Front Brake Pad and Rotor Change
After 31,000 miles I need to change the front brake pads and rotors on my '14 P-AWS. I am starting to feel a vibration in the steering wheel while braking. Where do I locate the jack stands once the car is jacked up? Looks like I must remove several plastic cowlings from underneath the car to access the support points.
You're very welcome NJ-RLX! If you need anything else let me know, and I will post if I can.
Fun fact, the PAWS and SH front rotor and pads are different. I changed all 4 corners at 50,000 in the driveway. Plenty of pad life left, but at least one of the rotors was warped.
Even the front calipers are different......dual piston on the SH, single piston on the P-AWS....
