2016 RLX HardCopy Owner's Manual
So after half a year of trying I finally got a complementary hardcopy (paper) owner's manual for my 2016 RLX and started reading. Although I still don't know the difference between LDW and LDM and LKAS .... here are two good "hacks" I learned so far. You guys probably already know them ... but wonder what other RLX hacks are out there.
1 - The little "A" on the air conditioner recirculating function indicates optimized automatic mixing of fresh air (from outside the cabin) and recirc air (inside) based on inside temperature and outside temperature. You can select normal recirc (all inside air) or "A" recirc depending on what suits you best.
2 - of course we all know that if you push (or pull) then release the steering wheel horizontal audio wheel right (or left) it advances the XM radio station one programmed channel ...but if you push/pull and hold it in place without releasing it will advance the XM channel 1 single channel forward (or back). Same for normal FM radio.
What else ya' got?
What else ya' got?
The following 3 users liked this post by Scott in AZ:
What else ya' got?
What else ya' got?
