2015 Acura RLX Technical Service Bulletins
2015 Acura RLX Technical Service Bulletins:
TSB 14-019 - 2015 RLX: TQI Information Applies To: 2015 RLX - Base, With Navigation, With Technology Package, With Krell Audio Package, With Advance Package http://www.urvi.net/forumfiles/SB/B14-019.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-019.PDF TSB 14-020 - 2015 RLX: TQI of the Navigation System Applies To: 2015 RLX - All with Navigation http://www.urvi.net/forumfiles/SB/B14-020.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-020.PDF TSB 13-041 - P-AWS RTC Actuators Moan When Making Small Turns This bulletin has been replaced by either 23-022, Warranty Extension: 2014–19 RLX Rear Toe Control Actuator Moan When Making Small Turns or Warning Lamp Comes ON, or 23-021, Warranty Extension: 2013-14 RLX Rear Toe Control Actuator Moan When Making Small Turns or Warning Lamp Comes ON. Applies To: 2014-15 RLX - ALL 2016 RLX - From VIN JHK4C1...GC000001 thru JHK4C1...GC000408 http://www.urvi.net/forumfiles/SB/B13-041.PDF http://techinfo.honda.com/rjanisis/p...nu/B13-041.PDF TSB 14-025 - Timing Belt Chirps Applies To: 2014-18 RLX - ALL except Sport Hybrid - ALL 2019 RLX - ALL except Sport Hybrid - From VIN JH4KC1...KC000001 thru JHRKC1...KC000064 2014 RLX Sport Hybrid - ALL - ALL 2016-18 RLX Sport Hybrid - ALL - ALL 2019 RLX Sport Hybrid - ALL - From VIN JH4KC2...KC000001 thru JHRKC2...KC000369 http://www.urvi.net/forumfiles/SB/B14-025.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF TSB 14-031 - Steering Column Screeches When Moving Applies To: 2014-16 RLX - ALL - ALL 2014, 2016 RLX Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B14-031.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-031.PDF TSB 14-034 - i-MID Reads “12 Volt Battery Charging System Problem” with DTC P154A Applies To: 2014 RLX - ALL - ALL 2015 RLX - ALL - From VIN JH4KC1...FC000001 thru JH4KC1...FC000811 http://www.urvi.net/forumfiles/SB/B14-034.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-034.PDF TSB 14-040 - Front Suspension Clunk or Rattle When Driving over Bumps Applies To: 2014-15 RLX (Excluding RLX Sport Hybrid) - ALL - ALL http://www.urvi.net/forumfiles/SB/B14-040.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-040.PDF TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs Applies To: 2014-15 RLX - ALL - ALL 2014 RLX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B14-048.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-048.PDF TSB 14-051 - Safety Recall: Headlight LED Lens Film Delaminates Applies To: 2014-15 RLX - ALL - Check the iN VIN status for eligibility 2014 RLX Sport Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B14-051.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-051.PDF TSB 15-015 - Driver’s and/or Front Passenger’s Seat Cushion and Recline Covers Are Loose Applies To: 2014-15 RLX - ALL - ALL 2014 RLX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B15-015.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-015.PDF TSB 15-017 - AcuraLink System Status Indicator Is Red and DTC B1403 Will Not Clear Applies To: 2014–15 RLX - ALL with navigation - ALL 2014 RLX Sport Hybrid - ALL with navigation - ALL http://www.urvi.net/forumfiles/SB/B15-017.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-017.PDF TSB 15-022 - I-MID Displays “Camera Too Hot” Message Applies To: 2014–15 RLX - ALL - ALL 2014 RLX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B15-022.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-022.PDF TSB 15-023 - HomeLink System Has Weak or Limited Range Applies To: 2014–16 RLX - ALL - ALL 2014 and 2016 RLX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B15-023.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-023.PDF TSB 15-030 - Safety Recall: RLX and RLX Sport Hybrid CMBS Error Applies To: 2014–15 RLX - Advance - Check the iN VIN status for eligibility 2014 RLX Sport Hybrid - Advance - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B15-030.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-030.PDF TSB 15-031 - Safety Recall: RLX Sport Hybrid CMBS Error This bulletin is replaced by S/B 15-030, Safety Recall: RLX and RLX Sport Hybrid CMBS Error http://www.urvi.net/forumfiles/SB/B15-031.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-031.PDF TSB 15-032 - Rear Door Sunshades Rattle While Driving Applies To: 2014-15 RLX - Advanced, Tech Audio - ALL 2014 RLX Sport Hybrid - Advanced - ALL http://www.urvi.net/forumfiles/SB/B15-032.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-032.PDF TSB 15-035 - MIL Comes On with DTC P0134 and/or P0154 Applies To: 2014–15 RLX - ALL - ALL http://www.urvi.net/forumfiles/SB/B15-035.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-035.PDF TSB 16-008 - High Pressure Fuel Pump Chirps Applies To: 2014-18 RLX - ALL - ALL 2014 and 2016-18 RLX Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B16-008.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-008.PDF TSB 16-011 - Product Update: Monroney Label (Hawaii) Applies To: 2015-16 RLX - ALL - Check the iN VIN status for eligibility 2014, 2016 RLX Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B16-011.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-011.PDF TSB 16-016 - Starter Grinds or Spins at Startup Applies To: 2014-16 RLX - ALL - ALL http://www.urvi.net/forumfiles/SB/B16-016.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-016.PDF TSB 16-049 - Squeal During Electric Parking Brake Operation Applies To: 2014-16 RLX - ALL - ALL http://www.urvi.net/forumfiles/SB/B16-049.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-049.PDF TSB 16-065 - 2012 RL, 2014–17 RLX: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required) Applies To: 2014-17 RLX - ALL except Hybrid - ALL http://www.urvi.net/forumfiles/SB/B16-065.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-065.PDF TSB 16-066 - 2012 RL, 2014–17 RLX: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required) Applies To: 2014-17 RLX - ALL except Hybrid - ALL http://www.urvi.net/forumfiles/SB/B16-066.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-066.PDF TSB 17-003 - AcuraLink Sending Excessive Notifications for Low Power Applies To: 2014–16 RLX - ALL - ALL http://www.urvi.net/forumfiles/SB/B17-003.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-003.PDF TSB 17-032 - A/C High-Pitched Whine Applies To: 2014-17 RLX - ALL except hybrid - ALL http://www.urvi.net/forumfiles/SB/B17-032.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-032.PDF TSB 17-033 - Steering Intermittently Pulls to the Right Applies To: 2014-17 RLX - ALL - ALL 2014, 2016-17 RLX Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B17-033.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-033.PDF TSB 17-034 - MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2]) Applies To: 2014-17 RLX - ALL - ALL 2014 RLX Sport Hybrid Only - ALL - ALL 2016 RLX Sport Hybrid Only - ALL - ALL 2017 RLX Sport Hybrid Only - ALL - ALL http://www.urvi.net/forumfiles/SB/B17-034.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-034.PDF TSB 17-040 - Front Brakes Squeal Applies To: 2014-17 RLX (non-hybrid) - ALL - ALL 2018 RLX (non-hybrid) - ALL - From VIN JH4KC1...JC000001 thru JH4KC1...JC000553 http://www.urvi.net/forumfiles/SB/B17-040.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-040.PDF TSB 18-029 - Warranty Extension: Customer Support For Front Passenger's Airbag Inflator for 2016-17 RDX, 2014-17 RLX, and 2014, 2016-17 RLX Sport Hybrid (Expires June 30, 2030) Applies To: 2014-17 RLX - ALL - Check the iN VIN status for eligibility 2014, 2016-17 RLX Sport Hybrid - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B18-029.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-029.PDF TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram Applies To: 2014-20 RLX 2014-20 RLX Sport Hybrid http://www.urvi.net/forumfiles/SB/B19-059.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF TSB 20-020 - Blower Motor Is Noisy, Runs Slowly, or Intermittently Stops Working Applies To: 2014-18 RLX - ALL - ALL 2014, 2016-18 RLX Sport Hybrid - ALL - ALL http://www.urvi.net/forumfiles/SB/B20-020.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-020.PDF TSB 23-022 - Warranty Extension: Moaning or Rubbing Noise from P-AWS RTC Actuators and/or P-AWS Indicator On With DTC C1600-94, C1611-13, or C1621-13 Applies To: 2014-19 RLX - ALL with P-AWS - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B23-022.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-022.PDF |
TSB 13-041 was revised.
Added new TSB 23-022 - Warranty Extension: Moaning or Rubbing Noise from P-AWS RTC Actuators and/or P-AWS Indicator On With DTC C1600-94, C1611-13, or C1621-13. |
