2016 Acura RLX Technical Service Bulletins - AcuraZine - Acura Enthusiast Community
Notices
Old 07-28-2018, 05:37 PM
Forum Contributor
EE4Life's Avatar
2016 Acura RLX Technical Service Bulletins:
TSB 15-014 - 2016 RLX: TQI Information
Applies To: 2016 RLX - With Technology and AcuraWatch Plus Packages, With Advance Package, With Navigation Package (Special Order Only)
http://www.urvi.net/forumfiles/SB/B15-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-014.PDF
TSB 15-008 - 2016 RLX: TQI of the Navigation System
Applies To: 2016 RLX - All with Navigation
http://www.urvi.net/forumfiles/SB/B15-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-008.PDF
TSB 15-025 - 2016 RLX Sport Hybrid: TQI and New Model Service Information
Applies To: 2016 RLX Sport Hybrid - With Technology Package, With Advance Package
http://www.urvi.net/forumfiles/SB/B15-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-025.PDF
TSB 15-026 - 2016 RLX Sport Hybrid: TQI of the Navigation System
Applies To: 2016 RLX Sport Hybrid - All
http://www.urvi.net/forumfiles/SB/B15-026.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-026.PDF
TSB 12-012 - IMA Battery Exchange Program
Applies To: 2014, 2016 RLX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B12-012.PDF
http://techinfo.honda.com/rjanisis/p...nu/B12-012.PDF
TSB 13-041 - P-AWS RTC Actuators Moan When Making Small Turns
Applies To: 2014-15 RLX - ALL
2016 RLX - From VIN JHK4C1...GC000001 thru JHK4C1...GC000408
http://www.urvi.net/forumfiles/SB/B13-041.PDF
http://techinfo.honda.com/rjanisis/p...nu/B13-041.PDF
TSB 14-025 - Timing Belt Chirps
Applies To: 2014-15 RLX - ALL except Hybrid - ALL
2016 RLX - ALL except Hybrid - From VIN JH4KC1...GC000001 thru JH4KC1...GC000922
2014 RLX Sport Hybrid - ALL - ALL
2016 RLX Sport Hybrid - ALL - From VIN JH4KC2...GC000001 thru JH4KC2...GC00017
http://www.urvi.net/forumfiles/SB/B14-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF
TSB 14-031 - Steering Column Screeches When Moving
Applies To: 2014-16 RLX - ALL - ALL
2014, 2016 RLX Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-031.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-031.PDF
TSB 15-023 - HomeLink System Has Weak or Limited Range
Applies To: 2014–16 RLX - ALL - ALL
2014 and 2016 RLX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B15-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-023.PDF
TSB 16-008 - High Pressure Fuel Pump Chirps
Applies To: 2014-18 RLX - ALL - ALL
2014 and 2016-18 RLX Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-008.PDF
TSB 16-011 - Product Update: Monroney Label (Hawaii)
Applies To: 2015-16 RLX - ALL - Check the iN VIN status for eligibility
2014, 2016 RLX Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-011.PDF
TSB 16-016 - Starter Grinds or Spins at Startup
http://www.urvi.net/forumfiles/SB/B16-016.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-016.PDF
TSB 16-024 - Center Console Lid Will Not Automatically Slide Close with Release Button
Applies To: 2016 RLX - ALL - From VIN JH4KC1F...GC000001 thru JH4KC1F...GC000408
2016 RLX Sport Hybrid - ALL - From VIN JH4KC2F...GC000001 thru JH4KC2F...GC000005
http://www.urvi.net/forumfiles/SB/B16-024.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-024.PDF
TSB 16-049 - Squeal During Electric Parking Brake Operation
http://www.urvi.net/forumfiles/SB/B16-049.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-049.PDF
TSB 16-065 - 2012 RL, 2014–17 RLX: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Applies To: 2014-17 RLX - ALL except Hybrid - ALL
http://www.urvi.net/forumfiles/SB/B16-065.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-065.PDF
TSB 16-066 - 2012 RL, 2014–17 RLX: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B16-066.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-066.PDF
TSB 17-003 - AcuraLink Sending Excessive Notifications for Low Power
http://www.urvi.net/forumfiles/SB/B17-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-003.PDF
TSB 17-006 - Cruise Control Operation Cancelled When Engine Comes On
Applies To: 2016 RLX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-006.PDF
TSB 17-019 - MIL Comes On with DTC P0430
This bulletin is replaced by S/B 17-034, MIL Comes on with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank2])
http://www.urvi.net/forumfiles/SB/B17-019.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-019.PDF
TSB 17-032 - A/C High-Pitched Whine
Applies To: 2014-17 RLX - ALL except hybrid - ALL
http://www.urvi.net/forumfiles/SB/B17-032.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-032.PDF
TSB 17-033 - Steering Intermittently Pulls to the Right
Applies To: 2014-17 RLX - ALL - ALL
2014, 2016-17 RLX Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-033.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-033.PDF
TSB 17-034 - MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
Replaces 17-019, MIL Comes On with DTC P0430
2014 RLX Sport Hybrid Only - ALL - ALL
2016 RLX Sport Hybrid Only - ALL - ALL
2017 RLX Sport Hybrid Only - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-034.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-034.PDF
TSB 17-040 - Front Brakes Squeal
Applies To: 2014-17 RLX (non-hybrid) - ALL - ALL
2018 RLX (non-hybrid) - ALL - From VIN JH4KC1...JC000001 thru JH4KC1...JC000553
http://www.urvi.net/forumfiles/SB/B17-040.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-040.PDF
TSB 17-042 - Front Brakes Squealing Noise
Applies To: 2014 RLX Sport Hybrid - ALL - ALL
2016-17 RLX Sport Hybrid - ALL - ALL
2018 RLX Sport Hybrid - ALL - From VIN JH4KC2...JC000000 thru JH4KC2...JC000257
http://www.urvi.net/forumfiles/SB/B17-042.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-042.PDF
TSB 18-029 - Warranty Extension: Customer Support For Front Passenger's Airbag Inflator for 2016-17 RDX, 2014-17 RLX, and 2014, 2016-17 RLX Sport Hybrid (Expires June 30, 2030)
Applies To: 2014-17 RLX - ALL - Check the iN VIN status for eligibility
2014, 2016-17 RLX Sport Hybrid - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-029.PDF
TSB 19-004 - 2014-19 RLX Sport Hybrid and 2017-19 MDX Sport Hybrid: Transmission Judders, Shudders, or Surges While Driving
Applies To: 2014-19 RLX Sport Hybrid - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-004.PDF
EE4Life is offline
The Following User Says Thank You to EE4Life For This Useful Post:
MuGen7Modulo (07-30-2018)
Old Today, 07:32 PM
Forum Contributor
EE4Life's Avatar
Added new TSB 19-004 - 2014-19 RLX Sport Hybrid and 2017-19 MDX Sport Hybrid: Transmission Judders, Shudders, or Surges While Driving.
EE4Life is offline
EE4Life
Third Generation RLX (2013+)
Today 07:32 PM
EE4Life
Today 07:32 PM
EE4Life
Today 07:32 PM
EE4Life
Acura ILX Discussion
08-16-2018 10:17 AM
EE4Life
Second Generation RDX (2013-2018)
34
06-15-2018 08:20 PM
Quick Reply: 2016 Acura RLX Technical Service Bulletins
© 2018 MH Sub I, LLC dba Internet Brands
