Resetting TPMS
Old 03-27-2019, 12:02 PM
RDXguy's Avatar
Resetting TPMS
After setting your tire pressure to what you want, is there somewhere in the settings menu to click "Reset TPS"? I want the car to memorize the new pressures as the base pressure from which it will advise if it drops too much. I cannot find it in the settings menu or in the book. Thanks in advance.
Old 03-27-2019, 01:54 PM
Madd Dog's Avatar
Received 1,024 Likes on 714 Posts
It is an automatic read, so there is no reset. Just refill the tire to, likely, 33.
The low pressure light goes on if there is ‘significantly low pressure’
Old 03-27-2019, 02:02 PM
MrJames's Avatar
Don't forget the cover letter. Did you get the memo?
bluntman72 (03-27-2019)
Old 03-27-2019, 05:27 PM
Wander's Avatar
This vehicle has direct read TPMS, with physical sensors in the wheels.
Some other Honda vehicles use an indirect system based upon relative rotation speed of the wheel, and this must be calibrated to a particular pressure in the tires.
The system in 2019 RDX requires no calibration.
NeedsANewCar
1G TSX Problems & Fixes
04-02-2019 04:04 AM
mazen222
03-27-2019 11:50 PM
lumn8
1G RDX (2007-2012)
03-26-2019 05:10 PM
Anthony Lynn Davis Jr.
03-25-2019 06:44 PM
Anovice
03-23-2019 05:31 PM
Quick Reply: Resetting TPMS
