/SB/B15-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-017.PDF
TSB 15-022 - I-MID Displays “Camera Too Hot” Message
Applies To: 2014–15 RLX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B15-022.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-022.PDF
TSB 15-023 - HomeLink System Has Weak or Limited Range
Applies To: 2014–16 RLX - ALL - ALL
2014 and 2016 RLX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B15-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-023.PDF
TSB 15-030 - Safety Recall: RLX and RLX Sport Hybrid CMBS Error
Applies To: 2014–15 RLX - Advance - Check the iN VIN status for eligibility
2014 RLX Sport Hybrid - Advance - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B15-030.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-030.PDF
TSB 15-031 - Safety Recall: RLX Sport Hybrid CMBS Error
This bulletin is replaced by S/B 15-030, Safety Recall: RLX and RLX Sport Hybrid CMBS Error
http://www.urvi.net/forumfiles/SB/B15-031.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-031.PDF
TSB 15-032 - Rear Door Sunshades Rattle While Driving
Applies To: 2014-15 RLX - Advanced, Tech Audio - ALL
2014 RLX Sport Hybrid - Advanced - ALL
http://www.urvi.net/forumfiles/SB/B15-032.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-032.PDF
TSB 15-035 - MIL Comes On with DTC P0134 and/or P0154
http://www.urvi.net/forumfiles/SB/B15-035.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-035.PDF
TSB 16-008 - High Pressure Fuel Pump Chirps
Applies To: 2014-18 RLX - ALL - ALL
2014 and 2016-18 RLX Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-008.PDF
TSB 16-011 - Product Update: Monroney Label (Hawaii)
Applies To: 2015-16 RLX - ALL - Check the iN VIN status for eligibility
2014, 2016 RLX Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-011.PDF
TSB 16-016 - Starter Grinds or Spins at Startup
http://www.urvi.net/forumfiles/SB/B16-016.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-016.PDF
TSB 16-049 - Squeal During Electric Parking Brake Operation
http://www.urvi.net/forumfiles/SB/B16-049.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-049.PDF
TSB 16-065 - 2012 RL, 2014–17 RLX: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Applies To: 2014-17 RLX - ALL except Hybrid - ALL
http://www.urvi.net/forumfiles/SB/B16-065.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-065.PDF
TSB 16-066 - 2012 RL, 2014–17 RLX: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B16-066.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-066.PDF
TSB 17-003 - AcuraLink Sending Excessive Notifications for Low Power
http://www.urvi.net/forumfiles/SB/B17-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-003.PDF
TSB 17-019 - MIL Comes On with DTC P0430
This bulletin is replaced by S/B 17-034, MIL Comes on with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank2])
http://www.urvi.net/forumfiles/SB/B17-019.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-019.PDF
TSB 17-032 - A/C High-Pitched Whine
Applies To: 2014-17 RLX - ALL except hybrid - ALL
http://www.urvi.net/forumfiles/SB/B17-032.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-032.PDF
TSB 17-033 - Steering Intermittently Pulls to the Right
Applies To: 2014-17 RLX - ALL - ALL
2014, 2016-17 RLX Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-033.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-033.PDF
TSB 17-034 - MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
Replaces 17-019, MIL Comes On with DTC P0430
2014 RLX Sport Hybrid Only - ALL - ALL
2016 RLX Sport Hybrid Only - ALL - ALL
2017 RLX Sport Hybrid Only - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-034.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-034.PDF
TSB 17-040 - Front Brakes Squeal
Applies To: 2014-17 RLX (non-hybrid) - ALL - ALL
2018 RLX (non-hybrid) - ALL - From VIN JH4KC1...JC000001 thru JH4KC1...JC000553
http://www.urvi.net/forumfiles/SB/B17-040.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-040.PDF
TSB 17-042 - Front Brakes Squealing Noise
Applies To: 2014 RLX Sport Hybrid - ALL - ALL
2016-17 RLX Sport Hybrid - ALL - ALL
2018 RLX Sport Hybrid - ALL - From VIN JH4KC2...JC000000 thru JH4KC2...JC000257
http://www.urvi.net/forumfiles/SB/B17-042.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-042.PDF
TSB 18-029 - Warranty Extension: Customer Support For Front Passenger's Airbag Inflator for 2016-17 RDX, 2014-17 RLX, and 2014, 2016-17 RLX Sport Hybrid (Expires June 30, 2030)
Applies To: 2014-17 RLX - ALL - Check the iN VIN status for eligibility
2014, 2016-17 RLX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-029.PDF
TSB 19-004 - 2014-19 RLX Sport Hybrid and 2017-19 MDX Sport Hybrid: Transmission Judders, Shudders, or Surges While Driving
Applies To: 2014-19 RLX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-004.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2014-20 RLX
2014-20 RLX Sport Hybrid
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-020 - Blower Motor Is Noisy, Runs Slowly, or Intermittently Stops Working
2014, 2016-18 RLX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B20-020.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-020.PDF
TSB 20-040 - Emissions Recall: 2014, 2016-20 RLX Sport Hybrid Odd Gear Monitor Software Update
Applies To: 2014, 2016-20 RLX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B20-040.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-040.PDF
TSB 23-021 - Warranty Extension: Moaning or Rubbing Noise from P-AWS RTC Actuators and/or P-AWS Indicator On With DTC C1600-94, C1611-13, or C1621-13 (Expires 01/31/2024)
Applies To: 2014 RLX - ALL with P-AWS - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-021.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-021.PDF
TSB 23-022 - Warranty Extension: Moaning or Rubbing Noise from P-AWS RTC Actuators and/or P-AWS Indicator On With DTC C1600-94, C1611-13, or C1621-13
Applies To: 2014-19 RLX - ALL with P-AWS - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-022.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-022.PDF
TSB 23-038 - Safety Recall: Multi-Model Acura Fuel Pump Motor Stop Sale
Applies To: 2014 RLX - Advanced - Check the iN VIN status for eligibility
2018-20 RLX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-038.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-038.PDF
http://techinfo.honda.com/rjanisis/p.../B23-038v4.PDF (Link works, but is wrong) Version 4
The following 3 users liked this post by EE4Life:
