2017 Acura RLX Technical Service Bulletins
2017 Acura RLX Technical Service Bulletins:
TSB 16-051 - 2017 RLX: TQI Information Applies To: 2017 RLX - With Technology Package, With Advance Package http://www.urvi.net/forumfiles/SB/B16-051.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-051.PDF TSB 16-052 - 2017 RLX: TQI of the Navigation System Applies To: 2017 RLX - All with Navigation http://www.urvi.net/forumfiles/SB/B16-052.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-052.PDF TSB 16-053 - 2017 RLX Sport Hybrid: TQI Information Applies To: 2017 RLX Sport Hybrid - With Technology Package, With Advance Package http://www.urvi.net/forumfiles/SB/B16-053.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-053.PDF TSB 16-054 - 2017 RLX Sport Hybrid: TQI of the Navigation System Applies To: 2017 RLX Sport Hybrid - All http://www.urvi.net/forumfiles/SB/B16-054.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-054.PDF TSB 14-025 - Timing Belt Chirps Applies To: 2014-18 RLX - ALL except Sport Hybrid - ALL 2019 RLX - ALL except Sport Hybrid - From VIN JH4KC1...KC000001 thru JHRKC1...KC000064 2014 RLX Sport Hybrid - ALL - ALL 2016-18 RLX Sport Hybrid - ALL - ALL 2019 RLX Sport Hybrid - ALL - From VIN JH4KC2...KC000001 thru JHRKC2...KC000369 http://www.urvi.net/forumfiles/SB/B14-025.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF TSB 16-008 - High Pressure Fuel Pump Chirps Applies To: 2014-18 RLX - ALL - ALL 2014 and 2016-18 RLX Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B16-008.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-008.PDF TSB 16-065 - 2012 RL, 2014–17 RLX: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required) Applies To: 2014-17 RLX - ALL except Hybrid - ALL http://www.urvi.net/forumfiles/SB/B16-065.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-065.PDF TSB 16-066 - 2012 RL, 2014–17 RLX: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required) Applies To: 2014-17 RLX - ALL except Hybrid - ALL http://www.urvi.net/forumfiles/SB/B16-066.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-066.PDF TSB 17-019 - MIL Comes On with DTC P0430 This bulletin is replaced by S/B 17-034, MIL Comes on with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank2]) http://www.urvi.net/forumfiles/SB/B17-019.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-019.PDF TSB 17-032 - A/C High-Pitched Whine Applies To: 2014-17 RLX - ALL except hybrid - ALL http://www.urvi.net/forumfiles/SB/B17-032.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-032.PDF TSB 17-033 - Steering Intermittently Pulls to the Right Applies To: 2014-17 RLX - ALL - ALL 2014, 2016-17 RLX Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B17-033.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-033.PDF TSB 17-034 - MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2]) Replaces 17-019, MIL Comes On with DTC P0430 Applies To: 2014-17 RLX - ALL - ALL 2014 RLX Sport Hybrid Only - ALL - ALL 2016 RLX Sport Hybrid Only - ALL - ALL 2017 RLX Sport Hybrid Only - ALL - ALL http://www.urvi.net/forumfiles/SB/B17-034.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-034.PDF TSB 17-040 - Front Brakes Squeal Applies To: 2014-17 RLX (non-hybrid) - ALL - ALL 2018 RLX (non-hybrid) - ALL - From VIN JH4KC1...JC000001 thru JH4KC1...JC000553 http://www.urvi.net/forumfiles/SB/B17-040.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-040.PDF TSB 17-042 - Front Brakes Squealing Noise Applies To: 2014 RLX Sport Hybrid - ALL - ALL 2016-17 RLX Sport Hybrid - ALL - ALL 2018 RLX Sport Hybrid - ALL - From VIN JH4KC2...JC000000 thru JH4KC2...JC000257 http://www.urvi.net/forumfiles/SB/B17-042.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-042.PDF TSB 18-029 - Warranty Extension: Customer Support For Front Passenger's Airbag Inflator for 2016-17 RDX, 2014-17 RLX, and 2014, 2016-17 RLX Sport Hybrid (Expires June 30, 2030) Applies To: 2014-17 RLX - ALL - Check the iN VIN status for eligibility 2014, 2016-17 RLX Sport Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B18-029.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-029.PDF TSB 19-004 - 2014-19 RLX Sport Hybrid and 2017-19 MDX Sport Hybrid: Transmission Judders, Shudders, or Surges While Driving Applies To: 2014-19 RLX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B19-004.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-004.PDF TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram Applies To: 2014-20 RLX 2014-20 RLX Sport Hybrid http://www.urvi.net/forumfiles/SB/B19-059.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF TSB 20-020 - Blower Motor Is Noisy, Runs Slowly, or Intermittently Stops Working Applies To: 2014-18 RLX - ALL - ALL 2014, 2016-18 RLX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B20-020.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-020.PDF TSB 20-040 - Emissions Recall: 2014, 2016-20 RLX Sport Hybrid Odd Gear Monitor Software Update Applies To: 2014, 2016-20 RLX Sport Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B20-040.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-040.PDF TSB 23-022 - Warranty Extension: Moaning or Rubbing Noise from P-AWS RTC Actuators and/or P-AWS Indicator On With DTC C1600-94, C1611-13, or C1621-13 Applies To: 2014-19 RLX - ALL with P-AWS - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B23-022.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-022.PDF |
Added new TSB 23-022 - Warranty Extension: Moaning or Rubbing Noise from P-AWS RTC Actuators and/or P-AWS Indicator On With DTC C1600-94, C1611-13, or C1621-13.
